Old 09-09-2013, 10:38 AM   #1
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
(SOLD!) Tactrix Subaru EBCS with extended Harness
Up for sale is the Tactrix EBCS with Subaru plug. This is the EBCS Ecutek tuners will use to control your boost via the tune and be able to give you up to 4 maps with different boost setups, giving you the freedom to change your Boost settings simply with the Cruise Control Stalk. I used it on the car for a few days, but decided to go with a full EBC.
The included harness is only a few inches long. I extended it to over a foot long to allow to mount the EBCS to a better location.
Price new is $101 shipped, I'm asking for $80 shipped.
Actual pics of my item:
Extended Harness:
Below is the image for the Solenoid and stock harness:
Sportsguy83 is offline
Old 09-09-2013, 08:57 PM   #2
Sportsguy83
Drives: Limited BRZ
Cheap and easy boost control
Old 09-10-2013, 03:34 PM   #3
Sportsguy83
Drives: Limited BRZ
Updated OP with pics
Old 09-11-2013, 09:59 AM   #4
jx86
Drives: -
Which Ebc set up did you go for?
Sent from my GT-N7102 using Tapatalk 2
jx86 is offline
Old 09-11-2013, 10:44 AM   #5
Sportsguy83
Drives: Limited BRZ
Haven't decided yet, looking long and hard at the Go Fast Bits G-Force II
Old 09-11-2013, 11:55 AM   #6
jx86
Drives: -
So you can scramble boost? =P
Was wondering if you had pictures of where you managed to mount it with that extension and whatnot. I'm looking to go FI soon and I can't decide on ebcs or ebc either..
jx86 is offline
Old 09-11-2013, 12:10 PM   #7
Sportsguy83
Drives: Limited BRZ
Unfortunately I didn't take a pic. But if you look at your driver's side strut top hat (enlarge the image below), there is a bolt doing nothing right behind it. In the image there is a white pin on the black hood cable, the bolt is right by taht pin. I bolted it right there.
See the red arrow below for reference to see where I mean.
Old 09-11-2013, 12:22 PM   #8
jx86
Drives: -
That's very neat!
Where exactly does this ebcs plug into? I assume it's ecutek controlled? I was under the impression they were only meant to replace the OEM subaru ones, which our cars don't have..
jx86 is offline
Old 09-11-2013, 12:31 PM   #9
Sportsguy83
Drives: Limited BRZ
That's very neat!
It connects to the EVAP solenoid (the one whose hoses are popping off on 11+ psi guys) connector behind the intake manifold.
Old 09-11-2013, 01:17 PM   #10
jx86
Drives: -
Ahh. I see. Pardon the stupid question but is it safe for the tuner to control boost via the Evap signals? I'm interested in this or the Grimmspeed EBCS, but I'm halfway around the world without a turbo (yet) with severely limited knowledge so I wouldn't quite know what to do with it.. Looking at the AVO kit, I'm thinking it might be a lot safer for me (installation wise) to just run a simple MBC
jx86 is offline
Old 09-11-2013, 01:24 PM   #11
Sportsguy83
Drives: Limited BRZ
Yeah, its safe. As long as your tuner has the tune nailed down it will be ok. Also, tuners build into their maps Boost Cut safety measures which won't allow your car to go over a certain amount of boost (which is the only bad result that could happen from a boost controller).
Old 09-11-2013, 02:47 PM   #12
jx86
Drives: -
Will this render the EVAP system useless then? I'm assuming you disconnect the EVAP solenoid and plug the EBCS instead into the cable that leads to the ecu. Sorry to pelt you with all these questions. I've tried search for hours, it's not a common subject unfortunately.
jx86 is offline
Old 09-11-2013, 03:20 PM   #13
Sportsguy83
Drives: Limited BRZ
Dont worry, questions are fine. Yes, no more EVAP system. Researched that online and found people have been doing it for years with no issues.
Old 09-11-2013, 03:44 PM   #14
ft_sjo
Drives: GT86
Is it a Pierburg valve? If so, these are often used in Porsches, so are pretty good.
ft_sjo is offline
WTB: Subaru BRZ Headlight Harness Parts enderr Exterior Parts (Aero, Lighting, Etc.) 3 08-28-2013 05:39 PM
subaru brz subwoofer kicker harness mmontes Electronics | Audio | NAV | Infotainment 0 08-16-2013 05:57 PM
extended warranty? lionbacker54 BRZ First-Gen (2012+) — General Topics 28 05-27-2013 10:44 AM
Extended Warranty kevinnivek8877 BRZ First-Gen (2012+) — General Topics 30 06-14-2012 05:00 PM
Extended Warranty? FoxtrotRomeo-Sierra Scion FR-S / Toyota 86 GT86 General Forum 4 05-31-2012 01:02 PM
