Old 09-08-2013, 01:09 PM   #1135
xwd
Originally Posted by 5150unltd View Post
Big fucking problems! Installed GrimmSpeed front strut bar this morning exactly following the directions and using a torque wrench set to 12ft lbs to tighten to factory spec i drive it all day and its fine... took it for a couple hard runs down some back roads and head home for the night.. pulling onto main road I hear a rattling noise and get home and pop my hood and find the strut bar is very loose at 1st touch pull out my phone and this is what I find! All the bolts snapped! What the fuck! Either terrible design or 12 ft lbs is to much torque
What kind of torque wrench were you using? Most 3/8" and 1/2" drive torque wrenches aren't really that accurate at something as low as 12ft-lbs. I just hand tightened mine to snug and that's generally about all you need with something like this.
The bolts were obviously way overtorqued and stretched.
I might have to do the polish treatment on mine as well, that looks good.
Old 09-08-2013, 06:44 PM   #1136
Evil Jesus
Evil Jesus's Avatar
Drives: '13 FR-S Raven 6MT
Holy shit, that sucks. This issue would be the only thing that would prevent me from purchasing this part.
As other have said though, it seems that you may have over-tightened the nuts. I notice that you have a Crawford sticker on the strut-to-firewall brace. Is that just a sticker or are those aftermarket braces as well?
Evil Jesus is offline   Reply With Quote
Old 09-08-2013, 06:47 PM   #1137
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
Been a bit now since I've had mine and just did a autox with it. No issues at all. Still love it but now I'm deff goin to sand and polish that Grimmspeed logo.
Out of the FRS game
Mr.Jay is offline   Reply With Quote
Old 09-08-2013, 07:35 PM   #1138
Nardi330
Nardi330's Avatar
Drives: 86
OMG im scared. i torqued mine to 12ft/lb according to my torque wrench but it feels pretty tight. then i used the torque wrench to tighten the stock nut near the firewall and it turned a little more. left it overnight then saw the above post and i loosen all nuts a bit and hopefully they won't snap.
Nardi330 is offline   Reply With Quote
Old 09-09-2013, 02:54 AM   #1139
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
Sorry, no install pic. Been raining like crazy here. I LOVE the feel of the car! Definitely a noticeable difference! Thank you so much, Sirs!
Old 09-09-2013, 11:45 AM   #1140
GrimmSpeed
GrimmSpeed's Avatar
Drives: '13 BRZ, '12 WRX
Send a message via AIM to GrimmSpeed Send a message via MSN to GrimmSpeed
This is extremely unfortunate! I'm sorry to see that happen to you or anyone. I must reiterate that 12ftlbs is the factory torque value for those studs, and that I have personally removed and re-torqued ours literally over 100 times with no problems. It is a dry torque value, so if you used lube, and then torqued to 12ftlbs it could have possibly lead to an over torquing. Additionally this is the only case of this happening thus far, and we have many other people autocrossing with this bar, on top of other people running it hard.
It appears that the problem is most likely with your torque wrench. The fact that all 4 studs snapped makes no sense, because if the bar was the issue at least one side of the bar would have had to remain attached in order to apply force to the opposite side's studs. Even if that did happen, the other two breaking with no applied force is physically impossible. What makes even less sense, is that you were able to recover the studs and bolts, and that they did not fall to the ground somewhere during your spirited drive. The only explanation for this failure mode is that the studs were over torqued either during the install, or were over-torqued at a previous instance that caused the studs to begin to stretch, at which point they were already ruined. The fact that all 4 failed backs up the fact that either the torque wrench is out of spec, or that the studs themselves were a poor material composition (however unlikely).
Again, we're very sorry that happened to you, this is why we made it very clear to be careful on these studs. However, unless the material composition on all 4 studs was bad, 12ftlbs is the factory torque spec, and would not cause the studs to stretch. Additionally, the bearing surface (the surface of the strut bar that would physically interact with the stud) is substantially thicker than the stock triangulation bars, and thus substantially lowers the shear force acting on the stud, it does not raise it. Think cutting through something with a thin knife blade, and then trying to cut through the same thing with the opposite, dull side of the knife that is substantially thicker. So, I can safely say it is not "terrible design." I would think about throwing away that torque wrench, or try to remember if you or anyone had previously torqued those studs before this incident. We'd like to hear more about it to help prevent this from happening in the future, and as always you can give us a call or send us an email to talk about it.
612 379 0000 or engineering@grimmspeed.com
Chase
Engineering
GrimmSpeed is offline   Reply With Quote
The Following 6 Users Say Thank You to GrimmSpeed For This Useful Post:
Captain Snooze (09-09-2013), chanomatik (09-09-2013), Evil Jesus (09-10-2013), kwood9000 (09-09-2013), mfbmike (11-10-2013), mRdeMs83 (09-09-2013)
Old 09-09-2013, 12:19 PM   #1141
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Good news, LOVE this strut bar
Installed the bar and my MCB and both look at home in my car I have to take some new pictures of my car so the will end up in my build thread. Love the stuff you make Grimmspeed!
