Old 08-26-2013, 12:33 PM   #15
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
Originally Posted by PantsDants View Post
Just curious, why didn't you buy the shims and pinion bearing from him as well? Markup? He also told me to replace the pinion nut, FWIW.
Maybe his kit comes with it. I say I spoke with him, but really it was my brother. The rear end in his corolla has Weir axles, ring and pinion and pinion spacer. So he just got in contact with him for me since he already has a repor with him.
Dustin is offline   Reply With Quote
Old 08-26-2013, 12:33 PM   #16
PantsDants
Drives: Scion FR-S A/T, Whiteout
Originally Posted by Hawaiian View Post
So, for the FI guys, would the IS300 carrier be a direct swap FD and all, so we can run the auto LSD and get down to a 3.9 FD without any other changes?
Theoretically, yes. You could also get down to a 3.7 if you wanted from a manual IS. I keep saying theoretically because the fact of the matter is I haven't completed this yet, but the IS300 carrier is supposed to just bolt right on.
PantsDants is offline   Reply With Quote
Old 08-26-2013, 12:40 PM   #17
PantsDants
Originally Posted by Anthony View Post
So...
- Ring
- Pinion
- Shim
- Carrier if you don't want down time
That's it? I don't care about down time, so could I just buy the 4.88 ring and pinion, find a matching shim, and go to town?
The bare minimum that I was told I would need, in addition to the ring and pinion, was shims, pinion nut, pinion seal, and solid spacer. However depending on how many miles are on your carrier, you may also need bearings.
Old 08-26-2013, 12:42 PM   #18
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
10k
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 08-26-2013, 12:50 PM   #19
37
degrees
37's Avatar
Drives: 6MT BRZ
You won't need a solid spacer unless you're putting down MASSIVE amounts of torque. You'll break your factory trans long before your ring gear successfully shoves the pinion forward. My rear end had under 2000 miles and the factory spacer was reusable. Same for the pinion nut.
A solid spacer won't hurt but definitely isn't mandatory.
I would highly recommend adding side seals to your list as they'll likely need to be popped out to check diff clearances. They're cheap.
37 is offline   Reply With Quote
Old 08-26-2013, 12:53 PM   #20
charged86
charged86's Avatar
by carrier you mean the actual differential?
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 08-26-2013, 12:53 PM   #21
Anthony
Weight Nazi
Anthony's Avatar
Yeah, I'm not looking to go bare minimum anyway. I'm looking to go long lasting, reliable, and done correctly. Saving money compared to the Mfactory 4.67 would just be a nice byproduct.
Old 08-26-2013, 01:07 PM   #22
Anthony
Weight Nazi
Anthony's Avatar
For the record, according to: http://www.teammfactory.com/gearcalc...ission+1+%26+2
215/45/17 @ 4.88 final drive would mean...
1st - 29
2nd - 48
3rd - 69
4th - 87
5th - 106
6th - 138
I wonder what 6th gear would top out at with factory power and this ratio.
Old 08-26-2013, 01:42 PM   #23
PantsDants
By carrier I mean the "pumpkin" or housing that contains the differential. The two terms are often conflated so I figured I'd try to be as specific as possible. What I bought was a factory IS300 rear differential carrier, it comes with the differential inside obviously.
Old 08-26-2013, 02:02 PM   #24
PantsDants
Thanks. Is this the right part for the side seals? http://www.partsbase.org/parts/toyota-9031143009/
Old 08-26-2013, 02:27 PM   #25
37
degrees
37's Avatar
Drives: 6MT BRZ
Yes, that's it.
My post here has part numbers for what's needed: http://www.ft86club.com/forums/showp...5&postcount=45
Old 08-26-2013, 02:39 PM   #26
Dustin
Twin Screw You
Dustin's Avatar
I'm not 100%, but I believe doing this will be the only way to do all the OEM final drive part numbers I posted before. From what Spence @ Weir Performance was saying, the internals in the stock FRS rear end are not compatible. Maybe @8686 can clarify with the OEM 4.56 he just purchased.
Old 08-26-2013, 03:34 PM   #27
PantsDants
Yes, that's it.
Thanks again man, that's really helpful. I may just order all of those online rather than going with a kit that may or may not be incomplete.
Regarding the washers, would that be something a differential shop would just have on-hand? Or is there an actual set from Toyota? Same thing goes for the shims, are those specific to this application or is that something they could just have laying around already?
Old 08-26-2013, 03:42 PM   #28
37
degrees
37's Avatar
Drives: 6MT BRZ
No prob. I updated my post to include diff washers as well.
I can't speak to what a dealer might have on hand for diff washers. A good performance shop will either fab their own or already have them on-hand. That's difficult to answer since every dealer and shop will be different.
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
Final Fantasy jay4prez Off-Topic Lounge [WARNING: NO POLITICS] 66 08-25-2013 10:31 PM
Top Gear Crashes Helicopter During Filming of "Top Gear Korea" Episode SteveH Other Vehicles & General Automotive Discussions 7 02-13-2013 12:08 AM
No more 1st gear thump or 2nd gear notchiness kc4mne Scion FR-S / Toyota 86 GT86 General Forum 28 09-06-2012 08:39 PM
Reverse gear on the first and second gear side randytindoggy Scion FR-S / Toyota 86 GT86 General Forum 50 01-29-2012 01:21 PM
