Old 01-19-2012, 09:16 PM   #43
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
Originally Posted by arghx7 View Post
don't expect this car to be any faster than an Rx-8, which will do a 1/4 mile in the high 14's with trap speed in the mid 90s if you're lucky.
This is pretty much what I am expecting
Out of the FRS game
Mr.Jay is offline   Reply With Quote
Old 01-19-2012, 11:31 PM   #44
tripjammer
tripjammer's Avatar
Drives: WRB BRZ limited 6MT
It will be faster than the RX8...
tripjammer is offline   Reply With Quote
Old 01-19-2012, 11:58 PM   #45
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
Explain?
SUB-FT86 is offline   Reply With Quote
Old 01-20-2012, 12:07 AM   #46
fatoni
Originally Posted by SUB-FT86 View Post
Explain?
tq. oh wait it has less than the rx8...hp, wait same problem. here it is cd is .27. combine that with a boxer engine and youre in lambo territory
Old 01-20-2012, 12:16 AM   #47
miata
Drives: 2006 Miata 5 spd
RX8 weight: 3111 lb, HP: 212hp. lb/hp = 14.7 , 0-60mph = 6.3 sec
2011 MINI Cooper S 2668 lb, 181 hp = 14.7 lb/hp, 0-60mph = 6.2 sec
2010 GTI 3034lb, 200 hp = 15.2 lb/hp , 0-60mph = 6.9 sec.
FRS weight: 2750 lb ? HP: 200hp. lb/hp = 13.8 , 0-60mph = 5.9 sec sounds reasonable.
miata is offline   Reply With Quote
Old 01-20-2012, 12:39 AM   #48
Kage
Drives: 2000 Celica Gts
Send a message via AIM to Kage
This post makes me happy. I was fully ready to buy the car with a 6.9 sec 0-60 but this car just keeps sounding better and better.
But isnt 2750 the gt86 weight. I kept seeing 2596lb for the Fr-s which would put it at 12.98 lb/hp.
...either way
Originally Posted by Zaku View Post
I care first and foremost about what my needs are in the car and not to get "Props" from people. I'm not ricing it out for attention, I'm not flushing it to join a culture, I'm not keeping it stock for resale. I'm making this car for me and me only. And if you're my friend and club members that know me they'll respect that and respect is much better than props.
Kage is offline   Reply With Quote
Old 01-20-2012, 01:00 AM   #49
Capt Canuck
Drives: BMW E36 323is
...either way
Where? Apart from your dreams
No way is it going to be under 2600lb... the BRZ's official weight was released and it was in the upper 2700s IIRC. Don't know how the FR-S is going to find 200lbs to lose over that.
Capt Canuck is offline   Reply With Quote
Old 01-20-2012, 01:29 AM   #50
Khyron686
Drives: 2011 Outlander XLS, 2013 FR-S Blue
Push start, silly.
Khyron686 is offline   Reply With Quote
Old 01-20-2012, 01:38 AM   #51
Capt Canuck
LOLOL! :-)
I knew it! That push start ain't nuttin but trouble.
Old 01-20-2012, 02:01 AM   #52
cassidy0998
cassidy0998's Avatar
Drives: '99 Ranger / '94 APU Supra / Ninja!
I hate to burst anyone's bubble. But the FR-S has an almost identical power to weight ratio as the 7th gen Celica GT-S. I haven't done too much research, there are a lot of variables that come in to play, but the Celica is fwd, with 20 less hp but about 200lbs less weight. The FR-S is 200lbs heavier and has 20 more hp... Like I said.. lots of variables, but the Celica had around a 6.5ish 0-60 and ran about a 15 second flat 1/4 mile. I'm expecting the same for the FR-S.
cassidy0998 is offline   Reply With Quote
Old 01-20-2012, 02:38 AM   #53
Khyron686
Gearing, gearing, gearing, gearing.
Also didn't the 02ish celica have a terribly low redline to prevent idiots from 4-2ing their gearbox to death?
Old 01-20-2012, 04:38 AM   #54
serialk11r
Drives: '06 AM V8V Coupe
Mini and GTI aren't good comparisons, they have turbos making tons of boost at low rpm.
I thought RX8 had more like 232hp though? That puts it better than the FRS...
Anyways 1/4 mile reaches higher speeds so FRS could have advantage over Celica with lower drag and more power. They also have similar gearing. My guess is slightly better than Celica in both 0-60 and 1/4 mile. So maybe similar to RX8.
Old 01-20-2012, 05:20 AM   #55
Dark
Elite Padawan
Dark's Avatar
I believe so too. FRS could be a tad slower or faster than rx-8 but not a whole second.
Dark
Dark is offline   Reply With Quote
Old 01-20-2012, 06:44 AM   #56
Levi
Drives: Toyota
Do you change gears at low rpm or high rpm? Turboed cars have no much boost at high rpm.
Levi is offline   Reply With Quote
