Old 09-03-2013, 04:32 PM   #1
tackybrz
Drives: WRB BRZ Limited
Rolling Fenders
Was wondering if anyone rolled the rear of their brz/frs? I've heard that rolling the rears aren't possible due to the fenders creasing when rolled? Please help. Thank you.
tackybrz is offline   Reply With Quote
Old 09-03-2013, 04:47 PM   #2
TNPerformance
Drives: 2013 Hot Lava FRS/97 Supra/93 Supra
Not much there to roll. The fronts are rolled flat already and the rears have the smallest lip I think I've seen haha. What size tires are you trying to run?
TNPerformance is offline   Reply With Quote
Old 09-03-2013, 05:22 PM   #3
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
Rolled mine. It can be done. Not much of a lip though so you dont get a lot of extra clearance just by rolling. By adding a tiny amount of flare/pull though, you can gain some decent clearance.
Just start in the middle and work your way out
Old 09-03-2013, 08:24 PM   #4
tackybrz
Okay. Awesome. Thank you!
Old 09-03-2013, 08:25 PM   #5
tackybrz
225/40/18 on 18x9.5 +25
Old 09-04-2013, 06:49 AM   #6
TNPerformance
Ok I gotcha. Have you test fitted them yet? Reason I ask is because I run an 18x9.5 et38 (so yours will stick out a half inch further) but I run a 255 wide tire no problem. Especially in the rear. I could see you having a little problem in the front, but with the tire you are wanting to run maybe not. Like I said the front are flat already so you'd have to pull a little bit if the camber didnt get you where you wanted. Again, I think the rear is possible with no fender mods (just camber) but only a test fit will know, which is why I had asked if you had tried yet. Didn't know if you already had the wheels/tires or if those are what you were looking at getting.
Old 09-04-2013, 08:33 AM   #7
chadstyle
chadstyle's Avatar
Drives: 2013 Subaru BR-Z Limited
Get yourself a wooden bat and a fat friend...
chadstyle is offline   Reply With Quote
The Following 2 Users Say Thank You to chadstyle For This Useful Post:
8R6 (04-15-2015), mkiisupra (02-26-2014)
Old 09-04-2013, 09:36 AM   #8
tackybrz
Thank you for your help. Yeah the wheels have been ordered. I know people were fitting 9.5 +38 with 265 so I figured I could get away with a +25 on a 225/40 tires. I'll just pull the fronts a little then and run more camber in the rear. Good thing I ordered adjustable LCA. Thank you kind sir for your help.
Old 09-04-2013, 09:44 AM   #9
Acree
Acree's Avatar
Drives: 13 CSB BRZ Ltd
Please please please don't stretch a 225 on a 9.5" wheel. Function > form.
2011 BMW M3 (No torque dip)
2013 Subaru BRZ - SOLD - Build Thread
Acree is offline   Reply With Quote
The Following 7 Users Say Thank You to Acree For This Useful Post:
chadstyle (09-04-2013), Jive Turkey (09-04-2013), MisterSheep (04-26-2016), mkiisupra (02-26-2014), Shinryu (09-04-2013), SkAsphalt (02-26-2014), wparsons (02-26-2014)
Old 09-04-2013, 12:09 PM   #10
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
i rolled mine. its a joke as to how easy it was. you dont NEED to do it but i jsut wanted to never have issues. better to nip it before you run into troubles.
the other key thing is to roll the flare by the side markers in the front. the front is rolled flat but then flares out, those that want to run meaty tires, you will rub on that under hard turn in...ask me how i know.
fyi i'm running 18x9.5 +40 265/35 all around.
Jive Turkey is offline   Reply With Quote
The Following 3 Users Say Thank You to Jive Turkey For This Useful Post:
HATED1 (04-15-2015), kevaughan (10-19-2020), NABoxer (04-25-2016)
Old 09-04-2013, 03:07 PM   #11
tackybrz
I hear you. This is just temporary. I will eventually switch to a meaty stance once I get back from deployment. I had spare 225/40 laying around that have never been used.
Old 09-04-2013, 03:11 PM   #12
tackybrz
Thanks for the info Jive. I've been following your build before I bought the brz. I love the way your brz looks. I don't think id br able to fit a 265/35 on 18x9.5 +25 wheels. Maybe a 255?
Like I stated. This is just temporary. I'll eventually switch to a meatier setup.
Old 09-04-2013, 03:23 PM   #13
Jive Turkey
the tuna, no crust.
i mean you can fit anyhting you want with camber
whats the reason you are going with such a, for lack of a better term, useless offset?
The Following User Says Thank You to Jive Turkey For This Useful Post:
Old 09-04-2013, 06:08 PM   #14
tackybrz
I originally wanted the form > function look.
feeler CA: trade seibon CF fenders for stock red fenders Alliedforces86 Exterior Parts (Aero, Lighting, Etc.) 11 08-08-2013 01:03 PM
Tire rolling over Big-B Tracking / Autocross / HPDE / Drifting 46 08-05-2013 03:54 PM
fender rolling Andybui82 Northwest 0 03-30-2013 10:44 PM
Cf fenders Minovsky Cosmetic Modification (Interior/Exterior/Lighting) 16 03-11-2013 09:34 AM
Windows not automatically rolling up mickey177 Issues | Warranty | Recalls / TSB 1 01-18-2013 11:34 AM
