View Poll Results: Have you had an issue with your Direct Injection System?
I have had a DI issue and was fixed under warranty (Subaru) 10 12.35%
I had a DI issue that caused Engine Failure and was fixed under warranty (Subaru) 2 2.47%
I have had a DI issue and was fixed under warranty (Toyota) 31 38.27%
I have had a DI issue that caused Engine Failure and was fixed under warranty (Toyota) 3 3.70%
I have had a DI issue and denied warranty by (Subaru) 7 8.64%
I have had a DI issue and denied warranty by (Toyota) 14 17.28%
I had a DI issue that caused Engine Failure and was Denied warranty (Subaru) 8 9.88%
I had a DI issue that caused Engine Failure and was Denied warranty (Toyota) 6 7.41%
Voters: 81. You may not vote on this poll
Old 08-28-2013, 09:44 PM   #351
thill
Originally Posted by Doborder View Post
Yes it does
Look below the first line
That makes sense now. I was reading as the tech put that in the notes, but looking at it again, it does read more like that was the last update applied.
Muaddib, did you have you car in for any updates/repairs since you bought it?
Old 08-28-2013, 09:59 PM   #352
Muaddib
Mentat
Muaddib's Avatar
Drives: 2013 Scion FRS 6MT
I went there a few times because i had some other unrelated problems. They never gave me any ecu update.
Muaddib is offline   Reply With Quote
Old 08-28-2013, 11:27 PM   #353
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Originally Posted by Mikem53 View Post
No.. A mini-VCI cable.. It's a chipped cable used to interface with techstream.
Look on amazon.. Was around $25 and I have a beater laptop running win 7.
Very useful and informative tool .. Also does OBDII diagnostics.. And sets options like DRL on- off, timers, etc..
I'm assuming these are different from the ELM 327 OBD2 scanners. Can you link the software download or the thread you got it from and the seller you purchased your unit from? Thanks in advance!
Old 08-29-2013, 07:39 AM   #354
Mikem53
Drives: FR-S 6MT
Do a search on this site.. There are threads and links to the software download and for the cable itself. Also info on how to install and use.
Mikem53 is offline   Reply With Quote
Old 08-29-2013, 08:03 AM   #355
regal
Drives: Scion FR-S/Toyota Yaris
USA Customers, take the following steps to receive the updated calibration that should address the DI seal issue:
Step 1: Remove your ECU
Step 2: Place in your oven full Broil for 60 minutes, let cool
Step 3: Reinstall ECU
Step 4: Call your dealer to tow your car and install a new ECU.
Thank you for this slight inconvenience.
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
The Following 3 Users Say Thank You to regal For This Useful Post:
AyJay (08-29-2013), Jive Turkey (09-12-2013), suaveflooder (09-07-2013)
Old 08-29-2013, 08:09 AM   #356
Mikem53
Drives: FR-S 6MT
What makes you think you won't get a new ECU with the same calibration you had to begin with ?
Until they fix the system... That's probably what you would get.
Old 08-29-2013, 08:18 AM   #357
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
= Thread tag, Regalnoia.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
ATL BRZ (08-29-2013)
Old 08-29-2013, 08:19 AM   #358
Skyllz
Drives: Something fun.
Skyllz is offline   Reply With Quote
Old 08-29-2013, 08:20 AM   #359
Mikem53
Drives: FR-S 6MT
Here u go..
http://www.ft86club.com/forums/showthread.php?t=35530
The Following User Says Thank You to Mikem53 For This Useful Post:
solidONE (08-29-2013)
Old 08-29-2013, 09:02 AM   #360
regal
If they haven't built a car with the old ECU in 9 months odds are the old ones are out of their system.
I may wait a little longer or I may just say F- it and toast the ECU
Mods:
Old 08-29-2013, 09:04 AM   #361
ft_sjo
Drives: GT86
You need help. And to think I got an infraction for doubting your abilities.
