#169 | ||
- Andy |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | ultra (09-02-2013) |
#170 |
Drives: Scion FRS (Asphalt)
How do you feel about fortune auto V4 500? ft86speedfactory was doing some testing with them with 8k/7k. But I have not heard anything else about them.
The reason I ask is, the 500 was the only one I found that had height/dampener/and camber......and cheap. |
#171 |
Drives: really slow...
you are bringing a knife to a gunfight here...
#172 |
Drives: 2013 BRZ Limited
CSG and/or RCE---
Do you see the need for a different 'race' suspension for autocross v. track? |
#173 |
Curious cat.
Drives: 86 GT base M/T - Red
Good question. No doubt the ideal setup for each application would differ somewhat but I'm also curious to know if there's any general rules-of-thumb in terms of suspension setup that might be unique to AutoX versus circuit driving.
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold) 1991 Mazda MX5 Miata (sold) 2007 Mitsubishi Evo 9 RS (sold) 2006 VW Golf R32 (sold) |
#174 |
#175 | |
i'm sorry, what?
Drives: Canada
high spring rates are viable... for high spring rate applications the matter of compatability between track and street will also depend on the conditions of your tracks and the conditions of your streets some places have smooth tracks and smooth streets... or bad tracks and bad streets, in which case a specific spring+damper combo may "seem" like the "best fit" but when you're dealing with shitty streets and smooth tracks, you will always compromise.
#176 |
Drives: FR-S Whiteout
There is always compromising going on with suspension setup. If you want high rates, you'll have to deal with the rougher ride on the bumpy stuff. If you want a smooth/compliant ride, you'll have to deal with the body roll. You want to spend as little money as possible on dampers? You will probably not have a well matched suspension. You want near perfect damping for your chosen spring rates AND adjustability? Be prepared to spend an arm and a leg. If you want to just get springs and non adjustable dampers that match perfectly, be prepared to spend time testing, learning what you need to change in the damping and getting dampers revalved more than a few times before you get there (according to Koni's webpage expect 3-4 weeks turnaround).
Even if you have money to burn on suspension and have the latest technology you will still be making compromises in setting up your computer controlled, gold plated, diamond encrusted, active suspension developed by alien engineers. It's all about knowing where you are willing to compromise. |
| The Following User Says Thank You to solidONE For This Useful Post: | TTGT (05-01-2014) |
#177 | |
Curious cat.
Yes, I imagine that a very well matched spring and damper combo could potentially work very well for a mixed use application but if that were the case then I'm curious why most manufacturers' offerings, even in the higher end range where JRZs etc. live are all marketing their stuff with relatively soft springs (below 9k). Before anybody says it yes - I'm aware of Penskes, Motons, Nitrons, Proflex etc. All National Championship level competition race shocks and pretty irrelevant to anything remotely 'street', IMHO. Just trying to make some sense of all this info. I know what rates @Mike CSG runs and I don't doubt their expertise but does anybody know what rates @robispec is using on his (rather competent on the track) car, for example?
#178 |
My VTEC fluid is full
Drives: EFF JAY
Setup will be a matter of preference, but can use the same suspension.
At autox I prefer the following corner phases: Entry - loose (fast turn-in) Mid - slightly tight w/ some rotation Exit - neutral For track I prefer: Entry - tight Mid - neutral Exit - neutral I basically want a slower turn in for the track relative to autox setup. |
#179 | |
i'm sorry, what?
Drives: Canada
springs are cheap for these guys, they will put on whatever you want and then adjust the dampers for the springs... that's the easy part. what you're actually paying is the internals and the specific dampening design of this or that manufacturer.
| The Following User Says Thank You to 7thgear For This Useful Post: | whataboutbob (09-03-2013) |
#180 | |
AutoX places a premium on ultra fast load changes and rapid small direction changes, whereas tracking places a premium on static load grip. This is why you see higher spring rates in the fronts for AutoX, as well as the huge front sway bars. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | ultra (09-03-2013) |
#181 |
Drives: EFF JAY
#182 | |
IIRC, the car started with 7k front 6k rear (swapped KW V3 spring rates), although it may have started 6k front 7k rear. Robispec's car has slowly continued to increase in spring rate, and additionally I believe he's been running a mix of different aftermarket swaybars, and occasionally disconnecting them as experiments as well. I just gave a guy with Stance coilovers a ride this morning. He couldn't believe the SRCs were nearly double his spring rates, yet rode smoother. Again, with high spring rates, you're still going to feel the road, but with a high quality damper, it'll be refined, and not rattle your teeth out. Instead, it'll transmit just enough so that you know road isn't smooth. Come visit us in SoCal, and both @robispec and I will be more than happy to give you rides in our cars. Do you consider our Tein SRCs a "National Championship level competition race shocks and pretty irrelevant to anything remotely 'street'"? |
| Mike's CS FR-S build | mikef | Member's Car Journals | 6 | 04-25-2013 09:11 AM |
| Some observations | Nardi330 | AUSTRALIA | 20 | 02-07-2013 06:18 AM |
| 90 Day Anniversary ..some Observations | Scooby South | BRZ First-Gen (2012+) — General Topics | 6 | 09-03-2012 11:17 AM |
| Mike's track videos. | CSG Mike | Tracking / Autocross / HPDE / Drifting | 2 | 08-16-2012 04:00 AM |
| First Payment sent, Observations after 6 weeks. | Scooby South | BRZ First-Gen (2012+) — General Topics | 27 | 08-01-2012 02:02 PM |
