#71 |
It depends on your application. Lots of people on here autocross and for autocross a larger diameter tire is faster in almost all scenarios, period due to the transitions and tighter corners. If you are running a 17x9 rim you need to be running a 245/255, but the classes you run those tires in also allow enough suspension modifications to take advantage of it.
In "stock" class I run 245/40/17 Hoosiers on a 17x7 rim, it's the absolute fastest tire for this car for that class in autocross. On a track, it's a different story, large tires like that can hurt you with their rolling resistance . |
#72 |
Drives: AE86, 2x GT86, TE27
I agree with your point, on the assumption that an r rates / semi is specifically excluded from that event. If not, then I would fail to see how a wide road tyre is going to out perform a 215 tyre with a more competition orientated compound.
#73 |
These HRE's
At 20K a set...they better be the lightest wheels lol Nick C.
#74 |
Drives: Some kind of Subaru
#75 | |
Drives: Subaru BRZ Sport Tech Satin White
It is also a common misconception that tire section affects grip, it doesn't. Rubber compound affects grip, period. Contact patch area is proportional to vehicle weight and tire pressure, section profile is not relevant to that. It is called a coefficient of friction for a reason. Otherwise, children wouldn't be able to walk because their shoes were too small. Think about it. Think hard before you post any reply to this. |
| The Following User Says Thank You to Suberman For This Useful Post: | diss7 (08-30-2013) |
#76 |
#77 | |
#78 |
Re-read last two sentences of the post you quotes.
Hint - section profile. And answering your point, width can add grip. Compound will add grip. |
#79 |
#80 |
Probably Dymags, but they are super expensive
Nick C.
Last edited by Diode Dynamics; 09-09-2013 at 09:51 AM. Reason: The image for my meme didn't work |
#81 |
Drives: ZN6 / GDB-G
#82 |
Drives: GT86
Konig daylites
17x7" Et40 7kg (as weighed on my scales) - 6.5kg claimed |
#83 |
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
SprintHart CP-R 16x7 +35 : 4.9kg(from wheelweights.net)
I'm rocking these as my daily/track wheels until I wear them out. Made the silly mistake of getting 225's on them when I should have went lighter 205's with a stickier compound. Wheels feel much faster than my WedsSport TC105N setup(6.75kg rim) though. |
#84 |
Drives: 86 & GRB
KONIG RRF02
15" 4.78kg 17" 6.5kg (14.3lb) ~$180 ![]()
| The Following User Says Thank You to 86Toyobaru For This Useful Post: | SkAsphalt (10-12-2014) |
| Which 18" wheels will weigh the same or less than the stock wheels? | mickey177 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 32 | 05-16-2013 03:07 PM |
| TRD Wheels | Re~Mix | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 14 | 06-27-2012 06:11 PM |
| Forgestar wheels, great wheels at great prices!!!! | IslandImportPerformance | Wheels and Tires | 0 | 06-15-2012 05:03 PM |
| O.Z. Wheels | Zaku | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 25 | 02-28-2012 03:21 AM |
| Top 10 Lightest 300 Horsepower Cars | Axel | Other Vehicles & General Automotive Discussions | 2 | 11-22-2009 02:23 AM |
