Old 08-26-2013, 08:27 PM   #113
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by whitefrs View Post
I doubt is the pedal
It comes from the tranny
Sent from the moon
No clue... Does not sound good. Maybe TO Bearing
Old 08-26-2013, 08:33 PM   #114
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
no fucking way dude
dont scare me now lol
Old 08-26-2013, 08:34 PM   #115
Sportsguy83
Drives: Limited BRZ
no fucking way dude
I'm just guessing, dont pay attention to me. What clutch do u have?
Old 08-26-2013, 08:35 PM   #116
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
ACT 6 puck with Streetlite FW
Old 08-26-2013, 09:17 PM   #117
scraejtp
Drives: 2013 Subaru BRZ
Originally Posted by spitfire481 View Post
I put in a spec stage 2+ over the weekend. Uses stock flywheel. Feels almost identical to stock, slightly harder grab when engaging but not much. I plan to stop tuning around 300-320 whp, so torque won't be too much of an issue for me. Basically just outside the realm of the stock clutch.
Did you have the flywheel resurfaced? If not how many miles did you have?
scraejtp is offline   Reply With Quote
Old 08-26-2013, 09:36 PM   #118
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
8k. It was perfectly smooth and no hot spots. Just wiped it down with brake clean along with the new pressure plate
Old 08-27-2013, 12:37 AM   #119
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
are u having a noise while shifting?
No. The clutch works the same as the OEM one while shifting with no weird noises. The only time it feels different is when launching it in first gear.
Old 08-27-2013, 01:48 AM   #120
pmccut
Drives: Blue Subarus
Are you trying to engage it quick? You need to give it good RPMs and slip it a bit before finally completely engaging it. If you try quick engage, it will grab really hard and it will be al quirky.
Just tried it again. I just can't figure out what I'm doing wrong. If I try slowly engaging (over ~2 seconds) it's just horrible jerking. 2k, 1.5k, 2.5k, doesn't seem to matter. I think I need to find a friend who's used to something this bad and see how they can drive it.
'13 GBS BRZ 6MT | FBM 9:1 w/ GTX3076R| FBM oil cooler + catch-can + radiator + SPAL fans| Rays 57xtreme / PSS | Perrin 2.5" FP | Invidia 2.5" OP | Perrin 3" CBE | RCE T2s | Exedy Stg1
'15 STI LE | Cobb Stg1
pmccut is offline   Reply With Quote
Old 08-27-2013, 07:46 AM   #121
Sportsguy83
Drives: Limited BRZ
I honestly wish you were closer so I could try your car and see if there are any differences than mine.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
pmccut (08-27-2013)
Old 08-27-2013, 08:46 AM   #122
nix
nix's Avatar
Drives: AVO BRZ
Originally Posted by nix View Post
I've run the ACS/AVO clutch plate & flywheel with full organic, carbon puck and currently the ceramic puck disc and they all made some decel noise somewhere between 3500 to 2500 rpm. I wasn't happy with the nvh from the ceramic disc and then with adding the STI engine mounts and either the STI or stock & whiteline trans mounts it's more noticeable.
I have an early 2012 build car, and even when they were stock I noticed I had way more shifter rattle/movement than driving @Benn0r's 2013 build car. So I'm thinking about trying to warranty the shifter with subaru, which could be interesting or try an aftermarket one. It could remove some of the nvh I am getting.
But even with oem mounts the decel was noticable with this clutch combo, and since it's very similar to oem design I expect most clutches will be the same.
In follow up to this - I got the shifter assembly replaced under warranty. There is still a bit of a rattle but not as bad.
More importantly ACS built me a new sprung ceramic button disc with different springs that so far has been quiet under all conditions with their lightened flywheel. Super happy.
nix is offline   Reply With Quote
The Following User Says Thank You to nix For This Useful Post:
Sportsguy83 (08-27-2013)
Old 08-27-2013, 09:59 AM   #123
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Im considering on replacing my clutch.
This noise that it makes while shifting or down shiftings is annoying me
Sent from the moon
Old 08-27-2013, 03:42 PM   #124
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
Originally Posted by Mr.Jay View Post
No one else is running a Exedy clutch?
Really want one that has a OEM feel but stiffer in feel. From what I have seen the ACT 6 is hard to drive and get use too and the FX350 makes lots of noise decellerating and braking?
After speaking with Ptuning and based on their recommendation (no problem with 400whp and 300wtq), I am running the Exedy Stage 1 Organic. I really wanted an oem feel to it, so thats why i went with this.
I just put it in a few weeks back. Still breaking it in, but it feels great. I would be hard pressed to tell the difference from this and stock. Its quiet, and feels good. Engagement is a bit harsher, but barely, and does feel a bit stiffer than stock. Cant compare to anything else, since i have only driven this, but happy so far. Still breaking it in, so time will tell. I doubt the average person would even notice that its not a stock clutch.
gdrider77 is offline   Reply With Quote
The Following 2 Users Say Thank You to gdrider77 For This Useful Post:
civicdrivr (08-27-2013), Mr.Jay (08-27-2013)
Old 08-27-2013, 06:08 PM   #125
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Any rattles while idle and AC on?
Sent from the moon
Old 08-27-2013, 06:14 PM   #126
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Sent from the moon
Dreams money can buy
Clutch engagement issue. Possible clutch cylinders upgrade? wu_dot_com Engine, Exhaust, Transmission 42 04-05-2016 12:11 PM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 12:22 PM
Clutch Masters Clutch Kits | Island Import Performance IslandImportPerformance Transmission and Driveline 1 07-20-2012 12:06 PM
ATS carbon clutch collaboration model prototype clutch 86 & BRZ kanundrum Engine, Exhaust, Transmission 41 02-27-2012 03:48 PM
