Old 08-27-2013, 09:33 PM   #1
FA20Club.com
Drives: 2013 White Out FR-S
FA20CLUB Innovate Supercharger Tuning, Parts, Improvements & Results
Well, to start off the unit is definitely well built. The power delivery is instant it seems like and pull steadily throughout the rpm range. As far as the down sides. The main issues we have encountered have been related to lack of intercooler, which really hurts those not blessed with 93 octane fuel in their area. This also limits current power limits because of the blower becoming a heat pump when increasing boost levels.
With these issues being a easily solvable nuisance, we decided to spend a bit more time on the back end testing tuning and developing some products for the charger over the last few weeks. What we came up for a few components to reliable increase power and a few more coming down the line as well.
Our first piece was made to properly relocate the Air Temp sensor reading to post blower to accurately read the actual charge temps entering the combustion changer. This aides to minimize tip-knock which has plagued some many owners and tuners. Even though you can try to tune around it its not completely eliminated for those on lower grade fuel or those in higher ambient temp areas. We were given the opportunity to travel to Phoenix, AZ last week to actually test out some of our new tunes for those running 91 octane and high ambient temps. We actually were able to accurately measure power drop based on ambient inlet temp along with Knock correction applied in this extreme environment. Testing on the dyno with the hood open on the dyno vs closed actually equated out to a drop in power to the wheels of about 9-10whp. This more accurately duplicated the actual inlet temps seen on the road. This was verified by looking at previous logs of each car on the road where inlet temps were seen ranging between 48-60 degree Celsius. This also saw the ecu drastically fight to prevent tip in knock and maintain response with small but aggressive application of the throttle.
Some have solved these issues by adding either water methanol injection or running E85 or a blend of either. What we found is that relocating the charge temp sensor to after the blow properly allows for enrichment and timing adjustments to properly and accurately be applied by the ecu once charge temps begin to rise. i dont know about you guys but my hood is closed when i drive around.
Next up for testing are a few different pulley sizes we have recently released.With the quest for additional power first thing to come is a smaller pulley. We have already released the 70mm unit earlier last week. Next up is our more extreme pushhhhhh 66mm pulley. Our first test will be of the 70mm on both pump gas non intercooled and yes INTERCOOLED. And no, this will not be down the line this will be within the week if all goes to planning. We will finish up the testing of the pulleys with E85 and WMIif we can find a kit to borrow
FA20Club.com is offline
The Following 14 Users Say Thank You to FA20Club.com For This Useful Post:
8686 (09-01-2013), boarder1995 (08-28-2013), CSG Mike (08-30-2013), evo4g63 (08-28-2013), FastLane1000 (08-29-2013), feldy (08-28-2013), Hempo (08-28-2013), kombatlion (08-28-2013), Lawnik (09-02-2013), lexusb3 (08-28-2013), mikochu (09-03-2013), Sonolin (08-28-2013), Turbowned (08-28-2013), whataboutbob (08-28-2013)
Old 08-27-2013, 09:33 PM   #2
FA20Club.com
Reserved
Old 08-27-2013, 09:43 PM   #3
Ny Brz
Hella Flush
Ny Brz's Avatar
Drives: 2013 SWP BRZ
And this is why this company is great...keep up the great work.
Ny Brz is offline
Old 08-27-2013, 09:47 PM   #4
FA20Club.com
Thanks Rich, the adapter plate comes with a complete Harness for Plug-n-Play integration
The Following User Says Thank You to FA20Club.com For This Useful Post:
Lawnik (09-03-2013)
Old 08-27-2013, 10:04 PM   #5
sw20kosh
Drives: 2013 Black FR-S
Awesome!!!
So this plate uses a generic IAT sensor?
Is the adapter plate, IAT sensor, and harness available to purchase now?
sw20kosh is offline
Old 08-27-2013, 10:09 PM   #6
FA20Club.com
plates and sensors are ready harnesses ill have ready to go end of the week. im making them at the same time as my flex fuel harnesses while im on the dyno all week. women knit, i solder crimp & loom
The Following 2 Users Say Thank You to FA20Club.com For This Useful Post:
whataboutbob (08-28-2013), wparsons (08-28-2013)
Old 08-27-2013, 10:46 PM   #7
cruizin01
cruizin01's Avatar
Drives: 13' BRZ
In for intercooler info and smaller pulley results. Sway me away from an avo kit.
Sent from my Galaxy Nexus using Tapatalk 4
cruizin01 is offline
Old 08-27-2013, 10:58 PM   #8
mikalem
mikalem's Avatar
Drives: 2020 DGM BRZ Limited
Awesome - been looking at this over Vortech, waiting to see how it all plays out.... this + the FA20Club flex fuel kit and perhaps intercooler? Count me interested.
mikalem is offline
Old 08-27-2013, 11:53 PM   #9
Frostyman
Drives: 2013 Raven FRS
When will pricing be released for the sensor and plate?
Originally Posted by Don@Accelerated
For the sake of argument I went and cut my factory filter housing up.
Frostyman is offline
Old 08-28-2013, 12:38 AM   #10
FA20Club.com
the kits price is $199 includes sensor adapter plate & plug and play harness
Old 08-28-2013, 02:34 AM   #11
FRSRAVEN
How much for a 3bar map sensor thrown in?
FRSRAVEN is offline
Old 08-28-2013, 07:36 AM   #12
nonicname
Drives: it has 4 wheels and a motor
good job on the small upgrade but it's sad that this kit just got $200 more expensive. are the people running 93 oct having ANY problems?
nonicname is offline
Old 08-28-2013, 10:04 AM   #13
FA20Club.com
$99
Old 08-28-2013, 10:09 AM   #14
FA20Club.com
93 is less prone to knock on this kit but i have gotten the same complaints from other customer of other Tuners dealing with their kits and are having the same tip-in knock issues. its one thing to solve the issue on the dyno without extensive testing on the street in extreme conditions. Arizona is is a great proving ground for this type of testing no wonder GM, Nissan Toyota and other manufacturers have private testing facilities right their in the valley.
visconsneaky?
Innovate Supercharger!!! Titanmotorsports Forced Induction 62 08-24-2014 10:25 PM
Delicious Tuning: Offering Innovate Supercharger Stage 1 "Tuner" EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 24 09-20-2013 03:04 PM
Delicious Tuning: FlexFuel Innovate Supercharger EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-13-2013 01:34 AM
FA20CLUB 60 Trim Turbo 16 PSI Results Are In FA20Club.com Forced Induction 148 07-22-2013 08:00 PM
Innovate Results! Pure Automotive Mid-Atlantic 22 07-17-2013 10:09 AM
