Old 09-05-2013, 04:11 AM   #225
ft_sjo
Drives: GT86
Do you think there's scope to reduce the flash time in the future? BRZ-Edit, for example, takes about 2 minutes to write.
Old 09-05-2013, 04:23 AM   #226
Rombinhood@OpenFlash
Drives: FRS
Yes, we can reduce the time between write commands to shorten flash times. But that will probably come after a few weeks. There some other diagnostic functions we would like to implement first. As with the BMW application, the FR-S/BRZ application evolve over time.
Rombinhood@OpenFlash is offline   Reply With Quote
The Following 2 Users Say Thank You to Rombinhood@OpenFlash For This Useful Post:
FrX (09-05-2013), ft_sjo (09-05-2013)
Old 09-05-2013, 05:21 AM   #227
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
Can the rev limiter be adjusted to both different rpms and a softer limit.
Have the logging tables been defined?
Which tuners aside from vishnu support this?
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 09-05-2013, 06:33 AM   #228
Foobar
SLO NO MO
Foobar's Avatar
A list of participating tuners would be great.
Sent from my Nexus 4 using Tapatalk 4
Old 09-05-2013, 07:49 AM   #229
TIE Pilot
TIE Pilot's Avatar
Drives: TIE interceptor; BRZ13
Any evidence or footprint left after going back to stock?
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." Jeremy Clarkson
TIE Pilot is offline   Reply With Quote
The Following User Says Thank You to TIE Pilot For This Useful Post:
Anthony (09-05-2013)
Old 09-05-2013, 09:55 AM   #230
jamesm
no more than any other flashing solution.
Old 09-05-2013, 10:09 AM   #231
jadewbj
jadewbj's Avatar
This may be exactly what I am looking for. I am so scared about my motor popping and having a tune on there. At least this way you can go back to stock and unless they dealer really wants to go looking it should be fine.
jadewbj is offline   Reply With Quote
Old 09-05-2013, 11:36 AM   #232
Drives: FRS
Yes, the rev limiters can be adjusted. Both the on RPM and the off RPM. When you set them close to each other, you get a "softer" rev limit. The wider the gap between them, the harder the rev limit. The stock tune has a ~200rpm difference which is why its pretty hard.
Datalogging will be enabled later this month and will show the channels necessary for tuning such as RPM, Ignition Advance, AFR, Commanded AFR, Knock, Knock Learning, Ignition Advance Multiplier, STFT, LTFT, etc,. It will display these values realtime on its screen and store up to an hour of data on board (no laptop required). Then you can download the data to the laptop to export into our datalog viewing software. It will work exactly like it does on our BMW application:
[ame]http://youtu.be/wlEfyKIlWdg[/ame]
*Except the part about the in-dash boost gauge
Vishnu Tuning, who has been mapping Subaru engines since 1999, will be providing baseline maps for gasoline and E85 applications. From no modifications to full bolt-ons. All the mapping is open and unencrypted for anyone to see and make further changes if so desired. You can even take your car to any competent dyno tuning shop to get custom tuned. They won't need any special licensing or need to purchase any additional tuning software as you would with the other flash tuning software packages. It is all free with the OpenFlash Tablet. For power mapping, all changes will be isolated to just a few tables which are clearly labeled (Ignition Advance, Ignition Correction, AFR, VVT Intake and VVT Exhaust. Of course, there are ~200 editable tables in all so you have access to just about anything. But realistically, only a handful will be edited. Hopefully this will demystify the tuning process as it is quite simple on the FA20 application. Having access to the tables and being able to share maps with others should move things along quickly to the point were no one is at the mercy of their tune supplier. At $500 for a tune with handheld device, we predict some resistance from existing Ecutek dealers. But if history repeats itself, they will give in as they have in other platforms where open source tuning was released (Mitsu and Subaru).
Anthony (09-05-2013), toro73 (09-05-2013)
Old 09-05-2013, 11:41 AM   #233
Drives: FRS
The OpenFlash Tablet saves your original ROM file (when you first install it). You can flash this original file back into your ECU when its time to go to the dealership. Unlike other "closed" tuning solutions (Ecutek or BRZedit), there are no licensing markers embedded in the code. This means that the stock ROM is ACTUALLY stock, byte for byte.
The Following 3 Users Say Thank You to Rombinhood@OpenFlash For This Useful Post:
Anthony (09-05-2013), jamesm (09-05-2013), TIE Pilot (09-05-2013)
Old 09-05-2013, 11:45 AM   #234
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Aaaaaaaaaaand sold.
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
The Following User Says Thank You to Anthony For This Useful Post:
thebus (09-10-2013)
Old 09-05-2013, 11:46 AM   #235
bakerr6
Drives: 2013 raven black fr-s
same lmk when I can buy this haha
bakerr6 is offline   Reply With Quote
Old 09-05-2013, 11:47 AM   #236
SkullWorks
Drives: SSM LT MT BRZ
I hope you have about 30000000000 of these ready to ship lol
Old 09-05-2013, 11:52 AM   #237
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
that's wat I was gonna say ^as soon as a purchase link goes I'm I'm attacking it
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
Old 09-05-2013, 12:49 PM   #238
Drives: FRS
Thanks gentlemen! We will have an online order link up on Monday by the latest. If anyone has any more questions, please feel free to ask...
FrX (09-05-2013), leon78 (09-05-2013)
#lolwut, divinecomedy, dopeandcashcabinet, free shiv now, goddamitimissedit, golden cage, i missed the show, looks good, missed the fun, omgbbq, shiv 2016, thefatandthefurriest
Tablet on the dash ! TRD_86 Electronics | Audio | NAV | Infotainment 23 05-16-2015 03:48 AM
Tablet Install ThugNasty Electronics | Audio | NAV | Infotainment 4 04-13-2013 03:15 PM
Blutooth OBD II and a 9.7 tablet.. Scooby South Electronics | Audio | NAV | Infotainment 10 12-16-2012 08:11 PM
7.0 Tablet w/ Torque App Thatruth2001 Northwest 26 11-21-2012 11:53 AM
