Old 09-04-2013, 09:42 PM   #1
brillo
Drives: 2013 Firestorm FR-S
Toyota Oil Change at Dealer - Do they check the ECU?
I've got a free oil change from the dealer I might use post track day. My ECU is flashed and I'm not sure if the dealer oil change stations check things like the ECU to see if an update is warranted. I don't want to tip my hand over a free oil change.
What have other experienced?
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
Old 09-04-2013, 10:31 PM   #2
Nightbringer
Nightbringer's Avatar
Drives: Scion FR-S
They've never checked mine, but my dealership has two service areas---one for the general express lube, and a full service area. The former doesn't even have the capability to scan the ECU. Regardless, they shouldn't have a reason to check yours. A friend did go in for an update without switching out his tune and they just flashed over it. Not sure if they were cognizant of it being non-OE even.
Short: I wouldn't sweat it.
Nightbringer is offline   Reply With Quote
Old 09-05-2013, 09:01 AM   #3
jadewbj
jadewbj's Avatar
Last oil change I went in for they flashed my ecu since there was an update out for my car. So it could happen. I am not tuned so no big deal, but it is possible.
jadewbj is offline   Reply With Quote
Old 09-05-2013, 09:14 AM   #4
Suberman
Drives: Subaru BRZ Sport Tech Satin White
It's quite likely the ECU is read routinely at a service. Toyota and Subaru weren't born yesterday.
Suberman is offline   Reply With Quote
The Following 2 Users Say Thank You to Suberman For This Useful Post:
AZP Installs (09-23-2013), Trap63 (09-05-2013)
Old 09-05-2013, 10:33 AM   #5
brillo
It was my understanding once flashed the ECU couldn't be overwritten unless you flashed back to the stock flash. Is that not correct? That was my concern, if they couldn't flash the ECU then they would know something is up. I'm not concerned if they simply overwrite it as I can flash it back with no issues.
Old 09-05-2013, 07:46 PM   #6
SavEvoIX
Drives: Evolution IX, 13' FR-S White Out
Then you don't work in the service industry. There's no way they are going to hook up to your ECM. These guys get paid off of time and more than likely they have a entry level lube or apprentice working on your vehicle.
SavEvoIX is offline   Reply With Quote
Old 09-06-2013, 09:29 AM   #7
Suberman
Every Audi that enters a dealership for service gets VAG read for codes. Hooking up a code reader takes minutes and on many cars you don't even have to pop the hood. Of course they read for codes.
Dealerships make nothing on oil changes. They are ALWAYS looking for warranty work, or preferably non warranty work.
Which bankrupt dealership did you get laid off from?
AZP Installs (09-23-2013), xia (01-01-2014)
Old 09-07-2013, 04:48 PM   #8
kcam86
Drives: Asphalt FR-S MT
I can't speak for all dealerships but I can for mine. I work in service and I can say with 100% confidence that at my work they won't scan during an oil change. The name of the game is to churn out cars asap oil change to detail for a quick service wash. Also you're absolutely wrong about warranty work. They LOVE and prefer warranty work because who in their right mind would deny warranty work :P.
kcam86 is offline   Reply With Quote
Old 09-22-2013, 09:12 PM   #9
SavEvoIX
What are you talking about? If you knew anything the manufacturer frowns upon up selling warranty and add on warranties actually are reviewed by corporate warranty admin/dpsm.
Also, just as I said there's no way when you take your car in they scan for any DTCs if you are just getting a oil change. Go back to your troll cave this is Toyota.
Old 09-23-2013, 03:56 PM   #10
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
Really it varies on dealership. Some dealers will troll for more work especially in a bad economy. I would personally not bring it to a dealership with the edu flashed. Just put it back to stock and you won't have to worry.
-Mike Paisan
11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts.
Now we have an Online Catalog where you can purchase Parts! AZPParts.com
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
AZP Installs is offline   Reply With Quote
Old 01-01-2014, 12:52 AM   #11
HapaHaole
Drives: Grocery cart
As a former Toyota tech, we don't plug in the scan tool unless it is needed. The only time they flash is if the VIN run shows a TSB or Campaign then we would perform it, or when running the system for codes due to a Check engine / failure light on.
Now the Audi is different since to reset the maintenance light it's easier to plug in the scan tool, on newer ones you have plug in a VAS / VAG scan tool to reset the light.
HapaHaole is offline   Reply With Quote
Old 01-01-2014, 04:11 PM   #12
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
It wouldn't surprise me if my dealer thought my car had a carbureted rotary with pistons.
Old 01-01-2014, 04:13 PM   #13
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
When I was a tech, I never ran a code check unless I was authorized to do so. If the work is not authorized, and I perform the additional work, I don't get paid for it.
Dealership wanted the cars to be moved out for the customers. In and out as fast as possible because the customer is waiting.
However if we spot something, we'll note it down in the report but we won't perform the work right there and then. We'll put it on the recommendation.
If there's a recall out, the service advisor will always inform the customer first because the SA will look up the customers car in the database first.
Also for TSBs, we only perform them if the customer authorizes it. We can't just go "We changed your oil and some TSBs, even though all you came in for was an oil change".
Old 01-01-2014, 06:32 PM   #14
AZP Installs
My guess is that this is very dealer dependent.
-Mike Paisan
Maintaining, Modifying and Educating TriState Enthusiasts since 2001.
Help with Oil change at dealer kombatlion Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 03-23-2013 10:54 AM
Dealer Oil change Issue Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 9 02-18-2013 04:06 PM
should i change oil myself or let dealer do it? chenshuo CANADA 28 02-14-2013 01:28 PM
Check Engine light after: Major service (Fuel pump, ECM, and 7500 miles oil change) R2RO Issues | Warranty | Recalls / TSB 3 02-04-2013 10:06 PM
Dealer Oil Change JSK CANADA 6 10-05-2012 04:36 PM
