Old 08-28-2013, 04:26 AM   #57
Xauterus
Drives: GTS 86 Galaxy Blue
You do realise everytime you adjust height, you need a wheel alignment.
Xauterus is offline   Reply With Quote
Old 08-28-2013, 11:41 AM   #58
CSG Mike
CSG Mike's Avatar
Originally Posted by diss7 View Post
An update on where I'm at...
Decided against the Teins. Too many similar stories, even from people selling them.
Cusco has a local dealer (TRD NZ is also Cusco dealer ) But, they aren't rebuildable.
Fortune Auto 500 are rebuildable, but mixed opinions.
Also considering RCE Tarmac Zero's. I am in two minds about the fact they aren't damper adjustable, on the one hand, I like a set and forget and just adapt/get used to it approach. Also like that someone with for more knowledge than I has decided what is best. But, paying the same price for a non adjustable coilover compared to an adjustable one, is that a little near-sighted? Could argue that more $/quality has gone into the unit, seeing as there was $ saved from not making it adjustable. RCE Tarmac also have excellent warranty. Although one would argue useless on otherside of the world, but I would say that it says a lot about their confidence in the product.
Any thoughts on which of the three you'd go for?
Fortune Auto 500 are the cheapest of the three.
RCE Tarmac 0's work out to be about another $500 on top of them.
Cusco Zero - A about another $200 on top of the RCE's.
I'd say our results speak for themselves when we're using Teins and putting down solid results...
Anything under 2.5k or so, you get what you pay for. That Cusco damper you're considering is probably a rebranded Showa, just how the RCE is a rebranded KW.
Old 08-28-2013, 11:54 AM   #59
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
You get what you pay for to a certain point. With Tein or even KW, Cusco, I'd say there is a premium on the brand notoriety. Somebody has to pay for all the marketing they do....
Koni or Bilstein shock coupled with some springs with decent rates are probably the best bang for buck, but to get them dialed in you'd have to spend time testing them, getting revalved/rebuilt at least twice... nobody got time for that.
The Following User Says Thank You to solidONE For This Useful Post:
CSG Mike (08-28-2013)
Old 08-28-2013, 12:29 PM   #60
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Considering the range, pricing, and not made in Taiwan, I'm surprised.
So if Tein was made with the same quality but built in Taiwan, they're not good?
Just because something is made in Japan or the US doesn't make it better. See the first batch of Eibach R2s as an example.
There's only so many shock makers in the world, and this industry is a lot smaller than one wants to believe from a manufacturing perspective.
-alex
Old 08-28-2013, 05:49 PM   #61
solidONE
solidONE's Avatar
My advice, as a suspension snob on a budget, is to research and see which spring and damper combo works best and go with that. Much better than cheapo coilover systems with mismatched spring and damper rates. If you just want to "hella-slamm" your 86 then... Get a cheapo coilover kit.
Old 08-28-2013, 05:51 PM   #62
CSG Mike
CSG Mike's Avatar
you hipster you
Old 08-28-2013, 05:54 PM   #63
etherealfall
Drives: Toyota 86 GTS Storm Black
What about the smaller diameter coilovers offer? I know that's one thing that's enticing me for coilovers as the fitment of certain sizes at the front is a little too close on the stock strut.
Sent from my C6603 using Tapatalk 4
etherealfall is offline   Reply With Quote
Old 08-28-2013, 06:00 PM   #64
CSG Mike
CSG Mike's Avatar
I suppose it doesn't hurt to post.
Old 08-28-2013, 06:02 PM   #65
CSG Mike
CSG Mike's Avatar
It just gives you more room between the fender and spring to fit tire
Old 08-28-2013, 06:26 PM   #66
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Drives: 13 BRZ, Galaxy Blue Silica
What do the different "Filename" items represent?
Perrin Headerback, OFH, OFT, Ohlins R&T MI20, 17x9 Weds TC105N, Hankook RS4 (235/40), TOM's JDM Tails, PCV AOS, Perrin Crank Pulley, Perrin Rear Trans. Mount, Whiteline Shift Bushing, SS brake Lines, Hawk DTC60, Bayson R Lip Kit, LED Lighting , Smoked JDM Sidemarkers, Rear Fog Enable, Carsmo Armrest, Grimmspeed Plate Relocater
φφκα
Cjymiller is offline   Reply With Quote
Old 08-28-2013, 06:30 PM   #67
CSG Mike
CSG Mike's Avatar
Different damper settings.
Finer resolution doesn't show due to scaling, unless we zoom in
Old 08-28-2013, 06:43 PM   #68
etherealfall
Yeah that's why I am going for coilovers. 9.5in comes too close!
Old 08-28-2013, 11:16 PM   #69
solidONE
solidONE's Avatar
you hipster you
How dare you!? It's "hella-hipster." Get it right.
What are you, some kinda hippy? What's with this metric Newtons shit? You got a 'Murican English version of this chart? ft./lbs. and in./s measurement?
What damper is this? Doesn't look like much of a range in the adjustment on the first chart, though it might be because of the measurement units used. aint nobody got time to do no conversions...
Old 08-29-2013, 02:12 AM   #70
CSG Mike
CSG Mike's Avatar
Short version:
0.01-0.05 = roll/input
0.05-0.10 = berms, curbs, etc.
0.30 = potholes, parking bricks, red blocks of death at Laguna Seca, etc.
solidONE (08-29-2013)
CounterSpace Garage || JRZ|KW|Tein|Bilstein|Ohlins|MCS|SPL|Swift|Raceseng || CounterSpace Garage Brakes, Suspension, Chassis 45 11-01-2016 11:44 AM
GROUP BUY: TEIN SRC Coilovers / Suspension CounterSpace Garage Groupbuys 24 10-31-2013 03:56 PM
Whiteline|Cusco|TEIN|Perrin|KW & More! All your suspension needs here @ CMS Circuit Motorsports Brakes, Suspension, Chassis 64 12-18-2012 02:25 PM
Tein Suspension Announced! vividracingcom Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 06-07-2012 11:20 AM
TEIN releases more FT-86 Suspension parts! RallySport Direct Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 05-07-2012 01:20 PM
