Old 08-27-2013, 10:06 AM   #15
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by brillo View Post
what are the specs of the idiot light anyways? how low does pressure have to fall for it to go off?
Someone posted about it a long time ago, I believe they said it was something like 3 or 2 psi. Ridiculously low.
Old 08-27-2013, 10:10 AM   #16
brillo
Drives: 2013 Firestorm FR-S
is there a way to buy one with a better sensor? Like 10 psi or something that would indicate trouble at idle? That seems pointless.
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
Old 08-27-2013, 10:28 AM   #17
Sportsguy83
Drives: Limited BRZ
No idea.
Old 08-27-2013, 10:51 AM   #18
bgibbsunc
bgibbsunc's Avatar
Drives: Firestorm Scion FR-S
I went with AEM failsafe. Not really for the failsafe but for the dual gauge AFR and boost. I also went with the innovate MTX oil pressure/oil temp gauge. Again for the dual gauge. I hate gauges honestly and there isnt the best mounting locations in this car that are affordable. Therefore 2 dual gauges was perfect for my setup. Ill be installing next week and will post up pics. Oh and the P3cars gauge looks nice but for me it was a definite no go. I am a strong believer that you need to see all these things at all times. So for me it wouldnt work to have to switch between different settings. If something catastophic is going to happen you dont have time to switch between gauges to see whats going on. Just my 2 cents.
FA20 club 60 trim + flex fuel
467 whp 356 ft lbs @ 19 lbs
Owner of Sidewinders Auto LLC.
San Antonio TX
bgibbsunc is offline   Reply With Quote
Old 08-27-2013, 10:53 AM   #19
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I don't know that I can remember anyone seeing it ever come on or them having a oil pressure gauge to know at what PSI it lights up at either. @Dave-ROR was doing alot of oil pressure testing. Should be easy enough to pull it off the motor and put it in a pressure vessel to test it. See what signal it puts out and what thread pattern it is and then find an aftermarket low oil pressure switch that matches.
Old 08-27-2013, 11:09 AM   #20
Sportsguy83
Drives: Limited BRZ
Copycat you say?? J/K awesome choices!
Old 08-27-2013, 11:12 AM   #21
bgibbsunc
bgibbsunc's Avatar
Oh crap I knew you had the AEM but didnt know you had the innovate. I honestly thought I was going to be the first. Thanks for raining on my parade. Lmao I really liked your mounting but when I asked about it he told me 6 weeks. needless to say couldnt do that lol. I ended up getting the defrost vent gauge but a dual it actually looks really clean and does obscure vision like the A-pillar.
San Antonio TX
The Following User Says Thank You to bgibbsunc For This Useful Post:
Sportsguy83 (08-27-2013)
Old 08-27-2013, 12:04 PM   #22
infinite012
Drives: 13 DGM BRZ Ltd
Just stay away from the cheapest of the cheap: Prosport, Glow Shift, vatuzone specials, etc.
infinite012 is offline   Reply With Quote
Old 08-28-2013, 08:25 AM   #23
pierce88
pierce88's Avatar
Drives: SWP BRZ Limited
Completely agree. Had Prosport in m Legacy GT (matched PERFECTLY) and they weren't good for anything but looking good.
-Pierce
pierce88 is offline   Reply With Quote
Old 03-03-2015, 10:03 PM   #24
The86Ghost
Drives: 2014 FRS (Whiteout)
I heard glowshift was pretty decent?
The86Ghost is offline   Reply With Quote
Old 03-04-2015, 03:41 AM   #25
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
I'd really like the SPA Technique Dual Gauges (specifically the model DG 213 Pressure/temp one).... Kind of expensive at ~$350, but I can't think of a better value gauge for oil pressure and temp reading on the market (0.1 psi resolution with a vacuum to 232psi range, programmable alarms, callback function of peak readings, programmable outputs, comes with all sensors, etc...)
https://www.spatechnique.com/product...dualgauges.cfm
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
Old 03-04-2015, 04:49 AM   #26
WesleyG
Drives: 2014 Satin White Pearl GTS auto
I have autometer sportcomps, and they are not bad at all, for the price
2002 MR2 Spyder 2zz-GE Apexi PFC PPE Race header 8500 RPM of FUN
2014 37J 86 Auto
WesleyG is offline   Reply With Quote
The Following User Says Thank You to WesleyG For This Useful Post:
Hyper4mance2k (03-04-2015)
Old 03-04-2015, 05:25 AM   #27
themadscientist
Hotlink Terrorist
themadscientist's Avatar
Drives: 2015 WRB BRZ Spec S
I guess I find it hard to believe you can't find all three in one gauge for less than $100.
Damned difficult. Figure out how much your engine is worth to you. It sounds like false economy to be concerned enough about a pressure or temp reading to get a meter, but not enough to spend the coin to ensure accuracy. It's like putting an engine together with an off-brand $40 clicker torque wrench.
That's the gauge package in my 60hp three banger minitruck. I beat the hell out of it so I watch my meters.
My old Skyline.
If you care enough to ask a gauge a question, make sure it can give you an unquestioned truthful answer.
Defi and Greddy are my go to. I've never used AEM so I have to defer to those that have on how good it is. IMO the twins seem to run hot and leak oil so I would demand the minimum three pack of oil pressure and temp and water temp.
Never trust stock gauges.
Old 03-04-2015, 07:13 PM   #28
Mechazawa
Drives: FR-S, 6MT, White
I have been happy with vei in the past. Pretty sure they manufactur most of the special application vent mount gauges on the market.
http://www.veisystems.com/ws/
Mechazawa is offline   Reply With Quote
Can you tell me who makes this wing? bdanisi Cosmetic Modification (Interior/Exterior/Lighting) 11 02-02-2014 09:02 PM
Who makes 2.75 front pipes? Hawk77FT Engine, Exhaust, Transmission 10 07-02-2013 07:37 PM
Right gas makes big difference Carbon420 Scion FR-S / Toyota 86 GT86 General Forum 33 06-22-2013 06:03 PM
Anyone know who makes this wing? deadsailor86 Cosmetic Modification (Interior/Exterior/Lighting) 13 01-11-2013 08:38 PM
Who makes this front lip? green_comet Cosmetic Modification (Interior/Exterior/Lighting) 6 10-25-2012 09:01 PM
