08-28-2013, 01:48 PM | #99 | |
Drives: BRZ, Canyon
08-28-2013, 06:28 PM | #100 | |
Drives: Honda Fit
Good idea. Also, I was thinking that you might use some teflon tape (a.k.a. plumber's tape) on the threads of the drain bolt and/or the fumo valve. Don't know if teflon tape is rated for a hot oil application, but . . . . Keep us posted. |
09-08-2013, 09:32 AM | #101 |
Just did my very own oil change!
So just got done doing my first oil change EVER!
Parts: Dimple Magnetic Drain Plug Prova Sports Oil filter and Eneos Sustina 0W-20 Synthetic Oil |
09-08-2013, 11:50 AM | #102 |
Drives: Honda Fit
^^I'd like to see a picture of the metal debris (if any) that is on that Dimple Magnetic Drain Plug at your next oil change.
09-09-2013, 01:40 PM | #103 | |
Drives: 2014 Widebody Cosworth FR-S
Nice! I ended up using the Idemitsu 0w-20, OEM black oil filter and the Dimple plug! I'm a bit jealous of your Prova filter and Eneos oil haha. :happy0180: Thanks, Rick |
09-10-2013, 11:47 AM | #105 | |
Drives: Honda Fit
I am always a little cautious about deviating from OEM when it comes to oil filters. After-market filter failures are an incredibly easy way to blow up an engine. Do we have any reliable feedback or assessment of the Prova filter? Thanks. |
09-10-2013, 04:17 PM | #106 | |
Thanks, Rick |
The Following User Says Thank You to RallySport Direct For This Useful Post: | Marrk (09-10-2013) |
09-10-2013, 04:33 PM | #107 | |
Drives: Honda Fit
When you finally do cut that baby open, post the pics. |
09-10-2013, 04:40 PM | #108 | |
Basically they are just a great option for someone wanting a magnetic drain plug, they are super high quality and come with a lifetime warranty. Besides the oil filter, oil, drain pan, funnel and new drain plug gasket, nothing else should be needed. Thanks, Rick |
09-10-2013, 04:41 PM | #109 |
09-10-2013, 04:56 PM | #110 | |
Drives: Honda Fit
FYI Some folks on Bob the Oil Guy pointed out that having a drain plug magnet could lead to an oil blockage, like so: that super-strength Dimple magnet collects a whole lotta metal, then a bunch of it breaks off and circulates to a narrow place in the system . . . and there's your blockage. While I like the magnet idea, there could be unintended consequences, especially with a super-strength magnet. Frequent oil changes or frequent oil changes with an adequate-strength magnet may be just as good an option. |
09-10-2013, 05:08 PM | #111 | |
Everytime I pull my magnetic drain plug for an oil change, I have a film of metal goo on there, and while the oil filter could easily handle that load, it is less debris getting caught in the filter. Now if you ever have enough shavings or metal chunks on the magnet to potentially plug up the pickup tube, oil galleys or any part of the oil system, something else is going on inside the engine, and you may catch it before a catastrophic failure occurs. Also with the Dimple, I am able to pick up hammers, and other large heavy tools with them, I trust that the metal will stick to the plug vs getting swept away in the oil pickup. Now please note all of the above is just my theories/opinion so take them with a grain of salt I have run a magnetic plug on all of my cars for about 8 years, and I have never had a problem before, plus I just like looking at the particles stuck on the plug to make sure it is just normal wear and tear and not a real issue. Hope this helps! Thanks, Rick |
The Following 4 Users Say Thank You to RallySport Direct For This Useful Post: |
09-10-2013, 06:18 PM | #112 |
Snow Don't Hurt!
That's pretty much what my tuner/mechanic said. If there's enough metal being caught to cause a problem, then you have bigger problems to address.
The Following User Says Thank You to chanomatik For This Useful Post: | RallySport Direct (09-11-2013) |
Similar Threads | ||||
Oil Change Questions | #87 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 31 | 06-28-2012 11:06 PM |
Color Change | Dark_Angle | Mid-Atlantic | 10 | 05-30-2012 02:00 PM |
Do you change your own oil? If so, why? | SteelReign | Other Vehicles & General Automotive Discussions | 77 | 04-16-2012 10:12 AM |
I was able to change my pre-order. | nkrein22 | BRZ First-Gen (2012+) -- General Topics | 23 | 04-10-2012 04:16 PM |
Can SOA change my preorder? | Zaneman | BRZ First-Gen (2012+) -- General Topics | 8 | 04-08-2012 02:06 PM |
