Old 09-04-2013, 11:17 AM   #155
CSG Mike
CSG Mike's Avatar
Originally Posted by OICU812 View Post
Ok fair enough and understood, example looking for advice on is:
FR-S
1-1.25" drop tops to retain stroke and function
Rear 18x9.5" - 255/35/18 Michelin Pilot Sport A/S
Front 18x8.5" - 225/40/18 Michelin Pilot Sport A/S
Suspension: KWV3 with Vorshlagg front plates and Rear Stance LCA (have read and noted that Vorshlagg plates add a degree of caster.) not sure what stock is and how much the vorshlagg affect goals on front camber etc?
Goal driving: DD/ Street & Spirited /5% autocross
Guess: -2 degrees camber in rear with zero toe
Guess: -.5 degrees camber in front with zero toe
How would that work or any advice based on that setup?
Lastly if it were 18x9.5" and 255/35/18 tires all way around what would you then reccomend given all other data same?
The front camber is very easy to adjust, so align to taste for DD duty. When you get to the AutoX, increase your front camber via the camber plates. Be sure to note your "before" spots. This'll temporarily give you more camber for the AutoX in the front, giving you additional front grip (and preventing excessive outer edge wear). At the end of the day, put the camber plates back to where they were for street duty.
Voila, (almost) the best of both worlds.
Old 09-04-2013, 12:31 PM   #156
Wepeel
Drives: '13 BRZ Ltd
How much does the toe change on this car when you do this? I know on my GR STI, adding 1-1.5 degrees of negative camber via plates would result in drastic toe changes - way more than you'd want (3-4 mm per side).
Wepeel is offline   Reply With Quote
Old 09-04-2013, 12:32 PM   #157
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Ok I know as stock front is zero camber is that really best for wear even spirited driving steady? Common sense leads me to believe not so and then as DD a guy should consider even half a degree to full degree of negative camber up front agree or no?
Old 09-04-2013, 12:48 PM   #158
CSG Mike
CSG Mike's Avatar
That's a question I can't answer... yet.
Time to pull out the toe plates and tape measures :p
Old 09-04-2013, 12:49 PM   #159
CSG Mike
CSG Mike's Avatar
I'd run at least half a degree negative in the front, even for DD.
OICU812 (09-04-2013)
Old 09-04-2013, 02:02 PM   #160
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Toe (and combination of toe with camber) is the primary cause of excessive tire wear, not camber by itself...
-alex
Old 09-04-2013, 04:34 PM   #161
Jenson May
Drives: Evo
It's the same picture they use... I'd like to see application specific. I've never seen substantiated results from FA.
They've claimed SCCA/NASA wins, but when that win is from being the only car in class and/or from just showing up to the most events, I don't buy it.
This is just not accurate. I am not trying to ruin a great thread you have going here, however I would like to respectfully correct this statement.
Just in the last few months there have been numerous NASA, NARRA and One Lap wins with full fields (not just default wins).
Jenson May is offline   Reply With Quote
Old 09-04-2013, 05:21 PM   #162
CSG Mike
CSG Mike's Avatar
I'd love to see results on a more grassroots level car without an extreme level of prep...
Congrats on landing the defending LSB Limited AWD team
Old 09-04-2013, 10:48 PM   #163
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
So 0 toe all around with more negative camber up front than rear is the general idea?
My thoughts would be that -1.5 neg front and -1.0/-.5 neg rear zero Toe all around with rce yellows spc camber bolts and rear LCA or bushings to adjust rear camber.
225/45 17 sport maxx rt 17x7.5 et44 wheels
Spirited plus autoX
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 09-04-2013, 11:17 PM   #164
ZDan
ZDan's Avatar
Drives: '23 BRZ
Agree to disagree.
I do not agree to disagree! It's not a question of differing opinions, one of us must be wrong! Either offset/scrub radius affects leverage/motion ratios or it does not.
So thanks for making me actually *think* about it a bit
Yer right, changing lateral location of the wheel/tire only increases the lateral loads in the LCA and at the top of the strut, but the leverage/motion ratio between spring and tire is not affected.
Wepeel (09-05-2013)
Old 09-05-2013, 12:43 AM   #165
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Decreased offset/increased scrub radius DOES increase leverage.
There can only be one!
The Following User Says Thank You to solidONE For This Useful Post:
CSG Mike (09-05-2013)
Old 09-05-2013, 01:09 AM   #166
Dimman
Kuruma Otaku
Dimman's Avatar
I've been using this:
Because titanium.
The Following User Says Thank You to Dimman For This Useful Post:
solidONE (09-05-2013)
Old 09-05-2013, 01:15 AM   #167
solidONE
solidONE's Avatar
I need that book.
Old 09-05-2013, 01:22 AM   #168
Dimman
Kuruma Otaku
Dimman's Avatar
I need that book.
'Competition Car Suspension' by Allan Staniforth.
Target audience seems to be British hill climb racers who build their own open wheel cars.
Because England???
Because titanium.
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
