Old 08-30-2013, 11:38 PM   #1
ZackZ
Drives: '13 Scion FR-S Black 6sp man
Difficult to shift into first when coming to a stop
I find if i am coming to a stop doing about 5 mph or less, clutch in, if i shift into first, the transmission fights me and makes a clanking sound. I dont know why this happens with the clutch in and going that slow it gives me a hard time to shift into first. I feel that i am damaging the transmission. Im not talking about rev matching into first, the clutch is fully in while i try to shift from neutral to first or second to first. If i wait a second after completely stopped it goes in as normal. I had an 03 mini cooper s and never experienced this. It is a lease so should i bring it in to have it looked at or is this normal and i am not aware. Thanks.
ZackZ is offline   Reply With Quote
Old 08-31-2013, 12:30 AM   #2
thebus
Drives: Whiteout
mine does the same thing lots of clutch and trans noises..as for not going into first same thing, i come to a complete stop before putting it into first as i've read the gear ratios are really short in these cars
thebus is offline   Reply With Quote
Old 08-31-2013, 12:46 AM   #3
userjack6880
userjack6880's Avatar
Drives: Raven FR-S MT
Same here. I mean, it'll let me throw it in <10 MPH, but anything above that, it'll fight. I think I'll avoid that monster and not worry *too* much about it and not do that. I really only use first to start from a dead stop anyways.
2013 Scion FR-S - Build Thread
2015 Ford Mustang GT
1978 Triumph Spitfire 1500
userjack6880 is offline   Reply With Quote
Old 08-31-2013, 12:46 AM   #4
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
even my auto jerks around 5mph...
Old 08-31-2013, 12:58 AM   #5
lsxiong
Drives: 92 Integra
Blip the gas pedal before disengaging the clutch.
lsxiong is offline   Reply With Quote
Old 08-31-2013, 01:15 AM   #6
jflogerzi
jflogerzi's Avatar
This car does not like going into first if you are above 12MPH or so. I noticed once I am down a bit more on speed it will slide right into first.
Old 08-31-2013, 01:48 AM   #7
Hi ZackZ ......
I've found that some cars will let you into first gear at some speed .... others don't like to do that.
I had a 2006 Miata, 5 speed, that I could put into first at 40 mph, however, you only get to let out the clutch once per engine doing that.
My FR-S (MT) likes to be dead stopped before it goes into first. Besides, if you are rolling at all, usually second gear will pull it up.
Old 08-31-2013, 01:59 AM   #8
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Hahaha!
Yeah, my Tiburon won't go into first at over 5mph without rev matching, but rev matching smoothly into first is hard to do. It's never bothered me though, because if the car is rolling at all, second gear is plenty.
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 08-31-2013, 02:10 AM   #9
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Another note to be made if you're a manual is consider some motul 300, Redline mTL, or Pentosin fluid swap world of difference to say least.
Old 08-31-2013, 02:17 AM   #10
husker741
Drives: 2013 Whiteout Scion FR-S 6MT
Try to put it in first without the clutch. That usually works for me.
Disclaimer: Don't you fucking dare try this. If you do, it's not my fault your dumbass can't sense sarcasm.
husker741 is offline   Reply With Quote
Old 08-31-2013, 05:44 AM   #11
wrb
frank
wrb's Avatar
Drives: Subaru BRZ WRB
can you explain more (newbie here)
What are "Motul 300", "Redline mTL", and "Pentosin fluid swap"?
and What will those do?
2013 SUBARU BRZ WRB LIMITED M/T
Los Angeles, CA
Build Photo Album - http://bit.ly/brz_wrb
SoCal LA 86 Club Member
wrb is offline   Reply With Quote
Old 08-31-2013, 06:03 AM   #12
Clembo
'Senior' Junior Member
Clembo's Avatar
Drives: 13 FR-S,08 Mustang Bullitt,06 MX-5
Different transmission fluids, supposed to work better than the factory fill.
"You'll never know if you don't try" - Shinroko Momose
Clembo is offline   Reply With Quote
Old 08-31-2013, 09:25 AM   #13
d4wt
d4wt's Avatar
Drives: a couple + an frs
granny shifting... not double clutching like you should.
d4wt is offline   Reply With Quote
Old 08-31-2013, 09:54 AM   #14
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
This. I've found that when driving in manual mode in the auto you just can't beat the car to first. It downshifts about 5 or so mph. If you try to it any sooner it'll jerk so you just have to let it have that one.
Nevermore is offline   Reply With Quote
Difficult to heel toe NoVtec Scion FR-S / Toyota 86 GT86 General Forum 110 11-12-2015 05:42 PM
Debadging - How difficult will it be? Dadhawk Scion FR-S / Toyota 86 GT86 General Forum 86 06-24-2014 10:49 PM
Shifter clicking when coming to a stop larryt1026 Issues | Warranty | Recalls / TSB 1 07-15-2013 07:34 PM
Is it really that difficult...? JSK Scion FR-S / Toyota 86 GT86 General Forum 39 09-21-2012 03:09 AM
Single knock when coming to a stop oops86 Issues | Warranty | Recalls / TSB 14 08-05-2012 01:17 AM
