Old 09-05-2013, 07:45 PM   #29
jflogerzi
jflogerzi's Avatar
I have read at by adjusting your idle RPM a bit higher via tune can help with the rattle. Might want to talk with your tuner.
Old 09-05-2013, 09:01 PM   #30
jamesm
my motiv overpipe rattled until i disconnected everything and pushed up on it while tightening it back up, bought me 1/2-3/4" clearance where before there was none. might be worth a try.
Old 09-05-2013, 09:40 PM   #31
Tim_Asphalt_FRS
Is it fast? No.
Tim_Asphalt_FRS's Avatar
Drives: 2013 Scion FR-S Manual-Asphalt
That's how I installed my PLM overpipe. No rattles at all. I have about 3/4" clearance from the sway bar.
Sent from my iPhone using Tapatalk - now Free
2013 (Rebadged) Toyota GT-86 {Perrin intake tube, aFe dry air filter, custom 2.5" exhaust, PLM overpipe, Kartboy crank pulley, Hotchkis springs, custom Flossy grip tape shorty, TRD shifter, Berk HFC, Whiteline Sway-bars}
[Wanted: Delicious Stg 2 tune, Bilstein struts]
Tim_Asphalt_FRS is offline   Reply With Quote
Old 09-05-2013, 10:03 PM   #32
bestwheelbase
Drives: 1985 P-Type
Well this is a first. Fix an exhaust rattle with a tune? Intredasting.
Old 09-06-2013, 01:39 AM   #33
jflogerzi
jflogerzi's Avatar
I have seen FA20Club say this help with headers and a rattle issue. So it might help with the OP?
Old 09-06-2013, 02:38 AM   #34
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
I plan on getting this over pipe, and it looks like I'm about to buy some used headers that the original owner got rid of because they rattled. Haha my car is going to be noisy as fuck.
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 09-06-2013, 02:43 AM   #35
Anthony
Weight Nazi
Anthony's Avatar
Oh! And for anyone just beginning to look into a full exhaust system, the deal-maker about this particular over pipe is that it's the lightest one known to the general community as of now.
~3 pounds even!
Lightest Exhaust, Headers, and Front/Over/Mid Pipes
Old 09-06-2013, 10:58 AM   #36
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
What's the nameless downpipe weigh? One piece front/over pipe combo.
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 09-06-2013, 11:00 AM   #37
StormTrooper
Could also try heat tape on the subframe to dull the sound....
GR86 MT premium
Old 09-06-2013, 12:16 PM   #38
jflogerzi
jflogerzi's Avatar
What do you guys think? Which is the better deal
FA20Club EL Header catless header plus PLM OP and catted Front pipe for 1300$
Revworks UEL Header + Motiv OP and Catted Front pipe for about 1250$
I am after a smooth sound and much TQ/HP I can get. I would assume FA20Club combo would be the better choice. My Catback is a res Perrin 2.5
Old 09-06-2013, 11:01 PM   #39
Anthony
Weight Nazi
Anthony's Avatar
I would say the Revworks header because the FA20Club one is actually 50% heavier than stock and almost 300% the weight of the Revworks header. Power and torque won't do you much good if your car is heavy.
The Following User Says Thank You to Anthony For This Useful Post:
Mr. (09-18-2013)
Old 09-07-2013, 10:02 PM   #40
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Revworks.
FT-86 SpeedFactory is offline   Reply With Quote
Old 09-07-2013, 10:09 PM   #41
jflogerzi
jflogerzi's Avatar
Originally Posted by FT-86 SpeedFactory View Post
Revworks.
very interesting. Can you post your reasons why.
Old 09-07-2013, 11:58 PM   #42
Anthony
Weight Nazi
Anthony's Avatar
Because smiley face. What more do you need!?
Agency Power Front/Over pipe (Combo pipe) - Cheap! seven Engine, Exhaust, Bolt-Ons 12 03-09-2013 01:40 AM
FA20CLUB Over Pipe Front Pipe & Cold Air Intake Now Ready FA20Club.com Engine, Exhaust, Transmission 171 02-27-2013 09:44 AM
Will a resonated front pipe make alot less noise than test pipe? Mike86 Engine, Exhaust, Transmission 8 01-26-2013 07:24 PM
Agency Power over-pipe/front pipe combo question... seven Engine, Exhaust, Transmission 11 01-13-2013 12:14 PM
