Old 09-12-2013, 09:17 AM   #57
milkesfrs
milkesfrs's Avatar
Drives: hot lava
Originally Posted by Dipstik-sportech View Post
It's pretty bad we have to do ghetto fixes to a brand new car already. After replacing all the clips under the headlight and on the fender the drivers side is better but now the pass side did it fml!!!
You're telling me.I wasted $900. When I took the car to the dealership there was a Scion representative there. He basically told me the bumper was fine when the car left the factory so it was my problem.I tried explaining to him that the bumper the clips everything is brand new and the bumper still wanted to come off at one corner. I got so mad I ended up cancelling my extended 7 yr warranty and gap insurance that day. I am now waiting for a twenty eight hundred dollar check from Toyota. The salesman at the dealership got so pissed that he was going to lose commission that they offer to fix the car. I told him no I wanted my money back and I would fix the problem.
I took the car to two different body shops. When they would get one side fixed the other side of the bumper would pop out !Both body shops said it was a design issue. If the bumper was cold it would stay in place and would seem like the problem was fixed. As soon as I would drive and the bumper would get hot I would say here we go again back to the body shop. The bumper wants to shrink and flex when it gets hot. One guy said that the old GM Saturn's had the same problem. Its crazy that we cant take the bumper cover off without have this issue. The body shop tried double sided tape, glue , and god only knows what else. Nothing seemed to work for long. If you keep on taking the bumper cover off you end up doing more damage. The bumper, bracket, and plastic tabs SUCK !!!
Like I said before. The way I got the bumper to stay with the speaker wire is ghetto but it worked. I can take off the bumper without having to worry about how the car is going to look. I'm having a turbo put in and was afraid that the bumper was going to give me problems again and look like s*** . I only had to put the wire on one side and its tight as hell . I drove the car at over 90 miles an hour and the bumper stayed in place. The fix work so good it should be patented.
milkesfrs is offline   Reply With Quote
The Following 3 Users Say Thank You to milkesfrs For This Useful Post:
charged86 (02-11-2014), covance (03-24-2016), Norcalmav23 (09-13-2013)
Old 09-12-2013, 12:45 PM   #58
mezdup
#1362
mezdup's Avatar
Drives: 2014 Ice Silver WRX
so, just so i'm clear, the wire is just kinda wedged in there? i'm probably gonna go this route
mezdup is offline   Reply With Quote
Old 09-12-2013, 12:55 PM   #59
milkesfrs
milkesfrs's Avatar
Drives: hot lava
Yep. The wire is wedged right on top of the corner tab thats giving us the problems.
The Following 2 Users Say Thank You to milkesfrs For This Useful Post:
mezdup (09-12-2013), Norcalmav23 (09-13-2013)
Old 09-13-2013, 02:49 PM   #60
Norcalmav23
Drives: SWP Limited manual BRZ
You Sir, are the man. This will be my Sunday morning. I will report back with hopefully similar results. Fingers are crossed!
- Clear Bra - 35% tint - Fa20 club intake - Rev Works header - Perrin OP - 3 inch FP - Resonated CB - Perrin LW crank pulley - Fortune Auto 500 V4 coil overs... pinky sized gap - Full CS knock off poly lip kit - JDM clear side markers - RPF1 18x8 - 35 offset - square 225-18-40 - Perrin shifter bushing - KartBoy positive shift kit - Hawk HPS pads - SS Lines - Visconti e85 tuned
Norcalmav23 is offline   Reply With Quote
The Following User Says Thank You to Norcalmav23 For This Useful Post:
milkesfrs (09-15-2013)
Old 09-13-2013, 09:47 PM   #61
milkesfrs
milkesfrs's Avatar
Drives: hot lava
I wanted to let you guys know if you're going to buy new brackets save your money. It's the bumper . I have the APR break cooling duct kit When the bumper is cold I have no problems. As soon has the bumper gets hot the tabs that hold the duct on pop off. This also happens on one side only. Once the bumper cools down I can pop the duct back into place.
Old 09-14-2013, 04:41 PM   #62
mezdup
#1362
mezdup's Avatar
that worked surprisingly well lol
Old 09-14-2013, 05:11 PM   #63
Norcalmav23
Yes, I can confirm as well that this works pretty well. It isn't 100% perfect but a heck of a lot better than before. Thank you for sharing this very simple and quick fix for us. Just a heads up... I didn't use the roller, I just put some tape on the end of a thin flat head screw driver... took about 5 mins to do both sides and they are about 90% "perfect". Happy Happy Happy
Old 09-14-2013, 06:37 PM   #64
mezdup
#1362
mezdup's Avatar
yea i did the same thing. i put some electrical tape around a flathead and it worked great. and yea, agreed, it's not perfect, but i'm more than happy with it.
Old 09-15-2013, 06:03 PM   #65
milkesfrs
milkesfrs's Avatar
Drives: hot lava
Good to hear that at least you can deal with the issue for the time being ! Looking at the bumper popping out was driving me nuts !
Old 09-15-2013, 07:33 PM   #66
alex_86
alex_86's Avatar
Drives: 2013 scion firestorm frs
sorry but i beg to differ on the whole it's the bumper , 1. it's kinda hilirous that the rep and bodyman actually convinced you it's the bumber it "shrinks" in the heat come on guy, that whole car would eventually within a month or two deform and nothing on the whole car would line up if that was the truth however it is the truth the bumper brackets ARE the source of the problem and no the bumper, how do i know you may ask well i work at a dealership that one we DO have a tsb for this problem and that we HAVE fixed one to date. im pretty sure more will come in, the soultion is a revised bracket ,yes the bodyman you took your car too was correct there is a design flaw, and subaru has made a revised part that involves the tabs on the bracket to be sharper in design and thus solving the issue. However i cannot say the same about toyota if they had even cared one bit about the issue you should try to look up the most current tsb. hope your local scion/toyota dealership doesnt try and give you another cold shoulder.
alex_86 is offline   Reply With Quote
The Following User Says Thank You to alex_86 For This Useful Post:
milkesfrs (09-16-2013)
Old 09-15-2013, 08:40 PM   #67
Dipstik-sportech
Dipstik-sportech's Avatar
I beg to differ with you sir. My dealer and subaru of Canada have heard of no such bumper tsb or redesigned brackets. If you have a part number for said brackets, could you kindly share.....
Old 09-15-2013, 08:44 PM   #68
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Please reveal the tsb number and/or the part number, thank you
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
The Following User Says Thank You to tonystewart For This Useful Post:
alex_86 (09-15-2013)
Old 09-15-2013, 10:38 PM   #69
wootwoot
Drives: FRS
I call bs... Prove it.
Old 09-15-2013, 10:52 PM   #70
alex_86
alex_86's Avatar
i highly doubt you yourself have talked to soc, but unlike you we are in the great country of the United States Of America were shit happens lol, im just messing with you.
Front Bumper Black Vinyl Juanito08 Exterior Parts (Aero, Lighting, Etc.) 37 09-18-2015 04:09 PM
Front bumper holes... BRZ88 BRZ First-Gen (2012+) — General Topics 29 08-14-2012 12:19 PM
Other than SR front bumper this is the only other one I like Hanzo Cosmetic Modification (Interior/Exterior/Lighting) 6 07-09-2012 03:30 PM
BRZ to FR-S front bumper swap? r4m3n Cosmetic Modification (Interior/Exterior/Lighting) 4 04-20-2012 05:29 PM
Buy this front bumper for G37 Coupe? WhatIs86For Other Vehicles & General Automotive Discussions 12 02-26-2011 02:24 AM
