Old 08-27-2013, 06:58 PM   #43
Jeff Lange
Jeff Lange's Avatar
Drives: 1986 AE86 GT-S, 2011 Lexus IS250 6M
They are not different between A/T and M/T in Canada and USA.
41110-30A03 - A/T without LSD (Not used in Canada or USA only in Japan and other overseas markets on low-spec cars)
41110-18021 - A/T and M/T with LSD (Used for Canada and USA)
Both are 4.10:1 and externally look the same, but that LSD makes a difference. .
Jeff
2011 Lexus IS350 F-Sport 6MT with LSD
1986 Toyota Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
The Following 4 Users Say Thank You to Jeff Lange For This Useful Post:
37 (08-27-2013), 448hpsti (08-27-2013), Fly Guy (04-22-2014), PantsDants (08-27-2013)
Old 08-27-2013, 09:49 PM   #44
PantsDants
Drives: Scion FR-S A/T, Whiteout
Jeff
It's odd that 41110-30A03 is even listed as a part for the FR-S; I saw it on a few different sites. All I was really getting at was this is further evidence of cross-compatibility between the cars.
PantsDants is offline   Reply With Quote
Old 08-28-2013, 01:58 AM   #45
ReThink
ReThink's Avatar
Drives: Sc10n FRS "DCLXIV"
Subbed
Killer build good sir. Interest is piqued!!
Sc10n FRS #0664
ReThink is offline   Reply With Quote
Old 08-28-2013, 02:08 AM   #46
ft_sjo
Drives: GT86
This might be useful:
Apparently they're all slippers. The first one is about 40% more expensive than the others though. Not sure why, perhaps they're not all slippers!
The Following User Says Thank You to ft_sjo For This Useful Post:
PantsDants (08-28-2013)
Old 08-28-2013, 02:19 AM   #47
PantsDants
Sooo I noticed Weir Performance also offers a 5.71. Naturally, I had to investigate.
M/T, 6th gear, 4.556 final drive: 62.88 mph @ 3000 rpm
A/T, 6th gear, 5.29 final drive: 71.36 mph @ 3000 rpm
A/T, 6th gear, 5.71 final drive: 66.12 mph @ 3000 rpm
Even with the shortest gear ratio they offer, the A/T still cruises at a lower rpm than the M/T with 4.556. Now I'm even more conflicted as to what ratio I want. Can any of you guys with the manual and a 4.556 comment on the noise or loss in mpg? Are there any differential integrity concerns that come with such a short final drive? Other than burning through my tires at an alarming rate?
I'm leaving for my trip tomorrow so I probably won't be on the boards much (that's a lie, I'll probably be lurking the whole time) so don't think I just disappeared without following through on the project. As soon as I get back and make up my mind on the gearing, I'll update with my progress.
Old 08-28-2013, 02:27 AM   #48
PantsDants
Originally Posted by ft_sjo View Post
That last one pulls up on www.lexuspartsnow.com as an IS250 carrier but I don't know if that's a LSD or not. Good info either way.
Old 08-28-2013, 02:46 AM   #49
37
degrees
37's Avatar
Drives: 6MT BRZ
The only true fix there is a manual gearbox.
No noise. Proper alignment is key.
Haven't noticed a considerable loss in MPG on the highway. Maybe -0.5 to -1 MPG? Shorter gears will certainly impact city mileage unless you short shift (but that's no fun).
Differential integrity? No. The 4.556 is a factory ratio and this is a low-torque platform. You won't put down enough torque NA for it to be a concern.
Tires will let loose more easily. Your rate of alarm here is an unknown as the result will vary with your right foot and tire adhesion.
37 is offline   Reply With Quote
Old 08-28-2013, 02:56 AM   #50
PantsDants
Haven't noticed a considerable loss in MPG on the highway. Maybe 1 MPG? Shorter gears will certainly impact city mileage unless you short shift (but that's no fun).
Tires will let loose more easily. Your rate of alarm here is an unknown as the result will vary with your right foot.
