Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > NY / NJ / CT / PA
NY / NJ / CT / PA NY, NJ, CT, PA
Old 09-05-2013, 02:51 PM   #1
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
Question Any Place to adjust Coilovers in Central NJ?
I am looking for a shop to install and adjust my coilovers in central Jersey. And also do corner balance & alignment. Anybody know a good auto shop?
How much to install a set of coilovers with full soft setting and to do alignment+corner balance? I might need something like a one year package so I can do damper and camber adjustment after installing them.
Will be good if it is near New Brunswick.
BTW, a stupid question: after the coilovers are installed, can I adjust damper by myself without doing alignment?
Thanks.
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
The Following User Says Thank You to Figo For This Useful Post:
Jive Turkey (09-06-2013)
Old 09-06-2013, 06:57 PM   #2
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
What kind of coilovers? Where did you buy them? What kind of racing are you doing?
-Mike Paisan
11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
AZP Installs is offline   Reply With Quote
Old 09-06-2013, 10:23 PM   #3
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
check out AZP installs. they did my coilovers, and specialize in suspensions and subaru's.
Jive Turkey is offline   Reply With Quote
Old 09-06-2013, 11:22 PM   #4
cnk
Drives: '13 DGM BRZ Limited
For an alignment, I went with EG Tire in Dayton. You have to ask for Jeff. He used to set up Miatas and S2000s for auto-X. He will corner balance and do an alignment. He spent a good 2-3 hours just doing my alignment making it perfect.
As for installation, why not try the installation yourself? It only takes a couple hours to do and will give you some experience working on your car. The only tedious thing is setting the height as you'll be jacking the car up and down multiple times while making adjustments. If you don't want to do the install yourself, I would recommend AZP as well and they are relatively local to New Brunswick.
As for adjustments after install, you should be able to adjust the dampening (compression and rebound combined or independently depending on the type of coilover you have). The only thing that would probably require a re-alignment is if you adjusted the height as that will affect your camber/toe.
Old 09-23-2013, 02:08 PM   #5
Figo
Figo's Avatar
I am thinking to get RSR coilovers, but seems like they are out of stock for a while. They will come with preset but Its kinda too low to me. I need around 25mm drop only.
-Mike Paisan
Old 09-23-2013, 02:10 PM   #6
Figo
Figo's Avatar
Thanks hah.
How much did they charge for everythin? installation, alignment and weighted.
Old 09-23-2013, 02:11 PM   #7
Figo
Figo's Avatar
Thank you man thats really helpful.
Did you mean that any tire store that have alignment can also do weighted?
I thought they only do regular car like camry.
Old 09-23-2013, 02:13 PM   #8
campy
No rice, no life
campy's Avatar
Drives: 2013 Asphalt FR-S
Have you considered lowering springs?
campy is offline   Reply With Quote
Old 09-23-2013, 02:14 PM   #9
cnk
No. Not all stores can do corner balancing. Typically only the ones geared towards the enthusiast/racing crowd. If you just go to EG Tire, they won't corner balance for you. You have to call and ask for Jeff and set up an appointment. He basically rents out the alignment rack from EG Tire and brings his own scales. He used to work for EG Tire.
Old 09-23-2013, 02:28 PM   #10
Figo
Figo's Avatar
I jsut called EG tire and Jeff is no longer there.
A noob told me that they do not know how to do the corner balance.
Old 09-23-2013, 02:32 PM   #11
Figo
Figo's Avatar
Yep, i got lowering spring on my old car and installed them by myself. Now just wanna try somethin new. Also want to setuo damper to make it stiffer on the rear. And its a new car so I dont want to change shock after 3-4 years.
The only thin I am not sure about coilovers is that I will hav to change height by myself. Iv never done that before. And dont know how to measure the drop.
Old 09-23-2013, 02:49 PM   #12
AZP Installs
Shoot us a e-mail and we'll work with you to get a proper setup. We've had very good results in testing the KW coilovers. Jive Turkey as well as a few other BRZs are running our KW setup.
-Mike Paisan
Now we have an Online Catalog where you can purchase Parts! AZPParts.com
Old 09-23-2013, 02:50 PM   #13
Jive Turkey
the tuna, no crust.
Thanks hah.
www.azpinstalls.com
all prices are on the website. also feel free to shoot an email to Sales@azpinstalls.com
-ivan
Old 09-23-2013, 02:54 PM   #14
Figo
Figo's Avatar
Thank you I just called them, hah
www.azpinstalls.com
-ivan
Beatrush Mounts ,BC BR, Bilstein, ISC N1, ST Coils, KW Coils and Stance Coilovers b2autodesigns Brakes, Suspension, Chassis 818 09-10-2017 08:33 AM
Coilovers Coilovers, Coilovers: Tein, KW, BC, D2, Cusco, Eibach + more FREE SHIPPING! No Limit Motorsport Brakes, Suspension, Chassis 204 05-26-2017 12:09 PM
>>>>>>>WANT HIGH-END COILOVERS? LOOK HERE ~ New ST Coilovers l KW l Racecomp l Ohlins Circuit Motorsports Brakes, Suspension, Chassis 230 02-17-2016 12:01 PM
Drift Office Tune vs Visconti Tune mechaghost Engine, Exhaust, Transmission 109 07-03-2014 12:57 AM
Dynotronics and their E-Tune/ OTA tune. Ricepuddin User/Vendor/Sponsor Reviews, Feedback, Comments 5 12-24-2012 09:53 AM
