Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AUSTRALIA
AUSTRALIA Australia and New Zealand
Old 09-10-2013, 04:50 PM   #183
Arnimaniacs
Drives: WR BLUE MICA
Originally Posted by djmm View Post
SPeaking of sound upgrade, I read that stock sound on both BRZ and 86 are pretty crap. I haven't got my 86 yet, but just wondering, if I set aside say $500 (boss wife won't let me spend so much on this) to upgrade the sound system, will I be able to get any improvement at all over the stock?
I don't need audiophile quality, but at the very least sound decent.
For $500. A few ppl got splits n this power pack.
http://www.alpine.com.au/showItem.php?item_id=162
Arnimaniacs is offline   Reply With Quote
Old 09-10-2013, 05:36 PM   #184
djmm
djmm's Avatar
Drives: toyota
Since deadening improves road noise as well, I am leaning towards it more. It's not cheap if you do full car right, but if I only do doors (which I hope is enough to improve sound quality), will it still cost more than 500?
djmm is offline   Reply With Quote
Old 09-10-2013, 05:54 PM   #185
Arnimaniacs
Focal bam is like top of the range. Dynamat is a bit cheaper.
Depends on where you go. Some will only sound deadening around the speakers. Other will do the whole doors.
Example of focal bam. Done properly.
http://www.caraudio.com.au/forums/in...the-brz-or-86/
Old 09-10-2013, 06:07 PM   #186
fuddbutter
Potato Farmer
fuddbutter's Avatar
Drives: #SLOBRZ
That is over done.
I used 1 x Dynamat door pack over 2 cars, one of them was my Aust championship winning SQ car..
The other i was told i had too much midbass in at the only comp i put it in, the door was solid.
it's all about correct placement, smothering the door like that is just a waste of money and adding unessasary weight.
Something something butter..
www.vic86brzclub.com
fuddbutter is offline   Reply With Quote
The Following User Says Thank You to fuddbutter For This Useful Post:
ZZT86 (09-11-2013)
Old 09-10-2013, 06:09 PM   #187
Arnimaniacs
So just around the speakers is enough?
Old 09-11-2013, 06:44 PM   #188
fuddbutter
Potato Farmer
fuddbutter's Avatar
Drives: #SLOBRZ
I cut the SD into strips and squares, then i go over the door skin knocking and looking for any vibration, then when i do, whack on a piece.
Old 09-12-2013, 07:00 AM   #189
jack
Sound System BRZ
Alpine W910R head unit
Alpine PXE 660 sound pro
Alpine 4 x 110 watts RMS @ 4 ohms
Alpine mono 550 watts RMS @ 4 ohms
Alpine 5 1/4 type R in rear
Hertz ESK 163L.5 front
Focal 10" sub x 2 boot
Dyna Mat Extreme
some pics during build
All the connections are quick release ,takes me 30 seconds to remove both subs and amp panel .,no drilling in body ,
jack is offline   Reply With Quote
Old 09-12-2013, 07:03 AM   #190
Arnimaniacs
Very nice jack
Old 12-18-2013, 09:11 AM   #191
Alabang BRZ
A few questions.
How is the compatibility of the DDX630WBT with Apple iOS 7 and Android 4.4 Kitkat?
I found out that other than the Subaru BRZ the Toyota 200mm wide 2DIN standard is also used by the Third generation (2007–2011; GE, GH, GR, GV) Subaru Impreza and Third generation (SH, 2008–2013) Subaru Forester.
I was told by a dealer/installer that the steering wheel controls of the Subarus can be used by the Kenwood. There is no need for splicing.
Alabang BRZ is offline   Reply With Quote
Old 04-02-2014, 09:09 AM   #192
Kobra666
Drives: Storm Black Toyota 86 GTS
Does the stock headunit out of a 86 GTS have rca outputs?
Kobra666 is offline   Reply With Quote
Old 04-04-2014, 10:57 PM   #193
Tornado86
Drives: stock 86 GTS
personally sad to see you didn't go boxed, but looks trick - never enough bass right!!
Tornado86 is offline   Reply With Quote
Old 04-07-2014, 06:28 AM   #194
ZZT86
ZZT86's Avatar
Drives: BR86
No.
ZZT86 is offline   Reply With Quote
purchasing area 86 stuff pkptd447 Scion FR-S / Toyota 86 GT86 General Forum 7 08-15-2014 02:09 PM
Help Me Get This Stuff OFF!!! wootwoot Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 7 09-07-2012 10:38 AM
Any more cool stuff? Davyator Scion FR-S / Toyota 86 GT86 General Forum 21 05-24-2012 03:28 PM
More HKS stuff! uspspro Engine, Exhaust, Transmission 0 04-25-2012 12:27 PM
Dimman's technical stuff. Dimman Other Vehicles & General Automotive Discussions 74 10-17-2011 01:15 PM