The Following 2 Users Say Thank You to ft_sjo For This Useful Post:
CSG Mike (08-29-2013), Sportsguy83 (08-29-2013)
Old 08-29-2013, 09:10 AM   #362
Mikem53
Drives: FR-S 6MT
I would apply DC voltage to various connection points on the ECU itself, say 100v or so.. Fry the internals, not the case..
They might have a warehouse or two full of preprogrammed ECU's laying around with old programming ready to be matched up to a certain VIN number range..
It wouldn't surprise me... Good luck with your espionage.. I don't blame you for wanting it corrected.. It's ridiculous how screwed up something fairly simple can be when it comes to large corporations..
AyJay (08-29-2013)
Old 08-31-2013, 03:33 AM   #363
TheRipler
Reap the BReeZe
Drives: 04 LandShark STi
Was driving last night (14,943 miles), and stopped for gas. Left for the highway, and hit a CEL in 3rd. I hadn't reached the highway speed limit of 75mph yet. Took the next exit, and pulled a P0351.
Tonight, I was driving on a 2 lane 75mph road, stuck behind a car behind a pickup/trailer doing 55mph. Downshifted, and passed both only to get another CEL. Pulled the code, and grabbed the freeze frame data.
Only mod to the car is painting the plastic cover on the intake manifold. Ran puregas since getting the car home to keep the crickets away. Local stations switched to E10 this summer, but been going to the station that squeaks least.
Been reading through multiple threads tonight. Is this a sign my DI seals are gone?
Fault log report generated by Torque for Android
Vehicle VIN: *
Vehicle Manufacturer: Subaru
Vehicle Calibration ID: ZA1J700C
Current Fault Log
P0351: Ignition Coil "A" Primary/Secondary Circuit
Pending Fault Log
ECU reports no pending faults
Historic Fault Log
ECU reports no historic faults
Other discovered fault codes
(possibly pending, current or manufacturer specific)
ECU reports no other fault codes logged
End of report.
Freeze frame report generated by Torque for Android
Vehicle VIN: *
Freeze frame information:
Fuel Status = 0 byte
Engine Load = 0 %
Engine Coolant Temperature = 88 °C
Fuel Trim Bank 1 Short Term = 0 %
Fuel Trim Bank 1 Long Term = 7.031 %
Intake Manifold Pressure = 2.466 psi
Engine RPM = 6,465.75 rpm
Speed (OBD) = 150 km/h
Timing Advance = 34 °
Intake Air Temperature = 32 °C
Mass Air Flow Rate = 8.38 g/s
Throttle Position(Manifold) = 17.255 %
Fuel trim bank 1 sensor 2 = 0 %
Run time since engine start = 725 s
Fuel Rail Pressure = 2,043.582 psi
Fuel Level (From Engine ECU) = 88.235 %
Barometric pressure (from vehicle) = 13.924 psi
Voltage (Control Module) = 14.126 V
Engine Load(Absolute) = 6.667 %
Commanded Equivalence Ratio(lambda) = 0.948
Relative Throttle Position = 5.49 %
Ambient air temp = 31 °C
Absolute Throttle Position B = 33.333 %
Accelerator PedalPosition D = 13.333 %
Accelerator PedalPosition E = 12.941 %
End of report.
TheRipler is offline   Reply With Quote
Old 08-31-2013, 03:43 AM   #364
ft_sjo
Drives: GT86
150 km/h is 93mph!
direct injector, engine, failure, meet regal's paranoia, poll, regal's witch hunt, regalnoia, seal, sealions, silly sausage
Injector / seal failure or Miss-fire codes.. please post here mad_sb Engine, Exhaust, Transmission 378 04-24-2020 06:33 PM
Direct Injector Leaking Carwhisperer Issues | Warranty | Recalls / TSB 356 03-13-2020 12:35 PM
Fuel Injector Cleaner Purdue FR-S Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-18-2013 06:54 AM
Wilwood Failure SubieNate Suspension | Chassis | Brakes -- Sponsored by 949 Racing 46 04-09-2013 08:32 PM
Ringland Failure? iLuveKetchup BRZ First-Gen (2012+) — General Topics 9 01-30-2012 12:25 PM
