#1373 |
Drives: 2013 Black FR-S
Subtract atmospheric pressure from 1.6 BAR. For me it is -1.0 since I am at sea level.
#1374 |
Updated to reflect PSI, also to note these are 3rd gear pulls:
![]() Interesting to note: 4.2psi at 3k 5.2psi at 4k
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread) ![]() |
#1375 |
Does anyone have experience with datalogging Torque Actual (Nm) in ECUTEK?
Like: How reliable/accurate is it? How is it calculated? How does it translate to Wheel Tq?
#1376 |
My FR-S has 5 gears
Drives: FRS/280z/Tundra
Tomorrows the day I hear @FA20Club.com
Omar GC
2JZ - 6870 - stock block - 1000whp? Instagram: 2jzus |
#1377 |
Sorry one more, probably a better sample of a single pull to give you an idea. As noted same as above 93 octane with a 3rd gear pull (ambient 84F):
#1378 |
Drives: FA20Club.com
one day at a time
#1379 |
Road Warrior
Drives: Toyota 86 Satin Pearl White
HI,
Need some advice. We are about to receive the new Intercooled version in South Africa, which supercharging is new for us here on the 86. The kit I am told will come with 2.5 bar map and harness, with 75mm pulley, indicating 12psi. On the Tuning side I'm in discussion with Andy from FA20Club, must make quick note that they are extremely helpfull and give super fast response, something I have not had from my current tuner and hence will join the FA20Club soon. So my question is, based on what you guys have learnt on the Non IC version, would the Intercooled version at 12psi, require injectors or a fuel pump replacement??? or anything else I may need to consider with this kit. We are on equivalent to your 91Oct here in SA, with access to Octance Booster to get up to near your 93Oct. Appreciate your assistance. PS: Andy not going over your head here just gathering as much info as possible, very big decision as the kit will be around $6000 for us installed with tune. Thanks |
#1380 | |
Starts to loose a little boost on the high end. Quickly approaching the flow limitations it seems, at least with that pulley. |
#1381 |
Grip>Slip
#1382 | |
Grip>Slip
| The Following User Says Thank You to xjohnx For This Useful Post: | chadstyle (09-04-2013) |
#1383 | |
Drives: 2013 Subaru BR-Z Limited
| The Following User Says Thank You to chadstyle For This Useful Post: | xjohnx (09-04-2013) |
#1384 |
Grip>Slip
#1385 |
Lol I was going to bring a chisel and stone instead
#1386 |
Thanks
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
