JonMotoring
Old 09-05-2013, 01:18 AM   #15513
fst86frs
fst86frs's Avatar
Drives: FAT H8R Hot Lava FRS
[quote=jeffsides;1187893][QUOTE=jeffsides;1185647]
Attachment 50142
Just a count for tech day on who is planning on attending and projects to complete.
Projects
1. Bonks86 - headlight painting
2. Redsuns03 - pulleys, snorkel
3. Yruyur - caliper painting
4.
5.
Guests/hangout
1. Jstunna
2. 448hpsti
3. SpyderMS
4. KIMMMIdrvr
5. Rpg1031
6.
7.
8.
9.
10.
Count me in planning on going forsure as long if I don't go to subiefest
fst86frs is offline   Reply With Quote
Old 09-05-2013, 01:54 AM   #15514
Yruyur
Yruyur's Avatar
Originally Posted by 40flash View Post
Do you ever find yourself sitting in your car with the engine shut off, listening to the audio system, and I don't want to have the door shut because of the heat, yet with the door open the door chime drives you nuts? I have the solution. This is the third car I've owned that I have done this mod to. I install and wire in a small rocker switch below the stock door switch that when switched on fools the car into thinking the door is shut. I then add a small rubber bumper on the door that shuts the switch off when I close the door to reset it to the off position and restore normal operation next time I open the door. [/IMG]
httpi41.tinypic.com5o9oom.jpg[IMG]
This pic shows inside or behind the rear quarter panel. The top wire is the stock switch. Below that you can see the hole I cut with a drill & die grinder to clear the terminals of he new switch. I revised the wiring so ignore the routing in the picture. You just need go through the new switch and from there to the stock switch.
Should do a diy in that section. Lots of peoole would appreciate it.
Sent from a Motorola DynaTAC 8000X
Old 09-05-2013, 02:27 AM   #15515
Cross
It's the Mad Cow
Cross's Avatar
So lets see, didn't someone need a stock muffler?
Exhaust system is done, I removed the 2nd Cat and a Resonator (that weird small one) and had a bolt in replacement made and then the OEM Muffler pulled and my new replacement and tips installed.
Sounds decent, I expected it to be louder though... not that I wanted annoying but My 2000 Impreza RS had that Boxter sound that I loved and well I thought this would be similar. It does sound good just not what I thought.
I also took off the front snorkel after reading what one of the members here posted with dyno graphs.
I am now trying to find the Switchbacks I bought that came in yesterday... but I can't seem to find where I put them.... not surprising.
I also need to find some time to put in the Lowering Springs I have here, but it looks like Friday the majority of my LED Lighting and my new Side Mirror Lenses. Should be a busy weekend.
Old 09-05-2013, 02:38 AM   #15516
JesseE
JesseE's Avatar
Drives: LS Swapped BRZ
Did you put a Header on too? you won't get that awesome sound until you replace factory header with a UEL one...
JesseE is offline   Reply With Quote
Old 09-05-2013, 02:58 AM   #15517
jeffsides
AZ FRS 86
jeffsides's Avatar
Sunday Sept 15th, show up as early as 8:00am
Text me for address and info 480-414-1334
See you all there!!!
Projects
4.
5.
Guests/hangout
1. Jstunna
2. 448hpsti
3. SpyderMS
4. KIMMMIdrvr
5. Rpg1031
6. Nelsmar
7. Chrisbfrs
8. FR-Shadow
9. Fst86frs
10.dsrttigr
@AZFRS86
Old 09-05-2013, 03:01 AM   #15518
jeffsides
AZ FRS 86
jeffsides's Avatar
@AZFRS86
Old 09-05-2013, 03:15 AM   #15519
Cross
It's the Mad Cow
Cross's Avatar
I am going to start looking into that tomorrow, I see there are equal and unequals but I need to find dyno data on both before I pick a set. Unless someone locally is selling a set.
I also need to look into how to handle any Cat O2 Codes.
Old 09-05-2013, 03:55 AM   #15520
SpyderMS
SpyderMS's Avatar
Drives: 2014 BRZ - Crystal Black Silica
Major accident on the 60 just west of the 101. Westbound 60 was routed to the South 101. Hope everyone from the drive made it safely home tonight.
SpyderMS is offline   Reply With Quote
The Following User Says Thank You to SpyderMS For This Useful Post:
Ninjin (09-05-2013)
Old 09-05-2013, 03:58 AM   #15521
Ninjin
Ninjin's Avatar
Drives: SWP BRZ 6MT
Good thing I took the 202 back, I guess.
I did see a nasty one on the surface streets, too. Bad night apparently.
Sent from my GS4.
The Following User Says Thank You to Ninjin For This Useful Post:
SpyderMS (09-05-2013)
Old 09-05-2013, 04:06 AM   #15522
Ninjin
Ninjin's Avatar
Drives: SWP BRZ 6MT
I shoukd have some dyno data on the JDL header soonish.
I really like their design and craftsmanship. Plus they can help you out with the CEL/o2 codes issue. They installed a sensor bung behind the high-flow cat in my front pipe (also made by JDL). Now the secondary o2 sensor is relocated behind the front pipe cat. The header is catless and the ecu is still happy. No CELs at all! Really the car should have this configuration stock.
Sent from my GS4.
The Following 2 Users Say Thank You to Ninjin For This Useful Post:
chrisbfrs (09-05-2013), Cross (09-05-2013)
Old 09-05-2013, 08:57 AM   #15523
Pscylo
Pscylo's Avatar
Drives: Raven FR-S
Everytime I check in on this post, there are a bunch of new names I don't recognize.
Hi new guys/gals~
And when the hell is someone going to do a midnight cookout for those of us who are nocturnal?
Also back on topic, what is the best way to dump the CEL of swapping to a catless header?
Pscylo is offline   Reply With Quote
The Following 4 Users Say Thank You to Pscylo For This Useful Post:
chrisbfrs (09-05-2013), jeffsides (09-05-2013), redsuns03 (09-05-2013), Yruyur (09-05-2013)
Old 09-05-2013, 10:45 AM   #15524
Cross
It's the Mad Cow
Cross's Avatar
Sent from my GS4.
Ok so it sounds like they are using the Spark Plug Anti Fouler trick then, I thought it might work but I wasn't sure.
Thanks Ninjin I will look forward to your results
Old 09-05-2013, 11:16 AM   #15525
Yruyur
Yruyur's Avatar
Thats strange
Old 09-05-2013, 11:36 AM   #15526
FR-Shadow
FR-Shadow's Avatar
Drives: 2013 Scion FRS
Thats strange
Are you in a different country?
FR-Shadow is offline   Reply With Quote
