Old 08-30-2013, 09:42 AM   #43
gt8613
I dream of BRZ
Drives: Prospective BRZ owner.
I am not sure, but I vagu3ly remember 8t being said that it makes 160 jp without di.
Originally Posted by suaveflooder View Post
You'll also loose HP. Without the DI, this engine was pretty pathetic from what I've heard. Toyota's DI is the only reason why the car made it to 200 crank hp
Sent from my SAMSUNG-SGH-I537 using Tapatalk 2
gt8613 is offline   Reply With Quote
Old 08-30-2013, 09:55 AM   #44
R3d
Drives: White FR-S
your half right on this one, they were able to make 200 hp on port injector, but the emission tests results were bad and when they tuned to get the emission tests results to pass what ever criteria they need, it made around 145-165 hp! Thats when they went with DI, witch is an amazing showmanship of 2 company`s sharing technologies and know-how to produce something totally new !
If you dont like DI, in your situation, I would get a AP2 swap and call it a day.
R3d is offline   Reply With Quote
Old 08-30-2013, 10:00 AM   #45
R3d
Drives: White FR-S
Originally Posted by Admiral Ballsy View Post
That depends upon the yardstick, doesn't it?
If the non-VVT setup is designed for maximum power, you're right. But I think that's rarely the case, as few manufacturers would sell an engine set up with the proper overlap for peak high-RPM power; it wouldn't idle well and wouldn't be very tractable at low RPM.
VVT lets you make fewer compromises; you can have peak power AND driveability.
This argument is pointless!!!
BEHOLD the END of :
1- vtec
2- VVT
3- VVTI
4- i-VTEC
5- and all other tec of any kind !
THE TRUE FUTUR OF CAMS IS.... NO CAMS !!!
ok ill shut up heres proof XD :
[ame="http://www.youtube.com/watch?v=Bch5B23_pu0"]The Future of the Internal Combustion Engine - /Inside Koenigsegg - YouTube[/ame]
peace!
LOL you could also swap this in your car XD!
The Following User Says Thank You to R3d For This Useful Post:
Marchy (08-30-2013)
Old 08-30-2013, 10:15 AM   #46
Admiral Ballsy
Shorter of breath
Admiral Ballsy's Avatar
Drives: a soft bargain
Hardly a new idea, been worked on for decades. Not ready for prime time yet.
Admiral Ballsy is offline   Reply With Quote
Old 08-30-2013, 12:40 PM   #47
SkullWorks
Drives: SSM LT MT BRZ
To the best of my knowledge the only AEM's out there running on FA20's have been sourced through Mitch Pederson of MPtuning. We have been on and off the AEM with E85 since last August or September on my BRZ (which is obviously the test mule). The ECU development is at a point where it would likely be brought to market by a less discerning companies/tuners. Currently I think Mitch isn't pushing it because we are still working on full system integration.
The Lack of DI PUMP control is probably the easiest problem to resolve, we have a couple options there we are sorting out.
...just to clear that up...
Onto the matter at hand taking DI off at this point would put you in the same chapter as the redneck that takes the fuel injection off of a C5 corvette so he can do a blow thru turbo conversion on the stock LS motor...
Do some research on the Anti Knock Index (AKI) of fuels at port injection pressure and a DI pressure, then do some more research on combustion chamber cooling and the 3 stages of injection timing available and utilized by modern DI systems.
Having (and understanding) DI, gives you race gas effective octane (AKI) form standard swill, if you have access to E85....all the better.
TLDR; Don't abandon a technology because it intimidates or confuses you .
The Following 4 Users Say Thank You to SkullWorks For This Useful Post:
Bg8780 (08-30-2013), CSG Mike (08-30-2013), ft_sjo (08-30-2013), mad_sb (08-31-2013)
Old 08-30-2013, 12:52 PM   #48
Bg8780
Bg8780's Avatar
Drives: '13 Black Subaru BRZ Limited
I see where you're coming from OP. I have the "popping" noise and have had it for months now (at 15k mi now) I haven't heard it some time and called my dealer. They said they can't do anything if I can't replicate the issue and there's no CEL. So I'm pretty much waiting for her to explode. I'm a bit concerned about Subaru covering it since I have an intake and tune. I'm pretty much in fuck it mode right now and just driving the car normal. I still beat on her on the on ramps and such and have my fun (certainly nothing extreme). No autoX or track days so I'm not too worried. Just a daily fun driver.
