Old 07-22-2011, 10:16 PM   #295
Random_Art
professional smartass
Random_Art's Avatar
Drives: 16 speed mountain bike...
That's awesome! thanks!
Goodbye Celica, you served me well.
http://artsofrandomness.blogspot.com/
Random_Art is offline   Reply With Quote
Old 07-22-2011, 11:11 PM   #296
MiguelAE86
Drives: NB Miata
Wow great work!
I dont want to sound like a fanboy or anything, but could someone, just for nostalgia's sake, do these above renderings in a Panda paintjob in white? perhaps also red?
ps: with black wheels ofcourse!
MiguelAE86 is offline   Reply With Quote
Old 07-22-2011, 11:54 PM   #297
Kage
Drives: 2000 Celica Gts
Send a message via AIM to Kage
Is it weird that I actually love the spoiler...kinda excited to get one with that huge spoiler
Originally Posted by Zaku View Post
I care first and foremost about what my needs are in the car and not to get "Props" from people. I'm not ricing it out for attention, I'm not flushing it to join a culture, I'm not keeping it stock for resale. I'm making this car for me and me only. And if you're my friend and club members that know me they'll respect that and respect is much better than props.
Kage is offline   Reply With Quote
Old 07-23-2011, 05:42 AM   #298
Sea1monkey2
Sea1monkey2's Avatar
Drives: 2003 Impala
This was fun, this car is limitless
Sea1monkey2 is offline   Reply With Quote
Old 07-23-2011, 08:36 AM   #299
lancie
lancie's Avatar
Drives: brz wrb
a color like this tvr??
lancie is offline   Reply With Quote
Old 07-23-2011, 11:34 AM   #300
Sea1monkey2
Drives: 2003 Impala
If you say so
Old 07-23-2011, 12:03 PM   #301
lancie
lancie's Avatar
Drives: brz wrb
minchia*
(*wow!!)
for me best colours are white,black ad blue...
Old 07-23-2011, 11:15 PM   #302
MiguelAE86
Drives: NB Miata
THANK YOU THANK YOU THANK YOU! I know what my FRS will look like in the near future! custom paintjob here i come! (Or vinil job too! much cheaper )
Old 07-24-2011, 03:15 AM   #303
ryun84
ryun84's Avatar
Drives: 04 PSM WRX Wagon
I was thinking about partial-vinyl jobs as well, but then I started wondering how it would affect the paint in the long run. I would assume that if you leave it on the car for a long time, the elements (especially the sun) would wear the exposed areas of paint so that IF you decide to remove the vinyl stripes, those previously covered areas would probably look noticeably different. Anyone with any experience with vinyl-wrapped cars? I think wrapping the entire car would fix any uneven weathering issues, but does the adhesive affect paint as well?
ryun84 is offline   Reply With Quote
Old 07-24-2011, 04:39 AM   #304
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
Drives: Swagtron Scooter
I haven't had a wrapped car for more than 2 years, so i couldn't tell you the long term affects of partially wrapped cars that has two different exposure surfaces. But if your worried about the paint underneath the wrap don't worry about it. its nearly completely protected and there are no other adhesive properties other than the non-slip backing of the vinyl. My biggest concern with vinyl is exposure to direct heat. Engine bays are the worst places to wrap and from my experience they don't last more than several months, and places where high heat sun can beat on the car for weeks without a break.The corners start to warp and air can start to undo the finish.
WingsofWar is offline   Reply With Quote
Old 07-24-2011, 10:01 AM   #305
Random_Art
Random_Art's Avatar
Yep, I used to work at a sign shop. So, I was dealing with vinyl on vehicles all the time. I can tell you, if the vinyl is properly applied and removed months or years later, the paint under the vinyl will be in better condition than the paint that was exposed to the elements the whole time. However, the thing with vinyl is that it dries out, shrinks, and cracks over time. Which is why the vinyl comes in different year ratings (3 year, 6 year, etc) and the higher the year rating, the more expensive it gets.
Old 07-24-2011, 03:13 PM   #306
MiguelAE86
Drives: NB Miata
Well, I was more or less talking about say, getting the car originally White or Red (as seen in the Panda Pictures) and then JUST doing the Black stripes (what makes it trully a panda job) or is that bad since the part where the stripes will be, look different later? or is it better to just do a Vinyl job of ALL white/red and then on TOP of that all that vinyl, put on the stripes?
Old 07-24-2011, 03:54 PM   #307
Sea1monkey2
Drives: 2003 Impala
So you're saying you want to cover the car in a single solid color vinyl... and then put a vinyl design on top of the other vinyl...
Yeah, no
I honestly love the panda look, i'm thinking of getting the magnetic gray metallic with the black panda bottom, all in paint. Because if i can start with a factory color and only add trim paint... why not?
Old 07-24-2011, 04:05 PM   #308
Random_Art
Random_Art's Avatar
I would get a red or white car and put the vinyl on it, just make sure you get the longest lasting vinyl you can. And get it professionally installed, it's easy to mess up and/or damage the paint job on the car if you don't know what you're doing.
Ideally, you would do it with paint so you don't have to worry about the vinyl cracking. But, if you were going to wrap the whole car in vinyl, I would probably coat the whole car in one color, then put the secondary vinyl over it. Other wise you have a few scenarios with an all vinyl job:
1: you butt the edges of the vinyl together so that they don't overlap. This leaves a crack that will widen over time as the vinyl shrinks and collect grime.
2: you overlap the vinyl a bit to remove the gap. This leaves a slightly raised ridge along the border that will be glaringly obvious and not look as good.
3: you Wrap the whole car in the color of your choice, but still have to run into the problems in scenario 1 and 2 since most single color vinyl maxes out at a 4-6 foot width. then you place the secondary color over the primary vinyl you don't have the problems in Scenarios 1 & 2 between the primary and secondary.
When you see a vehicle wrapped in an advertising vinyl, the seams aren't as noticeable due to the rest of the obnoxious graphics that cover it.
Unmasking the FR-S / BRZ / FT-86 Mule WingsofWar FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 522 03-19-2014 09:52 AM
Another BRZ Test Mule? Turbo? Harinjo BRZ Photos, Videos, Wallpapers, Gallery Forum 31 12-07-2011 08:49 PM
FR-S mule v. BRZ mule Rampant BRZ Photos, Videos, Wallpapers, Gallery Forum 46 10-27-2011 06:27 AM
Video of mule driving around. pe3nut FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 8 02-15-2010 06:06 PM