Ah, I should clarify. What I meant by noise was exhaust drone on the highway due to the higher revs. I was just asking about the MT with 4.556 as a point of comparison because it should be very similar to what I'm looking at doing if I get the shortest final drive possible, 5.71.
My concerns about diff problems stem from the fact that I'm planning on going suuuper short. I'm fairly certain the 5.29 and 5.71 were made by Toyota for use in the Suzuki Samurai, of all things, and I don't think that had a Torsen.
Old 08-28-2013, 03:04 AM   #51
the.big.kahoona
the.big.kahoona's Avatar
Drives: 2013 Raven 86
Linky? Couldn't find it on their website
the.big.kahoona is offline   Reply With Quote
Old 08-28-2013, 03:05 AM   #52
PantsDants
http://weirperformance.com/finaldrivegears.html
Look under Supra 1986.5-92- ALL.
The Following User Says Thank You to PantsDants For This Useful Post:
the.big.kahoona (08-28-2013)
Old 08-28-2013, 07:40 AM   #53
Captain Insano
Oh my goodness this thread is full of win. OP I can't wait to see your results since I'm really wanting to do a FD modification at some point and I also have an AT - I have same conundrum you face, I keep wondering how aggressive I want it to be.
Captain Insano is offline   Reply With Quote
Old 08-28-2013, 09:25 AM   #54
37
degrees
37's Avatar
Drives: 6MT BRZ
Drone can be judged by downshifting to 5th on the highway. Unless you've removed your cats or installed a cheap, obnoxious exhaust then you should be fine.
Have you plotted out the 5.71? It looks WAY too short, even with an auto trans. To closely match a 6MT with 4.67 in gears 1-2-3 you'd need a 4.9. You might only be focused on gears 4-5-6 and missing how short the first three will become. Don't overlook that as it's a major place where a final drive matters.
Realize that the 6AT in this car will have tall 4-5-6 gears no matter what you do. You either need a 6MT if you want all 6 gears spaced shorter or different auto gears. Shortening the first three too much just to shorten the last three means could mean you'll end up with a street car that's undriveable. You truly would be roasting tires and alarming yourself with a 5.71.
Here is a direct comparison of a 6AT + 4.9 (red) with a 6MT + 4.67 (blue): http://www.teammfactory.com/gearcalc...ission+1+%26+2
Take note of what happens at 4th gear. You can't fix that plot with a final drive. You need different transmission gears.
Originally Posted by Captain Insano View Post
...I also have an AT - I have same conundrum you face, I keep wondering how aggressive I want it to be.
See above. Despite your username, don't go too insane.
The Following 3 Users Say Thank You to 37 For This Useful Post:
Nightbringer (09-03-2013), SpeedR (12-15-2013), TouchMyHonda (08-28-2013)
Old 08-28-2013, 11:01 AM   #55
PantsDants
Thanks again @37. I didn't realize there was such a gap between 1-2-3 and 4-5-6 on the auto. I definitely don't want to go that short after all. I'll play around with the gear calculator some more, but looks like my original idea of 4.88 or 5.29 might be the way to go, as you suggested.
Old 08-28-2013, 01:04 PM   #56
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
WOW! the 5.71 would literally kill drivability 1-3.... it would be SOOO annoying.
TouchMyHonda is offline   Reply With Quote
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
Final Fantasy jay4prez Off-Topic Lounge [WARNING: NO POLITICS] 66 08-25-2013 10:31 PM
Top Gear Crashes Helicopter During Filming of "Top Gear Korea" Episode SteveH Other Vehicles & General Automotive Discussions 7 02-13-2013 12:08 AM
No more 1st gear thump or 2nd gear notchiness kc4mne Scion FR-S / Toyota 86 GT86 General Forum 28 09-06-2012 08:39 PM
Reverse gear on the first and second gear side randytindoggy Scion FR-S / Toyota 86 GT86 General Forum 50 01-29-2012 01:21 PM
