Old 04-16-2013, 09:08 PM   #15
schtebie
Drives: CBS BRZ Limited
Originally Posted by Supermassive View Post
Yes, so that's why you drain it when you can see oil in the little sight tube, which I just figured out makes a perfect drain since its a clear plastic tube with one-touch fittings, just undo the top one-touch and flip it over into something you want to catch it in and presto!
I have the same can, but can't figure out how to undo the clear tube to drain it. How do you release the tube?
schtebie is offline   Reply With Quote
Old 04-16-2013, 10:24 PM   #16
Supermassive
Supermassive's Avatar
Push the blue plastic piece into the black plastic housing then pull the clear tube out.
Supermassive is offline   Reply With Quote
The Following 2 Users Say Thank You to Supermassive For This Useful Post:
JPxM0Dz (04-17-2013), schtebie (04-16-2013)
Old 04-17-2013, 12:53 PM   #17
Hanakuso
If Saikou Michi doesn't come out with there catch can I might just buy this Cusco one and get it painted flat black.
Hanakuso is offline   Reply With Quote
Old 05-27-2013, 05:16 AM   #18
w3bhead
Drives: A Car
Cusco Catch Can Question
Hi everyone, first time to post on this forum. I just bought this catch can for my 86. Any news on how much oil you were able to collect from it, @Supermassive?
How were the lines installed? Does the line from the PCV connect to the top or the bottom? Because I've been looking around and I saw this diagram which would seem like the air flows in from the bottom and exits the top part.
http://www.google.com.ph/imgres?um=1...fmICgCw&zoom=1
w3bhead is offline   Reply With Quote
Old 09-07-2013, 07:45 AM   #19
Supermassive
I poured out about a 1/4 of a cup of oil last time i emptied it. As for my routing....well I didn't follow the instructions, but the lines connect PCV to bottom inlet. The idea is to allow the air to flow through the collector while oil which is heavier than air attached to the mesh in the can. The crappy thing about this kit is that the clear lines turn brown pretty quickly due to the vapor.
The Following User Says Thank You to Supermassive For This Useful Post:
Laika (09-07-2013)
Old 09-09-2013, 07:02 PM   #20
empower-auto
Kouki-Monster
empower-auto's Avatar
I'd really like a diagram of where the hoses go. I have the straight up catch can (horizontal) on right now and am putting the separator on tonight. Which hose does the PCV run to and which runs back into the intake tube where the PCV originally ran? Or am I doing it wrong?
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 10-18-2013, 12:55 AM   #21
ft86me
ft86me's Avatar
Drives: 2013 FRS
i'd like to know this as well since i have a unit coming in very soon. like a couple days. i THINK this just gets put between the factory pcv valve.
ft86me is offline   Reply With Quote
Old 04-26-2015, 10:04 PM   #22
empower-auto
Kouki-Monster
BUMP
Anyone?
Rich Anderson
EMPOWER AUTO
Old 04-28-2015, 05:20 PM   #23
Efferalgan
Drives: 2025 BRZ, ex-2012 GT86
BUMP
Anyone?
Does this picture answer your question?
Efferalgan is offline   Reply With Quote
The Following User Says Thank You to Efferalgan For This Useful Post:
empower-auto (04-29-2015)
Old 04-29-2015, 06:45 PM   #24
empower-auto
Kouki-Monster
Yes. THANK YOU. That's perfect
Rich Anderson
EMPOWER AUTO
Cusco Street Spec A Coilover Kit Scion FR-S Subaru BR-Z No Upper Mount FRS-HHH Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 03-31-2016 07:17 AM
**PHASTEK** Scion FRS / Subaru BRZ Oil Catch Can (oil air seperator) PhastekSport Engine, Exhaust, Bolt-Ons 16 11-30-2013 11:45 AM
Selling a Vertical door kit FRS-89 Exterior Parts (Aero, Lighting, Etc.) 0 02-20-2013 02:57 PM
Group Buy - Cusco transmission mount + Beat Rush master brake cylinder stopper Nardi330 Australia Classifieds 74 10-28-2012 01:08 AM
New cusco transmission mount! Silverdub Engine, Exhaust, Transmission 5 07-11-2012 08:50 AM
