Old 08-29-2013, 08:23 PM   #155
DAMotorsports
Drives: 2013 Scion FRS "Raven"
Originally Posted by Tansey86 View Post
What suspension modifications? How is the clearance inside of the wheel well?
Looks amazing, favorite meaty setup so far.
Originally Posted by TRD_86 View Post
This is a new amazing square set up. Could you list setup specs, wheel offset, camber, coilover... ?
We are working on a build page but we are running eibach r2 coil overs with about an 1.5 inch drop. Camber is 1.5 front and rear. The wheels are wedssports SA-15R 18/9.5/48. We are running a 6mm spacer in the front making our final offset a 42. The spacer gave use the room needed to run BFG R1 slicks and we decided to leave them when we switched to the hankook Rs3 275/35/18.
DAMotorsports is offline   Reply With Quote
The Following User Says Thank You to DAMotorsports For This Useful Post:
TNPerformance (09-01-2013)
Old 08-29-2013, 09:22 PM   #156
NYCsubaruBRZ
Drives: 2013 Subaru BRZ & 99' Ford Explorer
i burned up my stock tires in the rear so now i have the front with the stock 215/45/17 and the rear is 245/45/17 no rub no problems.
wondering if i can put the same size in the front with out rubbing....
Can i put a 245/45/17 on the front with out rubbing? i dont wanna have to adjust camber
NYCsubaruBRZ is offline   Reply With Quote
Old 08-29-2013, 09:32 PM   #157
DAMotorsports
We had 235/40/17 on stock wheels before upgrading to our new meats. No problems with the 235 @NYCsubaruBRZ
Old 08-29-2013, 09:38 PM   #158
NYCsubaruBRZ
im not so great with rim tire fitment. so if a 235/40/17 will fit without rubbing, than a 245/45/17 will fit? (in front)
Old 08-29-2013, 11:19 PM   #159
DAMotorsports
It's going to flare out on the stock rim and feel different it should be fine. Put Your rear to the front. With out looking I'm 90% sure it will.
Old 08-30-2013, 12:16 PM   #160
gppfrs
Drives: slow
Originally Posted by Turbowned View Post
My conservative (for this thread) setup consists of 18x8.5 +45 with 225/40R18 in the front and 18x9.5 +45 with 255/35R18 in the rear. Lowered on Eibach Sportline and completely functional. Just about flush, which is more in line with how an exotic performance car comes from the factory. I'll dial in more front camber when I switch to coilovers. Only downside is that I can't rotate the tires, so I'll be buying new ones every year
[/URL]
Perfect fit I think i'm going for the same type of look next spring with my FSR.
gppfrs is offline   Reply With Quote
Old 08-30-2013, 12:21 PM   #161
Lakers86
Lakers86's Avatar
Drives: Asphalt FRS
Originally Posted by Touge Factory View Post
17x9 RPF1's
245/40/17 RS3's
Sexyness right here! I just picked up the Silver RPF1's.. but u make these SBC's look real good bro!
Lakers86 is offline   Reply With Quote
The Following User Says Thank You to Lakers86 For This Useful Post:
Touge Factory (08-30-2013)
Old 08-30-2013, 12:25 PM   #162
Lakers86
Lakers86's Avatar
Drives: Asphalt FRS
Originally Posted by Superhatch View Post
Not sure if these are meaty enough or not.
17x8 RPF1, 245/40/17 DIIs.
Eibach Sportlines.
This is gooood meats bro!
Old 08-30-2013, 01:10 PM   #163
Touge Factory
Touge Factory's Avatar
Drives: ZN6
Send a message via AIM to Touge Factory
Touge Factory is offline   Reply With Quote
The Following 3 Users Say Thank You to Touge Factory For This Useful Post:
JEFFSTYLE (01-05-2014), mfbmike (09-05-2013), TNPerformance (09-01-2013)
Old 08-30-2013, 04:30 PM   #164
NYCsubaruBRZ
meat is good! veggies r not for me
Old 08-31-2013, 09:24 PM   #165
red_comet
Severed Member
red_comet's Avatar
Drives: Argento 2013 Scion FR-S Manual
Originally Posted by bkblitzed View Post
It's probably cus they never used the tire before. Im a fan of bfgoodridge just because they make good cheap tires that last a long time. Used the comp 2's in the STi for a track day and they did great. I have the comp 2's on the frs now, and can't say much since i dont have an alignment but they're doing pretty good.
Thanks for that info. It's good to have a first hand account when looking into something as important as tires.
Also, what the hell is the gif in your signature from? It's hypnotic.
87 Volvo 760 Turbo <3
02 WRX THE QUEEN IS DEAD, LONG LIVE THE QUEEN!
06 Xfire Bite me I liked it
13 FRS doriftoooo!
DON'T PANIC
red_comet is offline   Reply With Quote
Old 08-31-2013, 10:59 PM   #166
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
Emma watson! Oh ma gawd shes hot
bkblitzed is offline   Reply With Quote
Old 09-01-2013, 04:56 PM   #167
TNPerformance
Drives: 2013 Hot Lava FRS/97 Supra/93 Supra
The classic 18x9.5 et38 RPF1 in SBC with Fortune Auto v4 500 coilovers on some crappy tires for daily duty. 255/35 on all 4 corners. Alignment still needs dialed in, just got the coilovers on a couple of days ago.
TNPerformance is offline   Reply With Quote
The Following 3 Users Say Thank You to TNPerformance For This Useful Post:
armythug (09-15-2013), GTB/ZR-1 (09-02-2013), tipiman (12-26-2014)
Old 09-02-2013, 05:03 PM   #168
mpg
Drives: black 2013 fr-s
17x9 RPF1's
245/40/17 RS3's
What springs are you using? What offset? How much camber?
mpg is offline   Reply With Quote
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 05:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 06:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 12:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 01:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 03:05 PM
