Old 07-25-2013, 11:34 AM   #15
Events@Ptuning
Events@Ptuning's Avatar
Drives: 2013 Scion FRS
Working His Magic
Events@Ptuning is offline   Reply With Quote
The Following 2 Users Say Thank You to Events@Ptuning For This Useful Post:
Darryljr11 (07-25-2013), ecko04 (08-04-2013)
Old 08-30-2013, 01:16 PM   #16
Events@Ptuning
Bump for the only EcuTek Dyno Tuner in Town!
The Following User Says Thank You to Events@Ptuning For This Useful Post:
ptuning (08-30-2013)
Old 08-30-2013, 03:11 PM   #17
ptuning
ptuning's Avatar
Drives: White FR-S
We just finished tuning an FR-S with an AVO Turbo Kit. The AFR's on the base map were WAY too lean (possibly due to his exhaust mods). They were not even in the same zip code of where they needed to be, but that's fixed now. The ignition timing, cam timing, and injection control have been optimized as well. We've also integrated a boost cut to protect the engine from overboosting.
We'll be tuning an FA20Club Turbo Kit here in the next week or so. We also have Innovate and Vortech customers lined up for tuning as well. Don't settle for e-tunes that require you to switch between multiple fuel and timing maps to close in on a functional tune. Your tuner should be the one figuring all this out on a dyno, not you on the street. Get your car tuned live and on a dyno and you'll only need one tuned map for a given set of mods.
Best Regards,
Toan
ptuning is offline   Reply With Quote
The Following 5 Users Say Thank You to ptuning For This Useful Post:
Darryljr11 (08-31-2013), IloveBaldEagles (08-30-2013), kanundrum (08-30-2013), nataku (08-30-2013), VoiD (08-30-2013)
Old 08-30-2013, 04:29 PM   #18
kanundrum
Drives: 2013 Whiteout FR-S
^^ Great Information
Old 08-30-2013, 06:48 PM   #19
nataku
Negative Mass
nataku's Avatar
Drives: Orange Metallic AVO Turbo GT86 6MT
Thanks for the awesome service and quick turn around. Car is running great so far. Got autocross tomorrow!
Build thread for my Lovely Lady.
nataku is offline   Reply With Quote
Old 08-30-2013, 07:29 PM   #20
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
My car gets done in a few weeks. Boost controller, injectors and map sensor and letting him do his thing on the dyno. Can't wait. Funny how yours is way lean. Factory wideband can only read down to 12.17:1 and under load in boost I'm pegged at that value. Never goes leaner than that
The Following 2 Users Say Thank You to spitfire481 For This Useful Post:
nataku (08-30-2013), ptuning (08-31-2013)
Old 08-30-2013, 10:46 PM   #21
nataku
Negative Mass
nataku's Avatar
Don't know what the deal was with running lean, I'm sure we'll hear something from AVO soon. It might be that they've never sold a kit to someone with a muffler delete, I have no idea...
Thought I'd share the graph you guys gave me. If you plan to post a digital copy then I can just pull the link here. The curves are looking a whole heck of a lot smoother and the car feels that way. Torque now peaks where it used to dip a bit. Things are running great.
The Following 2 Users Say Thank You to nataku For This Useful Post:
IloveBaldEagles (08-31-2013), ptuning (08-31-2013)
Old 08-30-2013, 11:40 PM   #22
kanundrum
^^ Thats a really nice Line right there, very linear! Glad the tuning worked out good! Ive been dealing with Toan for about 7 years now and Toan knows his stuff!
The Following 2 Users Say Thank You to kanundrum For This Useful Post:
nataku (08-31-2013), ptuning (08-31-2013)
Old 08-31-2013, 12:32 AM   #23
spitfire481
Drives: 2JZ FRS
That's good power at 5 psi, and dyno dynamics usually read a little lower than the common dyno jet
The Following User Says Thank You to spitfire481 For This Useful Post:
Old 09-07-2013, 04:56 PM   #24
spitfire481
Drives: 2JZ FRS
Picked my car up from ptuning this morning. What a difference. Toan did an amazing job. car feels like a bigger engine rather then a boosted 2.0 with the avo kit. Its hard to even tell when boost comes on its so smooth. Part throttle is amazing, zero flat spots or issues. Definitely recommend these guys for dyno tuning.
Avo kit
Tanabe catless front pipe
Perrin resonated cat back
Dw 700 injectors
Omni 3 bar map
Turbosmart manual boost controller
With the 5psi avo actuator boost dropped by about 2psi from 5500 to red line. Will be doing their upgraded actuator next spring. Max boost of 10.5 psi
Old 09-07-2013, 04:58 PM   #25
kanundrum
Nice seeing you again man!
The Following User Says Thank You to kanundrum For This Useful Post:
spitfire481 (09-07-2013)
Old 09-10-2013, 08:24 AM   #26
regal
Drives: Scion FR-S/Toyota Yaris
Toan, would you do a Dyno tune with this: http://procedetuning.com/styled-23/styled-24/index.html ?
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 09-10-2013, 12:17 PM   #27
ptuning
ptuning's Avatar
Drives: White FR-S
I can certainly look into it if there are enough interested parties.
- Toan
Old 09-19-2013, 10:41 AM   #28
Events@Ptuning
Bumpo Who is coming out to Meet Toan!
dyno, ptuning
Oi Takashi in USA, driving for Import Tuner Magazine FRS tuner impressions. Moto-P Scion FR-S / Toyota 86 GT86 General Forum 15 11-19-2015 04:39 PM
Recommendations for a tuner Blackout808 Hawaii 8 05-28-2015 06:18 PM
PTuning - Check us out! Ken@PTuning Announcements, Contests, Giveaways 0 06-13-2013 10:07 AM
Ptuning's exhaust ScionFamily Engine, Exhaust, Transmission 1 02-21-2013 07:40 AM
PTUNING Muteki SR48, SR35 and, tuner lug nuts Special Mrc@ptuning Wheels and Tires 4 11-16-2012 10:43 AM
