Old 07-08-2013, 03:21 PM   #15
Racecomp Engineering
All these companies can say this and that but at the moment, no one really knows what really works well with the shocks. Only time will tell, but from what i keep reading, the Swift shocks are very close to stock in terms of feel and ride, which might mean nothing but sounds like a best bet. In terms of rates...
The yellows get great reviews but they seem to be quite harsher then stock set up.
Ideal set up would be Koni shocks and yellows (or other springs) if your worried about OEM shocks.
The average for your lowering your car with springs on stock shocks is about a year or so of aggressive/spirited driving intill you'll start to feel a loss in responsiveness, IMO.
I wouldn't say that the RCE yellows make things quite harsher, and many others agree with my biased opinion . It's actually very close to stock or better IMO in most situations, with a slight tradeoff on really large bumps.
Many have had our springs on for more than a year now FYI. Subaru gave us a prepoduction car very early and we were able to do quite a bit of testing, plus Myles bought one of the first BRZs in the area. Lots of time testing and trying things. Stock shocks are pretty good...not amazing and not Konis, but also not horrible weak little things. Just keep the springs close to critically damped and don't slam it on the bumpstops and they'll last.
That said, there is much to gain performance-wise from Konis or possible other options that may come out in the future. They'll also let you go with firmer spring rates with less of a penalty in ride quality. And they'll likely last longer.
- Andy
ATL BRZ (07-08-2013), dem00n (07-09-2013)
Old 07-08-2013, 03:28 PM   #16
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
I love the ride on my RCE Yellows!
The Following User Says Thank You to ATL BRZ For This Useful Post:
Racecomp Engineering (07-08-2013)
Old 07-08-2013, 03:56 PM   #17
stockysnail
Just the tip
stockysnail's Avatar
I currently have the RCE Yellows and previously other brands and rode in other cars with other brands. The RCE Yellows are the best performing in my opinion and feel more comfortable than stock. The only downside, which to some it's not a downside, is that they don't lower the car enough. Function > form is my mantra however, so RCE Yellows FTW! Yes adding the Koni Yellows will make it even better. I know first hand as I have them. See my build thread for info on my daily driven impressions. Track day coming next month.
The Following User Says Thank You to stockysnail For This Useful Post:
Old 07-09-2013, 01:12 PM   #18
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
- Andy
Don't worry, i'm still going to buy your springs.
The Following User Says Thank You to dem00n For This Useful Post:
Racecomp Engineering (07-09-2013)
Old 07-09-2013, 02:48 PM   #19
We just released a new spring called the TARMAC spring with higher rates for the Koni's and a lower drop of about 1inch.
Myles
Old 07-11-2013, 03:51 AM   #20
Obja
Obja's Avatar
Drives: Raven FRS/c5 Corvette
what about Eibach Sportline? is that compatible
Obja is offline   Reply With Quote
Old 07-11-2013, 09:11 AM   #21
Nightbringer
Nightbringer's Avatar
Drives: Scion FR-S
Sportlines are compatible, but a few members have had bad experiences with them and stock struts I'm told. The drop is pretty aggressive. Just something to be cognicent of.
Nightbringer is offline   Reply With Quote
Old 07-11-2013, 09:55 AM   #22
wparsons
wparsons's Avatar
The Swift springs are designed for OEM dampers as well, and have different rates for the FR-S and BRZ.
flickr
Old 08-25-2013, 06:31 PM   #23
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Wishingful thinking here, but are there any springs available with at least a 1" drop that are matched to the OEM shocks?
hmong337 is offline   Reply With Quote
Old 08-25-2013, 06:46 PM   #24
whataboutbob
AutoX-10/10ths every run
I'm almost a year into running on the RCEs on factory struts. Dozens of autocross days and 36K+ miles and my dampers still seem to be working fine.
Build thread:Here
The Following 2 Users Say Thank You to whataboutbob For This Useful Post:
448hpsti (08-26-2013), hmong337 (08-25-2013)
Old 08-25-2013, 06:48 PM   #25
Dan@AWD
Drives: 2013 Argento FR-S
I have the Hotchkis springs, which are exactly a 1" drop on the stock shocks. I have 5000 miles on them with no issues.
Sent from my Moto X.
Dan@AWD is offline   Reply With Quote
The Following User Says Thank You to Dan@AWD For This Useful Post:
Old 08-25-2013, 10:04 PM   #26
hmong337
Emperor JDM
hmong337's Avatar
RCE yellows have definitely got the reviews but I'm also going for a bit more cosmetic and would like at least a 1" drop.
Old 08-25-2013, 10:10 PM   #27
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
i just installed my frs swift springs, and there's no issue with the bump stops etc. Perfectly fine with the stock struts. The drop looks to be around an inch and a half.
bkblitzed is offline   Reply With Quote
Old 08-25-2013, 10:43 PM   #28
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Drives: Vortech Prototype Test Car
where did you buy swifts from?
448hpsti is offline   Reply With Quote
Cusco products, Swift Springs and <Koni Shocks/SPC rear camber kit> b2autodesigns Brakes, Suspension, Chassis 713 09-11-2017 12:03 PM
FS: OEM springs and shocks Bcarlos Brakes, Suspension, Chassis 7 01-19-2014 02:58 PM
Oem shocks and springs Jhon19lopez Brakes, Suspension, Chassis 3 05-20-2013 04:33 PM
Springs & Shocks: Which to Buy? GhostofAkina Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 03-11-2013 01:16 PM
TRD Springs on std shocks? Panman AUSTRALIA 3 02-14-2013 02:59 PM