Now where is your intake info thread? month out or so? I need something else to follow religiously this christmas
Old 09-09-2013, 01:14 PM   #1142
GrimmSpeed
GrimmSpeed's Avatar
Originally Posted by xn7485 View Post
So I borrowed your ideas of hose clamp and mounting point. I had planned to utilize your setup, even have the $5 rubber thing from HK, but then I came up with a design of my own and thought I'd share. Any constructive criticism welcome. And yes I quoted pictures for easier comparison.
Main difference here is a spring extension; 1/2"x2-5/16"x.062" (12.70mmx58.74mmx1.60mm)
And oh yes, installed bar:
Hey thats pretty cool too man! I love your guys' solutions. If it were my car I would paint the brackets, and try and find some black coated hardware to be extra stealthy. Hopefully one of these days I can try my hand at a DIY solution
Originally Posted by OICU812 View Post
Yea I did mine to be different, seems others have as well already. A fine file some sand paper and 5 minutes for a different look. Personally I like the subtle change and abit O' bling factor.
Those look so good!!! I brought a bar home this weekend to start doing a little customizing for fun, but just didn't find the time to get to it. I am truly jealous as I want that look on our car, and I guarantee you're making some of the other STB owners run to their garage to do the same.
That is great to hear, glad you're enjoying it, and I hope you had a hell of a time at the autox!
I would not be worried if I were you, and in fact I would have left them torqued as you had them. You do not want them to be undertorqued and let the bar come loose. No reason to be scared! I just talked to the user that posted up the broken studs, and his case sounds like a problem with the studs themselves as it seems he did everything correctly. This isn't the first case I've heard about people torquing those studs correctly and having them fail, but it certainly is very rare.
Hey no problem man, and thank you very much sir! Also rain = less tire wear :P
Oh, I LOVE good news. That is great to hear, and thank you very much! The comments that you guys make, and the support that you have for us literally fuels us through the day.
Hahahaha, I am not sure of when yet. We are still very early into this project, but I promise there will be a development thread.
5150ultd thanks again for giving me a call so we could figure out what happened, hopefully it doesn't happen to anyone else.
Folks, thank you to everyone so far for the nice comments, and for posting up pictures of your installs and how you have customized the logos, and ac line brackets. I honestly love to see what you guys are coming up with, and I have to apologize for not coming up with any cool custom bar yet myself. It'll happen!
Chase
Engineering
The Following User Says Thank You to GrimmSpeed For This Useful Post:
Old 09-09-2013, 03:39 PM   #1143
RazBRZ
Cones are bad
RazBRZ's Avatar
Drives: 2013 BRZ Premium
It has begun. A little behind schedule, but whatever. GrimmSpeed Cherry Blossom paint
RazBRZ is offline   Reply With Quote
The Following User Says Thank You to RazBRZ For This Useful Post:
SkAsphalt (09-09-2013)
Old 09-14-2013, 04:48 AM   #1144
Evil Jesus
Evil Jesus's Avatar
Are new people still installing these? Impressions? Issues?
Can't wait to pick mine up if all is well.
Old 09-14-2013, 05:03 AM   #1145
sierra
Drives: Skoda Yeti DSG diesel 4x4
15 days since I ordered mine. I went out to the garage the next day and fitted a 12mm socket and short extension onto my torque wrench. I even loosened a couple of strut nuts and retorqued them to get some practice in.
In Oz, waiting.
I would appreciate knowing if the broken studs were overtorqued so we can relax about that aspect?
sierra is offline   Reply With Quote
Old 09-14-2013, 12:16 PM   #1146
Evil Jesus
Evil Jesus's Avatar
Originally Posted by sierra View Post
1
It really seems that that was the case. The GS guys have put on 100s of prototypes without issue they said. Haven't seen a single other person with issues either.
How tight is 12 ft/lbs anyway? Just slightly snug? Not looking forward to buying a $100 torque wrench to put on a $160 part if I don't have to. :happy0180:
Old 09-14-2013, 12:20 PM   #1147
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
If you plan on working on your car with any regularity, buy the torque wrench.
Sent from my Nexus 4 using Tapatalk 2
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 09-14-2013, 03:04 PM   #1148
disgruntld
Less than pleased...
disgruntld's Avatar
Drives: '13 BRZ Ltd SSM 6MT
$20 for a 0-80 ft-lb torque wrench at Harbor Freight.
disgruntld is offline   Reply With Quote
Anyone using the STi Flexible Strut Tower Brace? ngabdala Suspension | Chassis | Brakes -- Sponsored by 949 Racing 45 08-15-2019 01:59 AM
F/S Beatrush Strut Tower Brace Type-2 $175 Dan-in-Japan Brakes, Suspension, Chassis 2 02-24-2013 01:38 PM
FT-86 SpeedFactory Strut Tower Brace Review F1point4 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 35 01-07-2013 04:31 AM
DIY - Strut Tower Brace - FT-86 SpeedFactory F1point4 DIY (Do-It-Yourself) Guides 4 10-28-2012 04:30 PM
