Old 08-29-2013, 02:11 PM   #57
swift996
swift996's Avatar
@Sportsguy83 work now? I shrunk it down.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
The Following User Says Thank You to swift996 For This Useful Post:
kster1 (08-29-2013)
Old 08-29-2013, 02:16 PM   #58
InvalidJohnny5
The Based God
InvalidJohnny5's Avatar
Drives: 87 Supra, 92 240SX, 13 BRZ Turbo
Are half of you Air Force as well? If so what squad and AFSC?
341st CES, Water/Fuels
Milltek Full Exhaust (Overpipe, Cat-delete, Catback), AVO Turbo kit , Perrin Crank Pulley , ACT Clutch Kit , ACT Prolite Flywheel 10.5lb , Axel-Exchange Driveshaft, Sparco Assetto Gara 17x7.5, Hankook Ventus V2s 225/45/17, Michelin Pilot Super Sports 225/45/17, Rally Armor Mudflaps, Viscontiproof tune Courtesy of Drift Office LLC
InvalidJohnny5 is offline   Reply With Quote
Old 08-29-2013, 02:20 PM   #59
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
PERFECT, thanks!!
Old 08-29-2013, 02:39 PM   #60
xjohnx
Grip>Slip
xjohnx's Avatar
back on topic, did you ever get a chance to remove the fitting to see if anything weird was going on back there? could you take some pics of it?
Old 08-29-2013, 03:43 PM   #61
wparsons
wparsons's Avatar
^^ Check his thread in the brake section, he melted the dust boot on at least one of the pistons in his front calipers.
That's a more likely culprit for a soft pedal than a vacuum leak.
flickr
Old 08-29-2013, 04:10 PM   #62
Innovate Motorsports
Drives: Scion FRS, Subaru BRZ, Supercharged
Greetings all, it has been said in this thread quite well already, in no way will the vacuum hose to the brake booster cause your brakes to fail to function. It is simply a vacuum assist. That said, that fitting should remain tight. being plastic if there is any sort of load on the fitting it could loosen or potentially be damaged so do take care upon installation. All of these fittings are checked before the product ships. However if you do experience an issue, please contact us directly. We want to document it and take corrective action to keep you on the road.
Innovate Motorsports is offline   Reply With Quote
The Following 3 Users Say Thank You to Innovate Motorsports For This Useful Post:
evo4g63 (08-29-2013), Sportsguy83 (08-29-2013), tom@kartboy (08-30-2013)
Old 08-29-2013, 09:43 PM   #63
FirestormFRS
That is not 100% true. Having zero vacuum assist will cause the brakes to be massively difficult to engage. Imagine going 10/10th's into a corner and your pedal just became 200% more difficult to press. You just had an accident.
FirestormFRS is offline   Reply With Quote
Old 08-29-2013, 09:52 PM   #64
RedLeader
RedLeader's Avatar
Drives: 2013 Firestorm FR-S
They will however still work, just become more difficult to apply. The OP said that the pedal went to the floor and nothing happened. Totally difference scenario. I get what you're saying, but the loss of vacuum pressure doesn't make the brakes inoperable, which is what Innovate is saying.
That being said, the innovate kit comes with a brake booster hose. Is that necessary/recommended to switch from the factory one on a LHD, 6MT FRS?
Old 08-29-2013, 09:52 PM   #65
sw20kosh
Drives: 2013 Black FR-S
Both of the plastic 90 degree fittings (one for the brake booster, and one for the evap) swivel freely (by hand) on my unit. Is this normal?
Old 08-29-2013, 11:11 PM   #66
FirestormFRS
Just making sure people understand that the vacuum assist not working IS a lot bigger problem than Innovate indicated. Yes you have brakes but you'll never stop if that hose comes off unexpectedly.
OP probably just cooked his brakes.
Old 08-30-2013, 10:15 AM   #67
swift996
swift996's Avatar
Yeah the more analysis and insight from feedback on the forums seems to lead to cooking the brakes.
The strange thing was when I moved the fitting left to right the brake pedal started to fall when someone was in my car with the foot on the brake. Perhaps it was just an oddity. Also after applying locktite and letting it sit over night the pedal pressure issues were gone.
I ordered some new rotors, pads, fluid (motul rbf 600 - what I was running), and titanium heat shims. I'll be back on the track the first weekend of October.
Thanks to @Innovate Motorsports for the quality tech support over the phone. I did inspect the fitting before install (about 5-6 weeks ago) and it was tight. Interesting that it would come loose. I'll keep an eye on it although the locktite should hold it in there.
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 11:58 PM
WARNING! TOYOTA (TMCA) is watching! Be careful what you post online! Psyco AUSTRALIA 127 10-24-2012 03:45 AM
Question for HOUSTON Fr-s owners and/or to be owners enjoi23 Southeast 2 08-30-2012 10:48 PM
Be careful at the pump with E15 Thunderchicken Scion FR-S / Toyota 86 GT86 General Forum 9 08-10-2012 11:33 PM
