Old 07-21-2013, 06:31 PM   #85
slava
slava's Avatar
Drives: brZed
I dunno. Didn't on mine. Used XP, did everything the same way and it worked fine.
Just glad I got seat belt noise off. Great tool!
slava is offline   Reply With Quote
Old 07-21-2013, 06:39 PM   #86
Yruyur
Yruyur's Avatar
7 for me too works. Glad you got it working.
Sent from a Motorola DynaTAC 8000X
Old 07-21-2013, 07:39 PM   #87
garfull
garfull's Avatar
Drives: FRS(sold), AP2, R35, FJC, ED9
Works on both xp and win7 but it must be 32 bit.
Originally Posted by Chaetagnath View Post
Is your windows 7 32 bit or 64 bit?
garfull is offline   Reply With Quote
Old 07-24-2013, 04:41 PM   #88
RyanOver9000
RyanOver9000's Avatar
Drives: Scion FR-S/Whiteout/AT
Have you guys tried running the installer in compatibility mode for Windows XP Service Pack 3?
RyanOver9000 is offline   Reply With Quote
Old 09-02-2013, 02:30 PM   #89
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Works great, thanks for all the DIY advice!
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 09-02-2013, 02:47 PM   #90
lexusb3
Drives: FRS
THIS is pretty cool i want to buy it just to change a few little things
lexusb3 is offline   Reply With Quote
Old 09-02-2013, 04:06 PM   #91
tonystewart
Shutting off the buzzer/warning from the passenger seat belt was worth it. Data Logging in peace.Yes
The Following User Says Thank You to tonystewart For This Useful Post:
D K (07-16-2014)
Old 09-02-2013, 04:35 PM   #92
Nightbringer
Nightbringer's Avatar
Drives: Scion FR-S
It worked fine for me on Windows7, but if you're running into issues, no need to install XP. Just run the program in compatibility mode and make sure it's installed as 32 bit. Should work fine.
Agreed Tony. Was worth the money just to shut off the passenger seatbelt buzzer haha
Nightbringer is offline   Reply With Quote
Old 09-02-2013, 10:15 PM   #93
Rumbaar
Victim's aren't we all
Rumbaar's Avatar
Drives: Toyota GTS 86 - Pegasus White
Can you turn off the auto window drop on car door open feature via these settings? Australian GTS 86 model.
Rumbaar is offline   Reply With Quote
Old 09-02-2013, 11:02 PM   #94
Yruyur
Yruyur's Avatar
Do you mean the window coming down an inch when you open it? I dont believe the setting for any window options are there. Not even sure you can open the door without the drop.
Old 09-02-2013, 11:33 PM   #95
Rumbaar
Rumbaar's Avatar
Yes, that's the option. Just preparing for tinting and see how much I can limit the movement when it's setting.
Oh well, look for other options.
Old 09-02-2013, 11:54 PM   #96
37
degrees
37's Avatar
Drives: 6MT BRZ
Disconnect the battery before opening the door and the window won't drop. Either that or pull the window fuse.
37 is offline   Reply With Quote
The Following 2 Users Say Thank You to 37 For This Useful Post:
Rumbaar (09-03-2013), Yruyur (09-03-2013)
Old 09-03-2013, 04:10 AM   #97
Freude am Fahren
Drives: '13 DGM BRZ Limited/'14 Yamaha R6
There's also the button that activates it on the back of the door jam. You can tape that down or something.
-XXR 527 18x8.75 +35
-Nameless 2.5" OP/FP Combo (Coming soon) & Axleback
-SBD 500X (Waiting on coating to install)
-Southbend SBD500X Clutch
Freude am Fahren is offline   Reply With Quote
Old 09-03-2013, 08:05 AM   #98
xxscaxx
Drives: 2013 SWP BRZ
^ you just unbolt the sensor on the inside of the cars door frame. Thats what my tint guy did.
xxscaxx is offline   Reply With Quote
Toyota Techstream xjohnx Engine, Exhaust, Transmission 206 08-20-2023 04:01 PM
TechStream TIS - No work FRSFirestorm Engine, Exhaust, Transmission 19 07-10-2014 03:14 AM
Techstream/ECU customizations phanguy Northern California 60 10-05-2013 11:12 PM
Techstream ECU Options mrjester Electronics | Audio | NAV | Infotainment 10 03-18-2013 10:24 AM
86 TRD Customize Concept JDMrolla Scion FR-S / Toyota 86 GT86 General Forum 6 01-11-2013 12:31 PM
