Old 08-28-2013, 12:13 AM   #29
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
when ever i start my car i turn off tc, why? Because there's always a corner begging to be power slided through
bkblitzed is offline   Reply With Quote
Old 08-28-2013, 04:01 AM   #30
FRSfan111
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
I only turn TC off if I'm in a safe place with no other drivers that I have plenty of experience in. And the road conditions are good ie no rain ect. The stock tires with TC on often still get me completly sideways in the rain until the tires warm up. However I have track time in the FRS (hpde ect) and plenty of illegal fun times in the mountains in everything from FWD AWD an RWD. I will always Dailey with TC on. Just don't trust other drivers or road conditions. No matter how good the driver shit will happen. It's your responsibility to avoid it.
FRSfan111 is offline   Reply With Quote
Old 08-28-2013, 06:45 AM   #31
Deslock
Deslock's Avatar
Drives: 2013 DZE/01 (sold for MX5 ND1)
Originally Posted by tonytduc View Post
Thanks for posting... I enjoyed the article and corresponding video.
I generally leave it on Sport mode, but I like the button placement (perfect for toggling it off/on for those low speed moments when you want to get the back end loose).
Originally Posted by bestwheelbase View Post
Safety gear is a good backup for safe behavior, not a replacement for being fully aware of what you are doing and what may result.
Mountain climbers don't just clip onto a rope and start ascending a cliff. They know exactly what hand and foot positions to use, what to prepare for, what to do if they slip. They know they have safety gear just in case, but they never want to use it. With cars I do not see why it should be a any different. It should be the last resort, not the first thing that makes someone feel comfortable seeing how far they can push their car.
Yep:
Originally Posted by Deslock View Post
  • VSC is intended to help recover when something unexpected happens. Relying on VSC to drive faster (than you could without it) when conditions are good is especially risky (since running into leaves, oil, water, ice, sand, etc could result in an even higher speed accident).
  • Consider learning a vehicle's dynamics and limits at track days, AutoX, or even sliding around in big empty parking lots (at low speed, when/where it's safe).
  • Use common sense, don't overdrive conditions/visibility, and be prepared.
And:
A rant about misusing traction control:
It's intended as a safety feature in case you encounter an unexpected situation, so it should be left on. But don't use it to drive faster than you can without it.
I knew two drivers who had 2006 and 2007 Civic Sis (I'll refer to them as 6 and 7). Only the latter had Honda's TCS/VSA. 7 would fly around corners much faster than 6, not realizing that the computer was the only reason he wasn't crashing.
We all went to an autox, and 6 wasn't doing that well while 7 did great. He was talking a lot of smack about crushing 6's times, so before 7's next run I suggested he disable his traction control (he didn't know how, and I had to show him how to override it).
I've never seen anyone hit so many cones.
Hopefully 7 learned a lesson that day, but probably not. I used to warn him that if he ever came around a corner into a patch of leaves/sand/oil, his crash could be even worse than if he didn't have TCS/VSA (because he was traveling at such high speed). He moved away shortly after and I don't know if he ever had any mishaps.
Deslock is offline   Reply With Quote
The Following 2 Users Say Thank You to Deslock For This Useful Post:
acro (08-28-2013), neurokinetik (08-28-2013)
Old 08-28-2013, 08:00 AM   #32
jarviz
jarviz's Avatar
Drives: Raven FRS MT
Originally Posted by cfusionpm View Post
My last car ended up like this, so I leave mine on all the time. I don't another stupid mistake in a low traction scenario and I'd rather not repeat another wet slide/roll.
Just curious... how fast were you going when you lost control? and did you come from the other side of the road?
jarviz is offline   Reply With Quote
Old 08-28-2013, 08:57 AM   #33
Skurge
Drives: 84 RX-7/13' FR-S
Yeah and don't go to the bathroom either, save more time.
These tough guys driving with TC off will eventually get a bite in the ass, not all but there will be a number. You can simply be driving in the rain, take a corner too fast and where TC could of saved your ass, your dropping the clutch and ending up around a tree somewhere. It's a safety feature and unless your going to be going to be driving 10/10's on the street which i doubt you ever will be, just leave it on.
I remember watching a review of an Enzo, the driver said you can turn TC off for those too stupid or too brave.
On the track? Sure take it off, but i don't want dumbasses taking off an extra safety feature because they think they are Senna re born and crash into my car. I'm glad they are making TC more difficult to turn off in modern day cars.
I'm not sure I enjoy leaving it on, I dont like the intrusion.
I come from driving an RX-7, STI, S2000, none of which had any sort of traction control, VSC or anything, and i can say from experience that the S2000 is a more difficult car to drive at the limit than the FRS is, you just have to be mindful of your throttle/brake/steering inputs. to be honest the FRS has been very easy to drive
Skurge is offline   Reply With Quote
Old 08-28-2013, 09:05 AM   #34
Ammonia
Ammonia's Avatar
Drives: Whiteout FRS, Audi A4, 135i (sold)
I turned mine off and didn't notice a huge difference, except during 'launch' and when the road was moist she got tail happy. And I drive pretty aggressively. Are you guys power sliding and drifting on the streets on the daily? Because I have no clue who would ever need TC to be off during a drive to work.
