Old 08-23-2013, 09:51 PM   #323
Erza_ft86
Drives: the raven frs
RCE TARMAC 0 All the way down in the front and still got some room in the rear. 280 springs all the way around
I had a VW GTI before this and everyone in the vdub world just cares about how low you are. I didnt want to do this with this car and ruin the handling so i went with the tarmac 0s... I recently took out to my local canyon roads and WOW! huge difference. Handling was greatly improved and the ride is still great. Awsome set of coilovers. Thank you RCE
Erza_ft86 is offline   Reply With Quote
The Following User Says Thank You to Erza_ft86 For This Useful Post:
Racecomp Engineering (08-24-2013)
Old 08-24-2013, 01:33 PM   #324
Colombo
Drives: '13 BRZ
Originally Posted by FR-S Matt View Post
No, the brakes just dangled in the back and I left them there and just pushed the lines aside while I installed the coils. The stock lines are the only thing I can think of that would be causing the seize. I find it hard to believe a car with 9400 miles has a bad caliper, but I will find out when I inspect it. Right now the caliper is locked on one of the wheels but I wasn't able to see which one.
If it turns out to be a bad caliper, I suppose new brake lines are on the list.
Are you saying that you had the calipers dangling from the brake lines and not supported in any other way?
Colombo is offline   Reply With Quote
Old 08-25-2013, 05:57 PM   #325
FR-S Matt
Yes, I let the rears dangle down while installing. The lines weren't stretched nor did the calipers hit anything. I let them down carefully.
Old 08-25-2013, 08:06 PM   #326
mfbmike
Drives: 2013 FRS, 2008 R32
This is my car on Tarmac 0's
Tires are Michelin PSS 245/35/18, Traklite Angle 18X9 wheels, and the Tarmac's
Originally Posted by Asphaltfrs1 View Post
My FRS on Tarmac 0s w/ rpf1s on 255/35 bf Goodrich tires
Love it guys. What are you guys ride heights set at (threads left, etc.)?
Still narrowing done the suspension I want to get on my car and these Tarmac 0's may be leading the race now.
Your pic isn't working
Funny you mention that. I had an R32 and was maxed out on H&R coils.
Handling was certainly not ruined and I was still able to drive the absolute piss out of it both down here in Miami and on the occasions I took it up north to rip up mountain twisties in NC/GA/TN. I hope to accomplish the same with this car while still eliminating a good portion of the stock wheel gap.
PM me for pricing to 33182 please.
mfbmike is offline   Reply With Quote
Old 08-25-2013, 08:10 PM   #327
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Thanks for the kind words. IIRC, i have 0.5" inches of thread left in the front and 1.5" on the back.
Come out to the next meet if you want to see it/measure it in person
The Following User Says Thank You to Sportsguy83 For This Useful Post:
mfbmike (08-25-2013)
Old 08-25-2013, 08:15 PM   #328
UnOvertime
UnOvertime's Avatar
Drives: Firestorm FR-S AT
Currently 1.25" all the way around, but I am looking into wheels soon so I will be adjusting it again.
UnOvertime is offline   Reply With Quote
Old 08-25-2013, 08:40 PM   #329
mfbmike
As soon as I get my 86 (should be this week, last stock bits are going back on the R32 as we speak), I'll definitely make it out! Hoping my work schedule allows me to get out on the nights the meets take place.
Did you also have to install the bushings or LCA's at your ride height? Part of me thinks I might want to go slightly lower.
@UnOvertime, same question - did you have to install the other components or did you just do the coils? I read your alignment specs were "okay" for daily driving.
The Following User Says Thank You to mfbmike For This Useful Post:
Sportsguy83 (08-25-2013)
Old 08-25-2013, 09:03 PM   #330
Sportsguy83
Drives: Limited BRZ
SPC LCA's on the back to dial in camber from -1.8 one side, -2.4 the other. The slotted front allowed me to be at -.8 on the front. With the LCA's I'm at -1.4 on the back. Also, my drop was close to 1.25" all around too.
Old 08-25-2013, 09:11 PM   #331
coolaron
How low can you go down with Tarmac Zero from stock? Is it 1.5" or 2"?
coolaron is offline   Reply With Quote
Old 08-25-2013, 10:50 PM   #332
UnOvertime
UnOvertime's Avatar
I did not do anything for camber correction. I may just go with the OEM crash bolts up front when I get wheels in the next month or so. LCA's would have been what I went with for rear camber, but I feel they are overkill for my DD setup.
The Following User Says Thank You to UnOvertime For This Useful Post:
Old 08-25-2013, 10:56 PM   #333
UnOvertime
UnOvertime's Avatar
From what I can tell it is probably 1.5", maybe a tad lower, but not close to 2".
coolaron (08-26-2013)
Old 08-26-2013, 01:17 AM   #334
Erza_ft86
@mfbmike sorry I fergot to resize my photo so its probably to big. I uploaded it to photobucket so I hope this works.
[IMG][/IMG]
BTW the gti looks good. I loved my gti but it would get destroyed my frs in the canyons which is where I usually have most my fun! since where sharing pics of the mkv's I cant resist. Here was my old baby
[IMG][/IMG]
Old 08-26-2013, 08:35 AM   #335
Sportsguy83
Drives: Limited BRZ
1.5" MAX
Old 08-26-2013, 10:39 AM   #336
Gopherboy6956
Gopherboy6956's Avatar
Drives: 13 BRZ Limited WRB
I just have the whiteline rear camber bushings and the Tarmac 0's. Here's my alignment sheet:
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925
Gopherboy6956 is offline   Reply With Quote
The Following 2 Users Say Thank You to Gopherboy6956 For This Useful Post:
448hpsti (08-26-2013), chanomatik (08-27-2013)
Racecomp Tarmac II Clubsport coilover JoeBoxer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 47 11-16-2013 11:02 PM
Tarmac Zero Coilovers Specs? tintumz22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 06-13-2013 11:26 PM
KW CLUBSPORT COILOVERS W/ FREE SHIPPING FOR THE SCION FR-S/SUBARU BRZ!!! NJA Brakes, Suspension, Chassis 7 03-30-2013 08:26 PM
Wheel Directory: Enkei ES-Tarmac 16x7.0 +45 quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 09-12-2012 12:24 PM
Toyota 86 Tears Up Tarmac at 2012 TAS (TRD, N1, HKS, Up Garage Models) + LFA Roadster knoxviue FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 35 01-20-2012 01:44 AM
