View Poll Results: Have you had an issue with your Direct Injection System?
I have had a DI issue and was fixed under warranty (Subaru) 10 12.35%
I had a DI issue that caused Engine Failure and was fixed under warranty (Subaru) 2 2.47%
I have had a DI issue and was fixed under warranty (Toyota) 31 38.27%
I have had a DI issue that caused Engine Failure and was fixed under warranty (Toyota) 3 3.70%
I have had a DI issue and denied warranty by (Subaru) 7 8.64%
I have had a DI issue and denied warranty by (Toyota) 14 17.28%
I had a DI issue that caused Engine Failure and was Denied warranty (Subaru) 8 9.88%
I had a DI issue that caused Engine Failure and was Denied warranty (Toyota) 6 7.41%
Voters: 81. You may not vote on this poll
Old 08-28-2013, 08:37 AM   #323
regal
Drives: Scion FR-S/Toyota Yaris
Well I'm not giving up on these car's.
There is a reason that the calibration changed in the fall of 2012 to ZA1JA01C and no dealer in the USA is allowed to flash this update to cars built before then.
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 08-28-2013, 09:26 AM   #324
xjohnx
Grip>Slip
xjohnx's Avatar
Perhaps the reason is that admitting they changed the ECU mapping would essentially be admitting that there was a defect in the factory map.
Old 08-28-2013, 09:55 AM   #325
thill
Or it could be as simple as dealers cannot link the calibration file to a TSB/bulletin and have no way to perform the update. If it is not in the system, they are not going to update you.
Old 08-28-2013, 09:58 AM   #326
thill
And it is definitely time to stop listening to all the conspiracy theorists around here who have been telling people their engines will meltdown at 30K miles or less..
Egg, meet face..
Old 08-28-2013, 10:40 AM   #327
ft_sjo
Drives: GT86
Originally Posted by ft_sjo View Post
You're wrong, and your last sentence is just nonsense. I give up! You're a lost cause!
OK, so just to be super clear.. on Toyota's system the part numbers DO change.. and just to please your pretty little chops..
In North America.. there are three ECU's.. (for a given trim level)
One from Mar-12 to Dec 12
Another from Jan-13 to Jun-13
And the current is from July-13 to date..
So take what you want from that, my bet would be that's for the 700, A00 and A01 cals accordingly...
Some part numbers to CJ to..
SU003-00440
SU003-04593
SU003-04675
Have a nice day now @regal
Thanks CheapToyotaParts for the info...
Old 08-28-2013, 11:40 AM   #328
Mikem53
Drives: FR-S 6MT
Originally Posted by suaveflooder View Post
Interesting. I was told they couldn't tell. Might have to try another dealer. You already had it or did they update you? Thanks for responding.
They can do a system check on the engine with techstream and it shows the engine calibration level. I did it using my VCI cable and techstream
Mikem53 is offline   Reply With Quote
Old 08-28-2013, 11:45 AM   #329
Mikem53
Drives: FR-S 6MT
SU003-00440
SU003-04593
SU003-04675
I have a feb 13 build with A01 calibration.. According to techstream results.
Old 08-28-2013, 11:50 AM   #330
CSG Mike
CSG Mike's Avatar
Our ECU, even after the emmissions update/recall/whatever is not "ZA1JA01C". It is ZA1JA00C (I know the last 4 digits are A00C).
Correct. A01C was not available for us, period.
Egg, meet face..
We've already done two, and my private count of cars I know of with the DI seal failure is more than I can count on my fingers and toes...
Are you interested in doing an ECU swap with us if you have a newer ECU?
CSG Mike is online now   Reply With Quote
Old 08-28-2013, 11:59 AM   #331
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
SU003-00440
SU003-04593
SU003-04675
So you're likely safe if your car is built after July-13? Those would be the 2014 year models, no?
Old 08-28-2013, 12:07 PM   #332
Mikem53
Drives: FR-S 6MT
Some from jan 13 builds have the A01 calibration
Old 08-28-2013, 12:23 PM   #333
solidONE
solidONE's Avatar
Sorry if I missed it from a earlier post, but how can one check which calibration they have?
Old 08-28-2013, 12:48 PM   #334
CSG Mike
CSG Mike's Avatar
Ask a dealer nicely
Old 08-28-2013, 12:52 PM   #335
Mikem53
Drives: FR-S 6MT
I bought a mini VCI cable and downloaded techstream from a link posted on this site. Techstream has a health check option for the engine.. And it displays the ECM calibration level ..
Old 08-28-2013, 02:09 PM   #336
suaveflooder
SU003-00440
SU003-04593
SU003-04675
So anything built after December 12th should be okay?
@ft_sjo, why is there a month gap between computers? Any Idea? My car falls right in the middle of the December 12 and the January 13 (Mine was built January 4th)
suaveflooder is offline   Reply With Quote
direct injector, engine, failure, meet regal's paranoia, poll, regal's witch hunt, regalnoia, seal, sealions, silly sausage
Injector / seal failure or Miss-fire codes.. please post here mad_sb Engine, Exhaust, Transmission 378 04-24-2020 06:33 PM
Direct Injector Leaking Carwhisperer Issues | Warranty | Recalls / TSB 356 03-13-2020 12:35 PM
Fuel Injector Cleaner Purdue FR-S Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-18-2013 06:54 AM
Wilwood Failure SubieNate Suspension | Chassis | Brakes -- Sponsored by 949 Racing 46 04-09-2013 08:32 PM
Ringland Failure? iLuveKetchup BRZ First-Gen (2012+) — General Topics 9 01-30-2012 12:25 PM
