View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up?
Yes (Please only vote after you have 300 miles or more on the odometer) 3,101 85.22%
No (Please only vote after you have 300 miles or more on the odometer) 538 14.78%
Voters: 3639. You may not vote on this poll
Old 09-11-2013, 11:06 AM   #2745
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
Originally Posted by DylanFRS View Post
And how many miles it has been since you replaced the pump!
Over 4,000 miles so far.
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
Old 09-11-2013, 11:10 AM   #2746
Opie
Opie's Avatar
Originally Posted by mid_life_crisis View Post
Around 500 miles. I just checked for the first time and I definitely have the noise, although after growing up spending summers on Cape Cod back in the sixties (cricket central), I would never have come up with crickets as a description.
I didn't check the manufacturing date, although it is a 10th anniversary edition which should mean it is fairly recent, correct?
If you have to "check for the noise" you likely don't have the issue. The crickets chirping is loud enough to hear while sitting in the car with the engine running. Sounds like a super bad belt tensioner.
A normally operating HPFP makes all kinds clicking and clacking, but that is perfectly normal.
Old 09-11-2013, 11:12 AM   #2747
Opie
Opie's Avatar
Originally Posted by texasbound972 View Post
Please share part number!
Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
It is the same part number, but the updated parts have a green dot sticker next to the part number. The updated parts have been produced since April of this year.
Old 09-11-2013, 12:13 PM   #2748
losjackal
Drives: FR-S 10-series #405
Originally Posted by Terrapin77 View Post
There are 2 ways to stop the chirps.
1. Use E0. This isn't an option for people who live in urban areas.
2. Use 2 stroke oil. Kills the chirps for me. I put it in the fuel tank at a 1:1000 ratio. I use Lucas Oil 2T semi-synthetic w/ low ash. A small bottle costs me $3.99 at Pep Boys. It contains enough for 4 fill ups.
Originally Posted by sierra View Post
There's one fuel additive that doesn't just claim to lubricate the system, that's it's sole purpose. 2T
@Terrapin77 and @sierra, would you mind giving me input on this? You both seem to advocate this Lucas Oil 2T.
http://www.lucasoil.com/products/dis...d=290&loc=show
Another poster recommended this Mercury Quicksilver 2-stroke oil:
http://www.walmart.com/ip/Mercury-Qu...d-Oil/17165294
A salient feature about it is compliance with TC-W3:
http://www.nmma.org/certification/ce...oil/tc-w3.aspx
Lucas also makes a TC-W3 oil:
http://www.lucasoil.com/products/dis...id=17&loc=show
So given all of the above, would you still say the Lucas Semi Synthetic 2-CYCLE Oil is the best choice for our cars? I just don't know enough about the science of it.
losjackal is offline   Reply With Quote
Old 09-11-2013, 01:27 PM   #2749
mid_life_crisis
Drives: FR-S 10 #103 AT
By "checked for it" I mean I turned off the radio and sat in the car for a few seconds before shutting it off. I could hear it just fine with the windows up and the radio off.
Back when I was a production line mechanic if I heard that sound I would have been walking the line trying to locate the bearing that was getting ready to fail so I could have the replacement part handy for the next scheduled shutdown or when it failed, whichever came first. I don't like that sound and yes I know in this case it probably has nothing to do with a part about to fail. I still don't like it.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 09-11-2013, 01:52 PM   #2750
Terrapin77
Terrapin77's Avatar
Drives: 2013 Argento FR-S
I decided to use the 2T method after reading sierra's posts on the subject. I don't have a recommendation on what 2T oil to use. It just happens that the oil I mentioned is the only 2T oil the Pep Boys by me sells. All I know is I have been chirp free since I began using it. Sierra does say to use a low ash or no ash 2T oil.
Sent from my XT912 using Tapatalk 2
Terrapin77 is offline   Reply With Quote
Old 09-11-2013, 02:33 PM   #2751
xXDeathMaliCeXx
xXDeathMaliCeXx's Avatar
Drives: Scion FR-S
I haven't been keeping up with this thread lately, but I figure I should share that I now have a little over 7,000 miles on my FRS and no longer hear the chirping. Never had the high pressure fuel pump or anything replaced. And I use regular 93 octane fuel, no E0 fuel or anything.
Sent from my Nexus 7 using Tapatalk 4
2013 SWP Toyota GT86 -- Daily Duty
xXDeathMaliCeXx is offline   Reply With Quote
Old 09-11-2013, 05:42 PM   #2752
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Interesting.....
Old 09-11-2013, 11:01 PM   #2753
sierra
Drives: Skoda Yeti DSG diesel 4x4
I have googled using 2T in 4 stroke engines and you should too. I have found no negative posts from anyone trying it.
I used it in my 2.5 common rail T diesel for years at 1:200 to compensate for the low sulphur content in modern diesel fuel which lubricates the HP fuel pump for the direct injection. Much quieter, smoother and better economy that more than paid for the 2T.
It's used quite extensively in diesels and there's lots of info on it if you look. The criteria for the 2T is quality, low or no ash and mineral is fine. The Lucas 2T sounds ok.
1:1000 is a very low, that's less than a teaspoon of it in a gallon.
We don't get the chirps in Oz because ethanol is still rare and not available in the grade specified but i've tried 2T in mine at that mix with no problems, not that I expected any, only benefits. I think it might even clean the fuel system and help keep the fuel fresh too?
sierra is offline   Reply With Quote
The Following User Says Thank You to sierra For This Useful Post:
solidONE (09-11-2013)
Old 09-12-2013, 12:28 AM   #2754
Marusich
Marusich's Avatar
Pennzoil also makes a TC-W3 2 stroke oil.
http://m.autozone.com/autozone-mobil...25vj?id=143763
Marusich is offline   Reply With Quote
Old 09-12-2013, 02:17 AM   #2755
sierra
This is an interesting post about 2T, mainly in diesels but very positive about it's properties.
I have a few litres left and might start adding it again just to keep it sweet, quiet and for economy. It's Valvoline 2T Racing Oil to JASO FC, API TC and ISO GD
http://www.alfaowner.com/Forum/alfa-...ml#post4999743
Old 09-12-2013, 12:30 PM   #2756
jorbis
Drives: FR-S WhiteOut, 6MT
My chirping came back as well. Toyota did the fix about 1500 miles ago and they are back. But this time its more of a squeeking noise.
I havent been on in awhile, so I just read about the 2 cycle oil. I'm thinking about possibly trying it out, but does anyone know of anyother engine lubricants that might work as well?
jorbis is offline   Reply With Quote
Old 09-12-2013, 02:15 PM   #2757
Terrapin77
Terrapin77's Avatar
I've tried Lucas Oil Ethanol Fuel Conditioner & Lucas Oil Fuel Treatment. Neither of them worked for me.
Old 09-14-2013, 12:38 PM   #2758
rhood168
rhood168's Avatar
Drives: Black Subaru Brz Limited
Got my pump replaced middle of aug and now the chirps are back 1000 miles later awsome.
rhood168 is offline   Reply With Quote
Is this idle noise normal? robo_robb Engine, Exhaust, Transmission 288 01-25-2022 09:40 AM
Squeak noise from engine. Fish Scion FR-S / Toyota 86 GT86 General Forum 52 05-08-2014 01:06 PM
Video of chirping at idle Julio86 Engine, Exhaust, Transmission 15 02-01-2013 10:37 AM
Starting to get worried - Engine noise Laika BRZ First-Gen (2012+) — General Topics 49 07-02-2012 03:45 PM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 12:00 PM
