Old 06-11-2013, 01:10 AM   #309
Gixxersixxerman
Gixxersixxerman's Avatar
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
Originally Posted by Honeydew View Post
DO you guys know if there is anything we can use to prevent it from rusting?
Maybe having it ceramic coated and a good polish/protector might help.. But metal rusts under the use of salt.. Stainless steel still rusts, unless its the very very expensive type.. Even then I hear it will rust.. There are some people that understand and know all this on here as I've seen them debate the subject.. Hell I've been to the St. Louis arch and seen rust on that and it's suppose to be pure stainless and the best, at least they make it out to be
Gixxersixxerman is offline   Reply With Quote
Old 06-11-2013, 01:37 AM   #310
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
I used VHT Exhaust Manifold paint on mine, should help combat rust a lot more than without. It will eventually rust seeing as how the damn exhaust tip is faced at an angle where if you spray water it will seem to get stuck inside of the exhast.
LeeMaster is offline   Reply With Quote
Old 06-11-2013, 03:14 AM   #311
Minovsky
Minovsky's Avatar
Drives: Fr-s 2013 white out
The only down side To me for the Eco is that it's those single layered tips. Wish it was like the nameless on the double walled ones.. Just looks abit better.. I guess if it does rust you can get it polished off? Haha Ohwell
Minovsky is offline   Reply With Quote
Old 07-02-2013, 02:28 PM   #312
FRS_Ken
((•||=(86)=||•))
FRS_Ken's Avatar
Drives: '13 FR-S Ultramarine 6AT; '13 Yaris
My EVO3 didn't come with any silencers/baffles
I love the sound of it without them, to me it sounds like a much bigger engine (like a V8 ) sitting in the driver's seat anyway
I swapped out the stock one for the EVO3 with about 200km (120mi) on the dial, so I can't say I really heard the stock except at idle and sub-60mph speeds - still was breaking it in.
My car will never see salty roads (while I own it) since it will go into storage in Nov and awaken in April after the rains wash the salt off the roads.
FRS_Ken is offline   Reply With Quote
Old 09-03-2013, 12:58 AM   #313
GOT FR-S
Drives: 2013 Scion FR-S (Firestorm)
Odd. They come pre installed and bolted in. you have to remove them. They are not seperate in the box.
Vortech SC. Rev Work Header, Perrin over pipe, Invidia resonated top pipe, Greddy EVO3 exhaust, Perrin Light weight crank pulley, Gofast bits lightweight waterpump & alternator pulleys, Perrin Trans & Shifter mount, MTec Shift springs. Cusco rear diff brace, 1pc Alum Drive Shaft (Drive Shaft Shop), ATC performance clutch & Flywheel, Whiteline Positive traction bushings. Grimspeed hood struts. EcuTek Tune.
GOT FR-S is offline   Reply With Quote
Old 09-03-2013, 02:46 AM   #314
Gixxersixxerman
I was installing my coil overs a little bit ago and noticed small rust dots all over.. I blued the hell out of the piping from the track, even melted the right rear cut out a little bit.. I'm going to do a complete detail and plan on hitting it with some polish and protectant when I detail.. Let y'all know what happens afterwards..
For the record, I live In The desert.. Was the high desert of SoCal, now Vegas.. There is not much rain and the car has only seen a brief shower that lasted maybe two-three miles.. Otherwise, she's never seen the rain
Old 10-25-2013, 02:13 AM   #315
FRS_Jack
Duel Canister 2X the Fun
FRS_Jack's Avatar
Drives: 2013 scion frs
Hey guys, i might actually go to a shop and cut the silencer pipe and well in some bigger pipe of more sound maybe less drone....
FRS_Jack is offline   Reply With Quote
Old 11-18-2013, 06:32 PM   #316
rhythmM
rhythmM's Avatar
Drives: 2014 Subaru BRZ Limited MT - White
Super stoked! I just ordered mines last friday, Hopefully the drone isnt so "droney" to me. What are some things you guys have all done to help alleviate to drone?
rhythmM is offline   Reply With Quote
Old 11-18-2013, 07:03 PM   #317
Foobar
SLO NO MO
Foobar's Avatar
Either deal with it or switch to another system. To my knowledge, nobody has altered the system to reduce drone. You could possibly get another resonator fabricated and put in somewhere but at that point you have to wonder if it's worth the effort and cost.
Some folks aren't bothered by the drone at all, the rest of us had to move on to other options.
YMMV
Old 02-08-2014, 05:45 PM   #318
TRD_86
Drives: 2013 86 white
Originally Posted by tokiokun717 View Post
You need an Alan and 8mm wrench. I don't know if it's just me but those screws are a pain to take out because of the lock nut... I already broke 2 of them on each side so I replaced them with normal nuts. they seem to be working fine
^ sound like a pain, but will try to remove silencer and replace w/ different screws nuts for easy access.
TRD_86 is offline   Reply With Quote
Old 02-14-2014, 05:59 AM   #319
TRD_86
Exhaust is little too loud for me w/o silencer. I really like the sound of the silencer on at the moment. I'm thinking of modify the silencer to make it sound little louder by either cutting the silencer tip shorter or drill few perforated holes into the silencer tube that would make the exhaust louder w/ silencer on.
Old 02-26-2014, 06:03 PM   #320
DeLaRage
Drives: 2013 Raven FRS
Just got my greddy evo 3 in the mail today. I don't think it came with silencers. Granted I was planning on taking them out. But I was hoping to have them so that I could put them in for long drives
DeLaRage is offline   Reply With Quote
Old 02-26-2014, 06:07 PM   #321
AZFA20
Automotive Connoisseur
AZFA20's Avatar
Drives: too many cars
You will know if you got em. The EVO 3 comes with them already installed in the mufflers and instead of 4" openings you will have little guys.
LSx Powered 86/ASE Master Certified Automotive Technician
AZFA20 is offline   Reply With Quote
Old 02-26-2014, 06:09 PM   #322
DeLaRage
I already opened it. And it had the 4" installed. Nothing inside of them or anything.
Greddy Evo 3 exhaust pre-order! No Limit Motorsport Engine, Exhaust, Bolt-Ons 132 10-17-2012 10:30 AM
Magnaflow or Greddy Exhaust 86 FRS Southern California 3 09-13-2012 07:30 PM
Greddy SP Elite Exhaust Willsonk Engine, Exhaust, Transmission 67 09-03-2012 11:19 PM
Greddy SP Elite Exhaust Willsonk Engine, Exhaust, Transmission 5 08-02-2012 02:18 PM
greddy exhaust jdmboss86 Engine, Exhaust, Transmission 15 06-17-2012 02:38 AM
