#57 | |
Drives: hot lava
I took the car to two different body shops. When they would get one side fixed the other side of the bumper would pop out !Both body shops said it was a design issue. If the bumper was cold it would stay in place and would seem like the problem was fixed. As soon as I would drive and the bumper would get hot I would say here we go again back to the body shop. The bumper wants to shrink and flex when it gets hot. One guy said that the old GM Saturn's had the same problem. Its crazy that we cant take the bumper cover off without have this issue. The body shop tried double sided tape, glue , and god only knows what else. Nothing seemed to work for long. If you keep on taking the bumper cover off you end up doing more damage. The bumper, bracket, and plastic tabs SUCK !!! Like I said before. The way I got the bumper to stay with the speaker wire is ghetto but it worked. I can take off the bumper without having to worry about how the car is going to look. I'm having a turbo put in and was afraid that the bumper was going to give me problems again and look like s*** . I only had to put the wire on one side and its tight as hell . I drove the car at over 90 miles an hour and the bumper stayed in place. The fix work so good it should be patented. Last edited by milkesfrs; 09-12-2013 at 10:09 AM. |
| The Following 3 Users Say Thank You to milkesfrs For This Useful Post: |
#58 | |
#1362
Drives: 2014 Ice Silver WRX
#59 |
Drives: hot lava
| The Following 2 Users Say Thank You to milkesfrs For This Useful Post: | mezdup (09-12-2013), Norcalmav23 (09-13-2013) |
#60 |
Drives: SWP Limited manual BRZ
You Sir, are the man. This will be my Sunday morning. I will report back with hopefully similar results. Fingers are crossed!
- Clear Bra - 35% tint - Fa20 club intake - Rev Works header - Perrin OP - 3 inch FP - Resonated CB - Perrin LW crank pulley - Fortune Auto 500 V4 coil overs... pinky sized gap - Full CS knock off poly lip kit - JDM clear side markers - RPF1 18x8 - 35 offset - square 225-18-40 - Perrin shifter bushing - KartBoy positive shift kit - Hawk HPS pads - SS Lines - Visconti e85 tuned
| The Following User Says Thank You to Norcalmav23 For This Useful Post: | milkesfrs (09-15-2013) |
#61 |
Drives: hot lava
I wanted to let you guys know if you're going to buy new brackets save your money. It's the bumper . I have the APR break cooling duct kit When the bumper is cold I have no problems. As soon has the bumper gets hot the tabs that hold the duct on pop off. This also happens on one side only. Once the bumper cools down I can pop the duct back into place.
#62 |
#1362
that worked surprisingly well lol
#63 |
Yes, I can confirm as well that this works pretty well. It isn't 100% perfect but a heck of a lot better than before. Thank you for sharing this very simple and quick fix for us. Just a heads up... I didn't use the roller, I just put some tape on the end of a thin flat head screw driver... took about 5 mins to do both sides and they are about 90% "perfect". Happy Happy Happy
#64 | |
#1362
#65 | |
Drives: hot lava
Looking at the bumper popping out was driving me nuts !
#66 | |
Drives: 2013 scion firestorm frs
, how do i know you may ask well i work at a dealership that one we DO have a tsb for this problem and that we HAVE fixed one to date. im pretty sure more will come in, the soultion is a revised bracket ,yes the bodyman you took your car too was correct there is a design flaw, and subaru has made a revised part that involves the tabs on the bracket to be sharper in design and thus solving the issue. However i cannot say the same about toyota if they had even cared one bit about the issue you should try to look up the most current tsb. hope your local scion/toyota dealership doesnt try and give you another cold shoulder.
| The Following User Says Thank You to alex_86 For This Useful Post: | milkesfrs (09-16-2013) |
#67 |
I beg to differ with you sir. My dealer and subaru of Canada have heard of no such bumper tsb or redesigned brackets. If you have a part number for said brackets, could you kindly share.....
#68 |
Drives: 2013 Scion FR-S Raven
Please reveal the tsb number and/or the part number, thank you
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
| The Following User Says Thank You to tonystewart For This Useful Post: | alex_86 (09-15-2013) |
#69 |
Drives: FRS
I call bs... Prove it.
#70 |
i highly doubt you yourself have talked to soc, but unlike you we are in the great country of the United States Of America were shit happens lol, im just messing with you.
| Front Bumper Black Vinyl | Juanito08 | Exterior Parts (Aero, Lighting, Etc.) | 37 | 09-18-2015 04:09 PM |
| Front bumper holes... | BRZ88 | BRZ First-Gen (2012+) — General Topics | 29 | 08-14-2012 12:19 PM |
| Other than SR front bumper this is the only other one I like | Hanzo | Cosmetic Modification (Interior/Exterior/Lighting) | 6 | 07-09-2012 03:30 PM |
| BRZ to FR-S front bumper swap? | r4m3n | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 04-20-2012 05:29 PM |
| Buy this front bumper for G37 Coupe? | WhatIs86For | Other Vehicles & General Automotive Discussions | 12 | 02-26-2011 02:24 AM |
