Old 09-04-2013, 10:47 AM   #15
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
I could sure use more torque
LeeMaster is offline   Reply With Quote
Old 09-04-2013, 12:09 PM   #16
Dimman
Kuruma Otaku
Dimman's Avatar
DI. I didn't think the FB25 had DI.
Also flow. But depending on what's causing the top-end choke on the FA20, could just end up with same power at ~80% the revs.
Problem with DI on the FB25 is no fancy piston domes.
However, the 2GRFSE with D4-S is coincidentally also 94mm diameter. Anyone want to compare pistons now?
Because titanium.
Old 09-04-2013, 12:16 PM   #17
InvalidJohnny5
The Based God
InvalidJohnny5's Avatar
Drives: 87 Supra, 92 240SX, 13 BRZ Turbo
This is interesting, it this is cost effective I might consider this swap should my engine take an unfortunate blow.
Milltek Full Exhaust (Overpipe, Cat-delete, Catback), AVO Turbo kit , Perrin Crank Pulley , ACT Clutch Kit , ACT Prolite Flywheel 10.5lb , Axel-Exchange Driveshaft, Sparco Assetto Gara 17x7.5, Hankook Ventus V2s 225/45/17, Michelin Pilot Super Sports 225/45/17, Rally Armor Mudflaps, Viscontiproof tune Courtesy of Drift Office LLC
InvalidJohnny5 is offline   Reply With Quote
Old 09-04-2013, 12:18 PM   #18
OrbitalEllipses
Drives: Attitude
It won't be. You're going to need a bellhousing adapter of some kind for the Aisin trans.
Old 09-04-2013, 12:32 PM   #19
Kostamojen
Damn, if not for the stupid starter this would work perfectly
Old 09-04-2013, 12:50 PM   #20
InvalidJohnny5
The Based God
Meh, better off getting an STI EJ. If I'm doing fab work and still keeping a boxer.
Old 09-04-2013, 12:56 PM   #21
OrbitalEllipses
Drives: Attitude
:-/ IKR? I dream of a Frankenstein FA25 with the right trans.
Old 09-04-2013, 01:55 PM   #22
Anaxilus
Drives: They have four wheels
Let's get Cosworth to make a FA25 and offer a group buy.
Anaxilus is offline   Reply With Quote
Old 09-04-2013, 02:10 PM   #23
Calum
That Guy
Drives: 2013 asphalt FRS MT
For an extra $5000 more then 3MI will charge?
Old 09-04-2013, 04:29 PM   #24
jet86
Mad Sciontist
jet86's Avatar
Drives: gt86
The main reason for the swap would obviously be the extra torque and power of having another 500cc to play with.
I've also looked at the fact of putting the fb25 crank in the fa20 block for an extra 4mm stroke to get just about 2.1L. The bore centers look to be the same as do the cranks.
Just some food for thought
Sent from my GT-I9505 using Tapatalk 4
jet86 is offline   Reply With Quote
The Following User Says Thank You to jet86 For This Useful Post:
Calum (09-04-2013)
Old 09-04-2013, 04:33 PM   #25
OrbitalEllipses
Drives: Attitude
3MI He's actually semi-local to me. Super busy with a billion other projects though.
Old 09-04-2013, 04:43 PM   #26
Anaxilus
What's a 3MI? The people that make scotch tape? Or the people that don't seem to be able to make a functional website that apparently sells nothing?
http://3miracing.com/
If you have something useful to prove their track record and expertise matches that of Cosworth feel free to share. That's a pretty tall order btw. I'm sure I could pay a blind monkey peanuts to bore my cylinders compared to whatever 3MI does too so cheap ain't gonna sell me. Seems like they missed a finishing step on that piston they display on homepage. Should look like this:
Old 09-04-2013, 04:45 PM   #27
OrbitalEllipses
Drives: Attitude
If you have something useful to prove their track record and expertise matches that of Cosworth feel free to share. I'm sure I could pay a blind monkey peanuts to bore my cylinders compared to whatever 3MI does too so cheap ain't gonna sell me.
Go to NASIOC, search longrod destroker.
Old 09-04-2013, 04:56 PM   #28
Calum
That Guy
Micah talked about it several times about a year ago, he still pops in once in a while and drops hints. Just one of the many things I'm waiting to see come to market before I decide which route I'm gonna take for more power.
Early proposal: FA20 with a FB25 shortblock, .5l more displacement anyone? Kostamojen Engine, Exhaust, Transmission 90 03-20-2022 06:05 PM
WTB: short block or long block DOTman05 Engine, Exhaust, Bolt-Ons 2 07-14-2013 06:48 AM
conversion fa20 head with fb25T block ft86-UAE Engine, Exhaust, Transmission 3 06-18-2012 10:46 AM
Would you guys prefer FB20 or FB25 for NA FT? tranzformer Engine, Exhaust, Transmission 89 07-20-2011 04:00 PM