Ammonia is offline   Reply With Quote
Old 08-28-2013, 09:06 AM   #35
FRiSson
Drives: FR-S MT
Originally Posted by BANGER View Post
I leave all of them off, from driving to school to picking up the mail.
Because racecar.
Always leave underwear off, from bathroom to outdoor sports.
Because digestion.
FRiSson is offline   Reply With Quote
Old 08-28-2013, 09:18 AM   #36
DylanFRS
Lost in Kansas
DylanFRS's Avatar
Drives: 2013 Scion FRS (Raven)
I turn mine off for autocross and am wayyy faster. We had a rain event the other day, whole course was standing water and I had a difference of 3 seconds with everything off vs TSC Sport.
@bkblitzed : You gotta change your sig man. Every time I come across one of your posts I just stop and stare for like 5 minutes before I remember where I am.
DylanFRS is offline   Reply With Quote
Old 08-28-2013, 09:24 AM   #37
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
I tested using sport mode vs all nannies off. I was faster with the nannies off. Sport mode would alter the vehicles behavior in a slide or when it broke traction. I would try to counter a drift or slide like I normally would with the nannies off and the car would just jerk back the other way.
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
Old 08-28-2013, 09:45 AM   #38
cfusionpm
Drives: Firestorm 6MT Scion FR-S
Long sweeping freeway transition curve, maybe ~45 mph. The entry is downhill and I usually just coast through it with no gas until after the apex. This was slower than I usually take that corner, but I guess not slow enough. It had just rained that morning (and was still raining) after several months of no rain. If you're familiar with those kinds of conditions, it turns the road into an ice rink since all the oil and other gunk on the road is lifted, but not washed away. As the back end slid out and onto wet grass, there was no saving it. If the slide was on flat ground it wouldn't have been a problem, but it sloped about 30º downhill. As I slowed near the bottom, wheels dug in and 180'd onto the roof. There were about 330 other accidents that day alone just in San Diego; the tow truck said he passed half a dozen just in the small strip of road he took to get to me. If I had just tapped the brakes instead of trying to coast through the corner, I'd still have my tC.
2013 Firestorm 6MT Scion FR-S
cfusionpm is offline   Reply With Quote
Old 08-28-2013, 09:47 AM   #39
thill
Originally Posted by campy View Post
I keep my traction control off to shave tenths off my mcdonalds drive thru times
I nearly spit my orange juice out when I read this! It was exactly what I was thinking...
I leave mine on about 90% of the time because, well, I am driving the car to and from work and I view TC as a safety advancement. I have grown up driving RWD sports cars without TC and understand how to control the car, but I don't find TC intrusive most of the time.
For those of you that are new to RWD sports cars, I would leave them on until you get more experience behind the wheel in a controlled environment with them off.
The Following User Says Thank You to thill For This Useful Post:
feedbag (08-29-2013)
Old 08-28-2013, 09:51 AM   #40
FRiSson
Drives: FR-S MT
Nice strong roof structure on that TC. Impressive.
The Following User Says Thank You to FRiSson For This Useful Post:
cfusionpm (08-28-2013)
Old 08-28-2013, 10:35 AM   #41
FReddy
FReddy's Avatar
Drives: 2013 Argento
Thumbs up
Originally Posted by juliog View Post
My own experience with the FR-S (can't speak for other cars):
- If you're a beginner, TC ON will make you faster on the track/autox. Poor throttle inputs during cornering with TC OFF + prius tires = spin out (I know!).
- After one or two track days or autox's, VSC ON may be faster (YMMV). You're better at modulating throttle input but still make rather big mistakes once in a while. Having VSC ON increases the slip angle threshold before the computer kicks in, so now you can corner faster.
- As you gain seat time and start going faster and faster, TC becomes too intrusive, literally slowing you down. So at this point you turn it off.
I think if you have to ask, then leave the aids on. When it's time to turn them off, you'll know.
On the street I leave everything on, save for one or two canyons that I know very well and trigger the TC even at moderate speeds.
Well said. My thoughts, exactly.
F
FReddy is offline   Reply With Quote
Old 08-28-2013, 10:44 AM   #42
SVTSHC
(ノಥ益ಥ)ノ
SVTSHC's Avatar
Drives: 2015 Series Blue BRZ
With some people it just takes a hard lesson for them to learn. Honestly, how often does traction control interfere with your daily commute?
"Sweet Subaru, sweet Subaru, send your BRZ unto me, for the roads of the unworthy must be baptized in speed and glory." ~Zaku
SVTSHC is offline   Reply With Quote
How to disable Traction Control (TC) and Vehicle Stability Control (VSC) Completely Sigh-on-Rice DIY (Do-It-Yourself) Guides 58 03-02-2015 01:48 PM
traction control question Sileighty_guru BRZ First-Gen (2012+) — General Topics 9 09-26-2012 09:54 PM
CEL Traction Control ON then OFF HATED1 Issues | Warranty | Recalls / TSB 5 09-24-2012 07:11 PM
traction control issue *KID* Scion FR-S / Toyota 86 GT86 General Forum 13 07-08-2012 08:13 PM
Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely BabyGodzillaGTi-R BRZ First-Gen (2012+) — General Topics 40 04-25-2012 11:20 AM
