Old 09-08-2013, 05:31 PM   #1
ProTekk
ProTekk's Avatar
Drives: Whiteout FR-S
Auto Trans Fluid Drain & Refill
Just finished draining and refilling my diff and went to move on to the trans. I've located the drain plug, overfill plug and refill hole but don't seem to have the right socket size for the refill plug. Any ideas as to what size it is? Largest I have is a 19mm and I'm just speculating it'll be around 20-21mm. Searching hasn't shown anything and the manual doesn't state it either. I checked out the IS250 forums since that's where the trans is from but no one there has done it on their own.
Sent from my SGH-M919 using Tapatalk 2
ProTekk is offline   Reply With Quote
Old 09-08-2013, 05:54 PM   #2
Hagbard
Hagbard's Avatar
http://www.ft86club.com/forums/showthread.php?t=19218
Hagbard is offline   Reply With Quote
Old 09-08-2013, 06:05 PM   #3
ProTekk
ProTekk's Avatar
I've already read through that and it covers the manual trans. The automatic trans is different. There's no bolts on the auto trans that uses the 10mm hex socket.
Old 09-08-2013, 06:38 PM   #4
Hagbard
Hagbard's Avatar
This post has the PDF of the auto but damned if i can actually find in it what size they are page 140.
http://www.ft86club.com/forums/attac...7&d=1339384129
Old 09-08-2013, 06:43 PM   #5
ProTekk
ProTekk's Avatar
Yupp, that was the last thing I read before deciding to ask the forum. Kind of a pain in the ass and making me regret getting an auto
FRS/BRZ Manual Trans Fluid shellslinger Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 131 11-02-2017 10:44 AM
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
Greddy Magnetic Oil Drain Plug or Fumoto Drain Valve? tracerit Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 01-04-2016 07:36 PM
Change trans fluid thru dipstick bigsley18 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 07-18-2013 10:16 AM
Trans/Diff Fluid. DanoFA20 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 01-11-2013 03:11 PM
