JonMotoring
Old 09-05-2013, 04:31 PM   #15541
Ninjin
Ninjin's Avatar
Drives: SWP BRZ 6MT
@40flash does the window auto up-down feature that runs off the door switch cause any problems? i.e. is the door is harder to close because the window is up because the car thinks the door is already closed?
Sent from my GS4.
Old 09-05-2013, 04:41 PM   #15542
redsuns03
So.. who's all going to HIN for Show and Who's just attending to watch?
Old 09-05-2013, 05:04 PM   #15543
JesseE
JesseE's Avatar
Drives: LS Swapped BRZ
If anyone else wants to go to In and Out right off 101 and w bell rd... come by will be there 1:30 (about 30 minutes from now)
JesseE is offline   Reply With Quote
Old 09-05-2013, 05:05 PM   #15544
JesseE
JesseE's Avatar
Sent from my GS4.
Might be useful to do this for couple days after tint is done... but I wouldn't keep it like that personally
Old 09-05-2013, 05:13 PM   #15545
Yruyur
Yruyur's Avatar
Originally Posted by chrisbfrs View Post
Another intake mod.
Titanium pipe on my AIRAID box.
I did some analyzing with my laser thermometer on a few different intake materials. The stock tube and the AIRAID tube have a temperature around 50° to 56° Celsius on the top of tube, and 70°C towards bottom of tube near engine block. The titanium tube stays at 40° to 45° C on top and 60° C towards bottom.
The intake manifold has a constant temperature of 56°C
All the airboxs were around 45°C
So the titanium material is better for a CAI.
Moderninktattoos.com
I need to get you that bluetooth adapter so you can read intake temps at idke and speed to measure heat soak too.
Sent from a Motorola DynaTAC 8000X
The Following User Says Thank You to Yruyur For This Useful Post:
chrisbfrs (09-05-2013)
Old 09-05-2013, 05:19 PM   #15546
chrisbfrs
2012 car of the year
chrisbfrs's Avatar
Drives: Frontengine Reardrive-Sportcar
Originally Posted by nelsmar View Post
Course has already completed. Barely any rub left at this point... lol
what were your logged IAT... that sounds to me like the cold air being sucked in was cooling the surrounding area. And that the plastic was an insulator that was absorbing the heat. What were the MAF readings?
Not trying to be negative, just saying i wouldn't directly say its "better for cai" more so it is better to cool the bay temps down lol.
I was just using an infrared laser thermometer after running the car for a few hours each time.
I was measuring temps after engine shut off, but checked right away and a while after car had been sitting.
The stock and plastic materials were always at a higher temperature than the titanium.
I don't have anything to read or log the ecu but if someone has something and wants to log some readings for me it would be cool.
But to me if one material is retaining higher temps and for longer periods of time after car shut off than another material, it just seems like the cooler material would be better.
chrisbfrs is offline   Reply With Quote
Old 09-05-2013, 07:59 PM   #15547
Nu_era
Drives: 13 FRS 10series/94 Supra Turbo 6spd
Hello everyone, my name is Gabe and I live in Tucson. I just purchased my FR-S 10 series 6-speed a week ago and love every second I drive it. I needed a Daily driver and here is the result. I sold my 04 Xterra for this so now just the 06 Lexus R400H and the 94 Supra left in the garage. I have been a part of the Supra community for a bit and the Scion community ( had 2 tC's, one Supercharged and another with a built engine and GT35r). I am happy to be back in the Scion community but new member to this forum. Hope to meet you all soon
Nu_era is offline   Reply With Quote
The Following 9 Users Say Thank You to Nu_era For This Useful Post:
4azcats (09-06-2013), brenesk91 (09-05-2013), dsrttigr (09-05-2013), jack43 (09-05-2013), jeffsides (09-05-2013), nelsmar (09-05-2013), Sivtec (09-05-2013), SpyderMS (09-05-2013), Yruyur (09-05-2013)
Old 09-05-2013, 08:01 PM   #15548
nelsmar
This is why people make hard plastic intakes. They insulate and dont transfer heat as much which allows the colder air to stay colder. If something is colder than its environment then it is going to be absorbing the heat around it and placing it somewhere. In this case it would be transferring the heat in the bay to the pipe, and then to the air. How much is another story... but a quick datalog between intakes in consistant environments could tell you. We can always plug in EcuTEK to your car and log between two intakes to see the air temperature differences.
My flickr - Canibeat
Local magazine scout
The Following User Says Thank You to nelsmar For This Useful Post:
Old 09-05-2013, 08:09 PM   #15549
chrisbfrs
chrisbfrs's Avatar
I know they use plastic material to insulate heat and maintain cool temperatures, but it also cuts cost for production and makes an affordable product to consumer. Using titanium calls for a very expensive intake system so if it does end up showing it make cooler intake air temps, companies are still going to go with a material that os easy to produce and sell.
My obd port is screwed up so I hope I can get an obd plug to work with it
Old 09-05-2013, 08:16 PM   #15550
whaap
whaap's Avatar
Drives: '13 FR-S firestorm, 6 mt - '11 CR-V
Welcome Gabe. It's nice to have another Tucsonan.
whaap is offline   Reply With Quote
Old 09-05-2013, 09:33 PM   #15551
Evil86
Evil86's Avatar
Drives: Monkey-butt red FR-S
No
Dang it Chris, at that point you were suposed to tell us,
There is also one in Downey, Ca, and there is also the replica in Des Moines.
MotoEast ECUTEK tune; PPE Engineering intake, EL headers, overpipe, front pipe w/ hi-flow cat, midpipe, and single exit axle-back; GC camber plates; GC coilovers with Koni Sport (r) and Koni 8612 (f); Eibach front springs and Hypercoil rear springs; Hotchkis rear sway bar; Eibach front sway bar; Whiteline positive traction sub-frame inserts and differential support outrigger bushings; 17x9 Enkei RPF1 w/ 245 Hankooks.
Evil86 is offline   Reply With Quote
Old 09-05-2013, 09:44 PM   #15552
Accurate Race Shop
Accurate Race Shop's Avatar
Drives: Scion FR-S
Ronald replaced him apparently
I bought a ford tarus 10 years ago with a bag that had that guy on it shoved under the back seat. Found out later that people collect them.
Sent from my Q10
Old 09-05-2013, 10:01 PM   #15553
Yruyur
Yruyur's Avatar
Lewiston Idaho.
Lol people have been guessing all day and finally got it.
http://www.ft86club.com/forums/showthread.php?p=1190572
Old 09-05-2013, 10:08 PM   #15554
AzFranz
Az to Nm to Az
AzFranz's Avatar
I shoukd have some dyno data on the JDL header soonish. I really like their design and craftsmanship. Sent from my GS4.
I distinctly remember your shit not being craftsmanned so well on dyno day...yes craftsmanned, I said it, it's now a word.
It's a sleeper...I launch, it feels like it's asleep.
AzFranz is offline   Reply With Quote
