Old 08-23-2013, 04:33 AM   #1121
tech4pdx
Make love
tech4pdx's Avatar
Drives: H8R.. Not really
Originally Posted by NickFRS View Post
Well on my way home from work "cruising at 3k RPM's cruise control on" My charger sounded like it was at red line randomly so I started to pull over and clutched in. When I can to a stop the charger sounded like a chainsaw (no CEL) so i turned my car off. My tuner "PREracing" Bobby woke up after hours to check things out. He cut my belt and my car started right up and purred like a kitten. My car is now resting at the shop until I can figure things out tomorrow. Jason at nameless performance also picked up his phone to talk to me and address some concerns with the charger but unfortunately he was out of state and couldn't assist me. So glad I live in the NW where we have so many amazing saints of the auto industry.
A meth kit will fix this right up.
tech4pdx is offline   Reply With Quote
Old 08-23-2013, 04:53 AM   #1122
diss7
Drives: AE86, 2x GT86, TE27
Originally Posted by ft_sjo View Post
If you want to name drop, it was the CTO of Sprintex who told me. Don't shoot the messenger.
Keep in mind (as you may have missed it) I have an under drive crank pulley. So, I'm getting a smaller pulley on the sc to compensate for that, not to work the sc harder.
diss7 is offline   Reply With Quote
Old 08-23-2013, 05:23 AM   #1123
OrbitalEllipses
Drives: Attitude
Doesn't our stock ECU read up to 7PSI? My Scan gauge is only picking up -22 to 5.5lb's of boost.
From what I hear intercoolers on these kits create lower intake temps but rob some boost. (easy fix with a smaller pulley!!!)
You're creating the same power with less psi when you use an intercooler. It's not robbing you of boost it's being more efficient, usually through more aggressive timing due to the cooler intake charge.
Old 08-23-2013, 06:36 AM   #1124
ft_sjo
Drives: GT86
Originally Posted by DarrenDriven View Post
SERIAL NUMBER NEEDED @ft_sjo (Sprintex model in AUS)
Oh look. 080313. Stage 2 yo.
Old 08-23-2013, 07:49 AM   #1125
s2d4
s2d4's Avatar
Exactly, it isn't dictated by the supercharger pulley size itself but instead it would be how fast the supercharger spins up to with the specific crank/supercharger pulley ratio in ones setup.
Old 08-23-2013, 08:18 AM   #1126
xxscaxx
Drives: 2013 SWP BRZ
Not sure how this is going unnoticed really but please keep us updated. I'd reach out to Innovate as well. Hope everything is works out.
xxscaxx is offline   Reply With Quote
The Following User Says Thank You to xxscaxx For This Useful Post:
NickFRS (08-23-2013)
Old 08-23-2013, 08:21 AM   #1127
swift996
swift996's Avatar
FWIW here is a plot of a pull last night plotted from data acquired via Torque:
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 08-23-2013, 10:47 AM   #1128
invisage
Drives: Thunder Silver 86 GTS
That boost drop off at the end is ... odd?
invisage is offline   Reply With Quote
Old 08-23-2013, 10:50 AM   #1129
ft_sjo
Drives: GT86
@invisage why do you think it's odd?
Old 08-23-2013, 11:11 AM   #1130
s2d4
s2d4's Avatar
Well, why should the charger stop compressing air, it should keep increasing with rev.
It is belt driven after all unless it is a magnetically clutched pulley being disengaged or something is letting air out after a specific boost level.
Old 08-23-2013, 11:13 AM   #1131
swift996
swift996's Avatar
Originally Posted by s2d4 View Post
Well, why should the charger stop compressing air, it should keep increasing with the rev.
It is belt driven after all unless it is a magnetically clutched pulley being disengaged or something is letting air out..
Perhaps the bypass valve opens? I'll get an EcuTek data log this evening. I was using my china bluetooth adapter to torque so who knows.
Old 08-23-2013, 12:01 PM   #1132
sw20kosh
Drives: 2013 Black FR-S
No the bypass only opens if it gets vac to its nipple. The valve door is a butterfly and this cannot be "forces open" by boost.
Only two things I can think of:
1. Belt slip
2. Charger output is not adequate to compress air (to maintain 8 psi) at that Rpm with your breathing mods.
This is a small blower.
Old 08-23-2013, 12:08 PM   #1133
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Try it again with your stock airbox? The extra 2+ feet of piping might be the cause.
Old 08-23-2013, 12:11 PM   #1134
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
That has to be the worst sampling rate I have ever seen, haha. Get an EcuTek log and do a third gear pull from 2000 RPM please. kthxbai.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
