View Poll Results: Have you had an issue with your Direct Injection System?
I have had a DI issue and was fixed under warranty (Subaru) 10 12.35%
I had a DI issue that caused Engine Failure and was fixed under warranty (Subaru) 2 2.47%
I have had a DI issue and was fixed under warranty (Toyota) 31 38.27%
I have had a DI issue that caused Engine Failure and was fixed under warranty (Toyota) 3 3.70%
I have had a DI issue and denied warranty by (Subaru) 7 8.64%
I have had a DI issue and denied warranty by (Toyota) 14 17.28%
I had a DI issue that caused Engine Failure and was Denied warranty (Subaru) 8 9.88%
I had a DI issue that caused Engine Failure and was Denied warranty (Toyota) 6 7.41%
Voters: 81. You may not vote on this poll
Old 08-24-2013, 06:44 PM   #295
AyJay
AyJay's Avatar
Drives: 22 GR86, 13 FR-S, AP2 S2000
Quoting myself from a different thread:
Originally Posted by AyJay View Post
I visited my local Scion dealership this morning for my free 7500 mi service. Came up empty regarding the ZA1JA01C reflash. That ended up being a complete waste of time. Dealership did state that I'm currently at ZA1JA00C and 01C does not exist in their system. I have a good friend in a different dealership's parts dept that is going to verify the existence of 01C for me.
I brought a copy of the SA "TSB" with me so they were able to read about the problem. The "high rpm detonation" is the service dept's words not mine.
AyJay is offline   Reply With Quote
Old 08-24-2013, 10:43 PM   #296
Porsche
Drives: 2013 BRZ Ltd. MT
Originally Posted by regal View Post
Porsche, good question.
Yes, I know; thank you. Questions, actually … plural.
I was hoping for good answers. Comprehensive answers.
I'm still waiting.
But I'm not going to badger you if you choose to focus on evasion rather than explanation.
Maybe you live in a flat straight road terrain where you can somehow drive in the power band without lifting on/off the throttle ?
Shall we conclude that you are now asserting that any operation above 5200 rpm will produce damaging, uncontrolled detonation?
Is there another rational interpretation, an alternative conclusion to be drawn from your statement?
If not, then please account for EXACTLY why this is so. I do not accept this at face value, this 5200 rpm limitation to avoid catastrophe. I respect your experience, knowledge, skills, and abilities. I respect your intellect, Regal, but I cannot accept the above assertion at face value; it seems somewhat preposterous.
I require supporting, DETAILED EXPLANATIONS, and a compelling argument if I am to be convinced.
I am not saying you are wrong. I am saying that your so-called "arguments" have failed to convince. You are capable of much better … assuming that you have indeed thought this out carefully and are standing on solid ground.
Convince me, please.
I'm hoping to redirect your persistent complaints to an equally insistent determination to find SOLUTIONS.
I know you are dissatisfied. You are not alone.
Rather than continue to curse the darkness, let us light a candle, shall we?
Porsche is offline   Reply With Quote
Old 08-26-2013, 07:13 AM   #297
wes1202
Drives: 86
what are the signs for this ?
wes1202 is offline   Reply With Quote
Old 08-26-2013, 07:59 AM   #298
JRTNOLA
Drives: Subaru BRZ
I just got back from the dealer. I live in Dubai and have 35000 km on my car. It runs extremely bad after the engine is driven on for about 40 miles or so. They won't cover the warranty because I had the oil changed some where other than the dealer. What a crock of SH*T!!!! I will never buy another Subaru or Toyota again!!!!!! They want to charge me $3000.00 for 4 injectors and a fuel pump.!!!!
JRTNOLA is offline   Reply With Quote
Old 08-26-2013, 08:12 AM   #299
xjohnx
Grip>Slip
xjohnx's Avatar
Call Subaru corporate. I'm not sure how it works in Dubai, but here as long as you can prove the oil was changed and replaced with OEM spec'd parts (oil/filter), they shouldn't be able to deny your claim.
Old 08-26-2013, 10:35 AM   #300
frs10
Drives: tezla
so is this happening to modded or stock engines only or both?
frs10 is offline   Reply With Quote
Old 08-26-2013, 11:15 AM   #301
suaveflooder
Stock are the main ones I've seen. It has to do with the factory tune. Lots to read, but most of this is covered in the thread. :happy0180:
suaveflooder is offline   Reply With Quote
Old 08-26-2013, 11:16 AM   #302
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
both
Old 08-26-2013, 11:38 AM   #303
frs10
Drives: tezla
this thread is confusing to follow...
maybe they should make an anonymous poll? doesnt seem like people are being too honest with what they did to the car before things like this happened... has anyone with a fully stock car, not tuned, non tracked, not "abused" having DI failure?
Old 08-26-2013, 11:47 AM   #304
suaveflooder
lol. Agreed! Fully stock, yes. The conditions that tend to lend to the issue seem to be quick on and off throttle up high (5200 rpm is the magic number) where the transient tables are non existent in the stock tune. Obviously more common condition in open track cars. Oddly enough, a tune looks to be the fix to the failure and also the end of your drivetrain warranty. So, for now, a lot of us are just waiting for toyota to step up and fix the tune. There is already a "fix" out, but as far as I'm aware, unless you have a newer car or are within a certain vin range, they aren't doing the calibration (there is no TSB). I tried to get it last week and they told me my vin was out of range of the cars they would re-flash.
The Following User Says Thank You to suaveflooder For This Useful Post:
forwallblakmail (08-26-2013)
Old 08-26-2013, 11:58 AM   #305
CSG Mike
CSG Mike's Avatar
Originally Posted by thill View Post
And there is the whole warranty thing. Yes, at least one person has been denied their warranty for tracking their car, but if your seals go bad and your engine seizes you have 5yr and 60K miles of warranty if your car is affected.
We know that not all cars are affected, so telling everyone to shift under 5200rpm is just bad advice.
Drive the car like you would normally drive it. If you track the car a lot and have not had the latest calibration file installed, work with your dealer or Toyota or Subaru corporate and express your concerns.
There are many more silent members who have had denied warranty claims that I am aware of.
Old 08-26-2013, 12:08 PM   #306
frs10
Drives: tezla
do you have the VIN range handy?
Old 08-26-2013, 01:08 PM   #307
thill
Probably, and they are probably silent for legal reasons, but without hard evidence and facts, it is not very helpful.
Old 08-26-2013, 02:20 PM   #308
CSG Mike
CSG Mike's Avatar
No it's not
direct injector, engine, failure, meet regal's paranoia, poll, regal's witch hunt, regalnoia, seal, sealions, silly sausage
Injector / seal failure or Miss-fire codes.. please post here mad_sb Engine, Exhaust, Transmission 378 04-24-2020 06:33 PM
Direct Injector Leaking Carwhisperer Issues | Warranty | Recalls / TSB 356 03-13-2020 12:35 PM
Fuel Injector Cleaner Purdue FR-S Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-18-2013 06:54 AM
Wilwood Failure SubieNate Suspension | Chassis | Brakes -- Sponsored by 949 Racing 46 04-09-2013 08:32 PM
Ringland Failure? iLuveKetchup BRZ First-Gen (2012+) — General Topics 9 01-30-2012 12:25 PM