Anyone here have experience with Subaru's warranties? Do you think they will deny my warranty when the engine blows because of the intake and tune?
Bg8780 is offline   Reply With Quote
Old 08-30-2013, 01:04 PM   #49
xjohnx
Grip>Slip
xjohnx's Avatar
They've denied the warranty on a 100% stock motor car, just ask @CSG Mike .
Old 08-30-2013, 01:19 PM   #50
CSG Mike
CSG Mike's Avatar
They can tell you tuned the engine. If you're tuned, how is it Subaru's fault if your engine blows? Unless you can prove it's a manufacturing defect (which may be difficult), you're liable for your modifications.
Old 08-30-2013, 02:23 PM   #51
suaveflooder
I was under the impression it was the other way around. THEY have to be able to prove that the part you installed caused the failure.
suaveflooder is offline   Reply With Quote
Old 08-30-2013, 02:29 PM   #52
CSG Mike
CSG Mike's Avatar
Well, if you have an aftermarket tune, you altered the parameters of the engine. This is open and closed. You didn't install a part, you altered the software that is the core of the car.
I'm all for warranty coverage, but I don't believe this should be covered.
Mikem53 (08-31-2013), Sportsguy83 (08-30-2013)
Old 08-30-2013, 02:40 PM   #53
suaveflooder
but if that part didn't cause the failure, they are supposed to honor the warranty, correct? Like say the tune. You no longer have issues with your DI because you've fixed the tune yourself. Now the head gasket fails. Warranty should still cover the gasket, correct?
I'm speaking in generalities, but the Toyota dealership I go to has been REALLY cool with mods. The part itself is void and if it causes any obvious failure to another part, but my lowering springs didn't void out my entire suspension. Obviously a little different than modifying engine parameters, but still the basic idea.
Old 08-30-2013, 02:44 PM   #54
CSG Mike
CSG Mike's Avatar
Unless the gasket itself had a manufacturing defect, it wouldn't be covered.
You'd have a very difficult time proving that it had a defect.
Also, Ecutek, in the past, alters the ECU's handshake protocol so the dealer can't connect to it. Not sure if that's the case with the FR-S/BRZ, but we'll find out soon enough.
suaveflooder (08-30-2013)
Old 08-30-2013, 09:44 PM   #55
TeamZleep
Drives: 2013 FRS/2011 TDI
To all the people saying to sell my car for an s2k or a miata... There's a reason I don't already own one of those... Simply put, I don't like them. Never been a fan of verts. End of discussion. Never anywhere did I say I was frightened or living under a rock with my D4S worries. Hell, I'm not even really that worried about it, If it blows up, the only thing I'll have to fight is the fact that I removed the secondary cat. No biggie there.
This was an honest question of curiosity and pursuit of knowledge, and so far this thread has been great.
TeamZleep is offline   Reply With Quote
Old 08-31-2013, 12:30 AM   #56
Dimman
Kuruma Otaku
Dimman's Avatar
Mikuni has a solution for you.
Because titanium.
The Walking Dead DIM Off-Topic Lounge [WARNING: NO POLITICS] 286 11-02-2014 11:19 PM
Dead Engine LOZZI Issues | Warranty | Recalls / TSB 17 09-26-2013 11:25 PM
Dead OEM fog light SpyderDan Cosmetic Modification (Interior/Exterior/Lighting) 8 08-26-2013 02:40 AM
Dead Pixels on Nav Unit Longhorn248 Issues | Warranty | Recalls / TSB 17 09-06-2012 06:28 PM
g35 brought from the dead bryansbestwax Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 06-25-2012 11:22 PM
