Old 08-16-2013, 04:22 AM   #29
BRZSTIAZ
BRZSTIAZ's Avatar
Drives: SWP Subaru BRZ
I have this too. If someone knows exactly what it is please chime in.
BRZSTIAZ is offline   Reply With Quote
Old 08-20-2013, 11:57 PM   #30
evo4g63
evo4g63's Avatar
Drives: 2016 Subaru WRX
Can someone pots a video of the issue?
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD
evo4g63 is offline   Reply With Quote
Old 08-21-2013, 08:56 AM   #31
Mikem53
Drives: FR-S 6MT
Originally Posted by Jaylyons1 View Post
I'm getting this sound now too. 2200ish miles. Also have the crickets and a very odd lope. Kind of sounds like it's misfiring. On top of this, last night I walked out to the garage and the rear of the car just started buzzing. I didn't even touch it.
Needless to say, it's in the shop now and I'm rocking a loaner Outback.
The buzzing noise with The car off is the fuel pump and the fuel system doing maintenance to the Fuel evaporation system. It occurs about five hours after you stop the car. Really weird, but it's normal and they all do it.
Mikem53 is offline   Reply With Quote
Old 08-21-2013, 03:59 PM   #32
Jaylyons1
Jaylyons1's Avatar
Drives: 2022 WRB BRZ; 1993 Skyline GT-R
Ah, good to know. I just happened to go off when I walked by the car this time. It was like it was growling at me.
Jaylyons1 is offline   Reply With Quote
Old 09-09-2013, 09:37 AM   #33
Wattage
Wattage's Avatar
Drives: scion fr-s MT
My frs has developed what i think is this same problem just over the last week. The rattle happens at ~5k+ RPM when in gear. Sounds similar to how it sounds when you stick your finger in a fan.
Im at toyota right now having them look at it.... they tried to tell me it was the DI kicking in (lol). I said to them, ok, why did it only start in the last week? Then i took a mechanic for a ride and hes like ooooohhh theres the sound. So we'll see what they say now.
Wattage is offline   Reply With Quote
Old 09-09-2013, 10:06 AM   #34
Wattage
Wattage's Avatar
Hmmm so they didnt find anything loose..... now they say they contacted toyota technical; who want them to take a recording of the sound and give it to them. They say theyve never encountered it before... sheeeeeeeeit
Old 09-09-2013, 11:22 AM   #35
Foobar
SLO NO MO
Foobar's Avatar
For USDM cars, the underbody panels need some extra washers on some of the bolts because we're missing the underbody panels that go over the sides. The bolts were designed to hold both center and side panels overlapped, but without the side panels in place, you end up with a gap. If memory serves correctly, there were about 4 bolts that I had to do this to.
I'm not saying that this is definitely the cause of the noise, but it helped in my situation.
Old 03-20-2014, 07:45 PM   #36
juliog
juliog's Avatar
Drives: 86
Originally Posted by Chele View Post
Did someone find out where this rattle is coming from? It happens at 4k rpm and it goes away by 4300 rpm . It sounds like a loose heat shield. Only happens under load.
^ same thing here. Started experiencing this after flashing a base EcuTek stg 1 tune, probably unrelated but a coincidence nonetheless..
juliog is offline   Reply With Quote
Old 06-21-2014, 09:31 AM   #37
RED_CAR
Drives: GT86
UP !
I have the problem and I try to fix the bolts of the under engine cover with washers without success.
No sound generator on my car...
RED_CAR is offline   Reply With Quote
Old 06-22-2014, 07:14 PM   #38
Mr 286
Mr 286's Avatar
Drives: 2014 Camry SE V6 | 1991 MR2 Turbo
Almost the same here. My underbody panels rattled as well. A bolt had worked its way loose. It was found and fixed. Noise didn't come back since.
Mr 286 is offline   Reply With Quote
Old 06-23-2014, 07:32 AM   #39
BeRZed
I've been getting a loud noise and rattle on a few occasions too, but only when I'm in reverse. Happened since I got the Nameless overpipe/downpipe installed. Anyone know what it might be?
BeRZed is offline   Reply With Quote
Old 07-07-2014, 09:43 AM   #40
Roarke
Drives: Subaru Brz 2014
Originally Posted by Panecki17 View Post
The latest strange noise coming from my BRZ crops up while accelerating hard between 4k - 5.5k RPMs. It's a hard noise to describe, but it sounds like a combination of spring peeper frogs (not crickets) and a dial-up modem. Again, this only happens when the engine is under heavy load. It doesn't happen during normal driving/acceleration.
Any idea what might be causing this?
My first thought is that it might have something to do with the port injectors activating around these RMP's, or maybe it's just a vibration in the noise generator. I haven't done the noise generator delete yet, but I'll see if that helps.
I have same issue.. Its around 6k rpm.. And i was scared like hell when it happen first time..
Its not happening everytime, so its very hard to reproduce.. Anyway, even I show it to subaru mechanic, they didnt find anything
They were only surprised that I drive it so hard 5-7k rpm
Roarke is offline   Reply With Quote
Old 07-18-2014, 09:18 AM   #41
unlimited86
Drives: s2000
I got the same issue today after washing my car, got it up above 5k and it started rattling. Has anyone able to resolve the issue?
unlimited86 is offline   Reply With Quote
Old 07-23-2014, 04:15 PM   #42
Slonie
Slonie's Avatar
Drives: Only ridiculous cars
It sounds like there are at least two plausible suggestions for the cause and solution of this noise... I'm going to look into them both as I've noticed the same when pulling around 5k...
Slonie is offline   Reply With Quote
Strange Noise from rear of car while OFF mike2100 Issues | Warranty | Recalls / TSB 23 12-17-2014 09:14 PM
Squeak noise from engine. Fish Scion FR-S / Toyota 86 GT86 General Forum 52 05-08-2014 02:06 PM
Engine pinging (rattle noise) under acceleration sho AUSTRALIA 95 08-10-2013 06:52 PM
Starting to get worried - Engine noise Laika BRZ First-Gen (2012+) — General Topics 49 07-02-2012 04:45 PM
Strange noise Random_Art Other Vehicles & General Automotive Discussions 15 06-03-2011 04:31 PM
