Drives: 2013 Scion FR-S in Firestorm
What is this plug & this connector for? (FR-S, stock HU)
So I did some forum searching trying to figure this out but didn't get anywhere... apologies if it has been answered already.
I was wiring up a sub to the stock HU and noticed a connector on the stock HU was unplugged. The HU came out pretty easy so I don't think I yanked any cables out of the back. Upon searching for any loose cables/harnesses/etc., I noticed a connector pretty far back just sitting there. It's taped up pretty well so there's not enough slack for it to reach the HU and it doesn't look like the plug would fit anyway. http://imgur.com/a/GA8Li Can anyone clue me in as to what the plug and the connector are for?
#2 |
Drives: 2017 Camaro 1SS
I'm guessing it's something that just isn't used in this car. Like a 6-disc changer or something. It's probably used in other Scion cars.
#3 |
Victim's aren't we all
Drives: Toyota GTS 86 - Pegasus White
Can you take a picture showing the actual wires [colors] attached to that additional plug, that might help with determine what it's used for.
Looks like the speaker wire harness to me: I took some pictures of mine when I changed head units. ![]()
#4 | |
![]() I'll pull the HU out again and try to take a bit more detailed picture... stay tuned Edit: Here's the plug & the corresponding wire colors going to it.
#5 |
Does everything work???
#6 |
#7 |
It sure does! I'm just one of those curious folk that want to know why something in my car isn't connected.
![]() Sent from my One using Tapatalk 2 |
#8 |
#9 |
Shorter of breath
Drives: a soft bargain
It's listed in the schematics as "option connector", D29. The pink and blue wires are CAN bus, orange is B+ (fused through the dome lamp fuse), black/yellow is ground, red/black is accessory power (radio fuse).
Don't know what the 'option' would be for, though. |
| The Following 2 Users Say Thank You to Admiral Ballsy For This Useful Post: | ein311 (08-29-2013), RedReplicant (12-09-2022) |
#10 |
Drives: 2013 Whiteout FR-S
Looks like a Subwoofer connector (looks the same on the scion tC)
#12 | |
Shorter of breath
If I was guessing, I'd say it's potentially for diagnostics...maybe like that multifunction pod that turbo Cobalts and HHRs had as an option? Can't think of much else that would require switched power and CAN data....and nothing else. |
#13 |
Drives: 13' Scion FRS Track car
does anybody knows where to buy a male connector for the D29 connector ?
this connector offer some great cable with constant ant switched power, plus can high and can low.
2013 Scion Frs Track Car - Sold.
#14 |
Did you look on the top of the HU? there should be a diagram sticker of what the plugs are
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
| Gear Stick HELP | FaNtaSy | Engine, Exhaust, Transmission | 12 | 03-17-2013 11:03 PM |
| NAV Install -Pulling VSS, Reverse and factory USB plug from HU 28 pin plug | sikest | Electronics | Audio | NAV | Infotainment | 7 | 01-21-2013 09:38 PM |
| RPM stick between 3.5 - 4.5 | Realm | Engine, Exhaust, Transmission | 6 | 09-18-2012 01:10 PM |
| Car Name; Reason why FT-86 won't stick | xantonin | Scion FR-S / Toyota 86 GT86 General Forum | 54 | 07-17-2011 12:52 PM |
