Old 09-10-2013, 03:24 AM   #15
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Has anyone tried the Redline MTL and Motul Gear 300 back to back? Care to share your thoughts on the differences if any?
Since the MTL is 80W and the Motul is 90W....does the MTL give "lighter" feeling as such?
Fizz is offline   Reply With Quote
Old 09-10-2013, 10:35 PM   #16
Suberman
Drives: Subaru BRZ Sport Tech Satin White
Originally Posted by Kostamojen View Post
You obviously haven't been around Subaru's very much...
These cars use Aisin transmissions. Subaru doesn't build transmissions.
Suberman is offline   Reply With Quote
Old 09-10-2013, 10:36 PM   #17
Suberman
Originally Posted by DM7 View Post
I wouldn't be concerned with the metal particles that were in the fluid. Synchros are covered in very hard materials that needs to be worn in/off before they begin to work smoothly. A lot of material may be worn off at initial break in but it probably takes many thousands of miles before everything really smooths out. I'm at 3000 miles and my synchros have smoothed out and are no longer crunchy. 2nd gear used to be the worst especially when the transmission was cold but has since gotten better.
Engines, transmissions and brakes need to designed with all types of drivers in mind both good and bad. I'm pretty sure that even drivers with marginal/poor shifting technique would have no problems putting 100k miles on a transmission without a fluid swap.
Actually, synchros are soft, bronze in fact. What the break in does is allow time for the bronze to be thoroughly bathed in oil so that the synchros are fully lubricated. Another reason to follow factory break in.
Old 09-12-2013, 07:06 AM   #18
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
My poor poor 2002 wrx.
industrial is offline   Reply With Quote
Old 09-12-2013, 08:22 AM   #19
infinite012
Drives: 13 DGM BRZ Ltd
I changed my fluid to Pentosin 75w80 last night and immediately could feel the difference. Shifting into 1st produces no clunk (yet...) and from 1st to 2nd has no weird resistance.
So far so good.
infinite012 is offline   Reply With Quote
Old 09-12-2013, 09:13 AM   #20
jarviz
jarviz's Avatar
Drives: Raven FRS MT
I have 20K miles on original transmission fluid. Has everybody that changed out their fluid seen improvement in shifting?
jarviz is offline   Reply With Quote
Old 09-12-2013, 09:51 AM   #21
Ingen
Drives: Ultramarine FR-S 6MT
Anyone know the subaru / toyota part #s to order the crush washers for the trans and rear diff? And how many of each # I need? That's the only thing stopping me now... that and I need 2 more jack stands.
Car Received: 10/18. Break in ended: 10/28
Goal: Openflash UEL headers, Stage II 93 oct, TRD intake, arm rest :P
Ingen is offline   Reply With Quote
Old 09-12-2013, 11:08 AM   #22
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
YES
Old 09-12-2013, 11:09 AM   #23
OICU812
Just a dude
OICU812's Avatar
Originally Posted by roddy View Post
The car must be sitting level when filling the transmission.
^^^THIS is important to note^^^
Old 09-12-2013, 12:21 PM   #24
infinite012
I'm over 22k miles on my BRZ. I just changed my fluid yesterday and it's a marked improvement over stock fluid.
Old 09-12-2013, 04:33 PM   #25
frslee
Just drive it
Drives: 13' FR-S
Going to replace mine soon with Amsoil. I need to find a perfect day and nice flat spot.
frslee is offline   Reply With Quote
Old 09-12-2013, 04:42 PM   #26
HunterGreene
Hail Magnet
HunterGreene's Avatar
Subbed. I will likely have my shop replace the transmission fluid the next time I have it in the shop.
It has priests in it?
Old 09-12-2013, 05:26 PM   #27
Kostamojen
The trans gaskets you can get away with not replacing them as they are not crush washers. Diff you have to.
And you only need two jack stands, you just have to lift and lower the car more often.
Old 09-12-2013, 06:44 PM   #28
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
I changed mine to GM synchromesh, mainly because the transmission is a SOB in cold winter. Shifting are smoother now though even in summer weather. And metal shavings/dust/sludge are nothing to scuff about, fresh cut gears.,, Metal bits on the other hand..
Rayme is offline   Reply With Quote
DIY - Transmission / Diff Fluid Change Reference Guide F1point4 DIY (Do-It-Yourself) Guides 295 05-13-2023 02:34 AM
Automatic Transmission Fluid Change jmaryt Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 169 08-26-2018 07:55 PM
What transmission fluid are you using? Chillz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 25 04-06-2013 10:45 PM
Transmission and Differential Fluid Change LINK Amadeus DIY (Do-It-Yourself) Guides 1 12-23-2012 06:01 PM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
