View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up?
Yes (Please only vote after you have 300 miles or more on the odometer) 3,101 85.22%
No (Please only vote after you have 300 miles or more on the odometer) 538 14.78%
Voters: 3639. You may not vote on this poll
Old 08-28-2013, 10:17 AM   #2647
HunterGreene
Hail Magnet
HunterGreene's Avatar
Originally Posted by sweetfrs View Post
i took my car in about 2 weeks ago and they put a tbs on the fuel pump or something. I just dropped it off and they are putting a whole new and improved unit in it
Let us know how it turns out...though I am willing to bet that the crickets will return.
It has priests in it?
Old 08-28-2013, 12:20 PM   #2648
kurbkilla
kurbkilla's Avatar
Drives: Scion FRS (Asphalt)
It seems to me it is the ethanol in the gas. Because from what I found the Toyota version does not have this problem. And if the car was developed in an area that does not use ethanol in there gas, the problem would not surface until it got to the states. So instead of replacing the fuel pump with another OEM pump that work with ethanol free gas they need change the whole fuel system. It can't be the engine because we are close to the compression and bore&stroke as an S2000 and they didnt have this big of a problem.
Unless I'm completely wrong and talking out of my ass
kurbkilla is offline   Reply With Quote
Old 08-28-2013, 12:54 PM   #2649
choi0706
Drives: t
who wants to bet there will never be a fix for this because nobody has had a real failure..
imo, I think they failed testing in the US.. The test engineers either missed the chirping, or they knew and figured it was nothing worth noting.. or the supplier changed specs..
choi0706 is offline   Reply With Quote
Old 08-28-2013, 01:27 PM   #2650
Scoobidude
Drives: DGM BRZ
just noticed the crickets today 3400 miles. I think all the gas around me has ethonal in it
Scoobidude is offline   Reply With Quote
Old 08-28-2013, 02:31 PM   #2651
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Toyota operates significant testing facilities in America, most auto manufacturers do because where's the best place to do long term high heat testing? How about the hottest place on the planet: Death Valley California with the only fuel commercially available being 91 octane E10 gas.
http://www.toyota.com/about/our_busi...d_development/
Saying Ethanol is the problem is like saying fast shifts are the problem for the DI seal failures. Design criteria is the "problem" and as @choi0706 says, until there's a failure there's no need to do anything, it's just a noise. Ethanol is a band aid in so many ways.
ineedyourdiddly
Old 08-28-2013, 07:58 PM   #2652
tripjammer
tripjammer's Avatar
Drives: WRB BRZ limited 6MT
Originally Posted by sierra View Post
Make sure the fuel is completely free of ethanol until they make the HP pump compatible with it or add a lubricant to the fuel to compensate.
What kind of lubricant do your add to the fuel?
tripjammer is offline   Reply With Quote
Old 08-28-2013, 08:18 PM   #2653
Mikem53
Drives: FR-S 6MT
Well.. Your ass is talking.. The s2000 didn't use DI. It used a direct port injection system. DI uses a special pump for the high FP required on the twins.
Mikem53 is offline   Reply With Quote
Old 08-28-2013, 09:40 PM   #2654
sierra
Drives: Skoda Yeti DSG diesel 4x4
You could try a high quality 2 stroke oil pref zero ash. It's designed for the job. Mineral oil might be better than synthetic, there are reasons it could burn more completely if you read up on it.
It's about 1:50 in a 2 stroke, 1:200 added to a HP direct injection diesel and 1:500 to 1:1000 for gasoline engine. That's what others have found by experimenting. There's heaps on this thread and you can google it to find out more.
sierra is offline   Reply With Quote
Old 08-28-2013, 09:48 PM   #2655
tripjammer
tripjammer's Avatar
Thanks bro but I am not trying to go Dino oil on an engine designed for synthetic but found out the Lucas fuel injector addictive was a good choice. I might try it. My chirp is not too bad. Is there anybody using e85 getting bad chirps?
Old 08-28-2013, 09:49 PM   #2656
sierra
The Toyota version is still rated for E10, it's in the owners manual page 70.
Toyota stuffed up with the HP pump and one component can't handle the higher friction that ethanol causes. It gets worse when it's hot because friction increases with heat.
Why they haven't fixed it after well over a year is mindblowing, especially when you factor in all the pumps that have been replaced!
Old 08-28-2013, 10:29 PM   #2657
sierra
This isn't going in the engine oil, it goes in the fuel.
Is Lucas oil synthetic?
Old 08-29-2013, 11:45 AM   #2658
kurbkilla
kurbkilla's Avatar
I didnt say the s2000 had DI. I was saying it had close to the same compression. Some people thought that it was the high compression (12.5:1) but the S2000 had 11.7:1 with a larger bore&stroke.
But I was wrong regardless because of what Sierra and strat61caster mentioned.
Old 08-29-2013, 12:07 PM   #2659
Mikem53
Drives: FR-S 6MT
It doesn't have an HPFP like the twins.. Which is the source of the noise
Old 08-29-2013, 01:35 PM   #2660
grdotnet
Drives: 13 BRZ, 93 F150
Mine just started.... 700 miles on the odometer. Great.
grdotnet is offline   Reply With Quote
Is this idle noise normal? robo_robb Engine, Exhaust, Transmission 288 01-25-2022 09:40 AM
Squeak noise from engine. Fish Scion FR-S / Toyota 86 GT86 General Forum 52 05-08-2014 01:06 PM
Video of chirping at idle Julio86 Engine, Exhaust, Transmission 15 02-01-2013 10:37 AM
Starting to get worried - Engine noise Laika BRZ First-Gen (2012+) — General Topics 49 07-02-2012 03:45 PM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 12:00 PM
