Old 08-22-2013, 02:39 PM   #1527
Toma
Drives: Viper, Mustang, FD RX7, FFR GTM
Fenton. If that filter on the inlet is one of those ractive or vibrant shielded cones
.. ive seem a 20hp LOSS on a na B18 honda. Garbage. Just use an open element I kn and I assume you guys are just gonna ditch the airbox and poke the inlet out the front.
Limit boost to 5 or 6 psi max and let them both scream wide open at redline. My guess is 3.5 psi and the 230 rwhp.
Toma is offline   Reply With Quote
Old 08-22-2013, 02:44 PM   #1528
Robftss
Drives: VW
Originally Posted by bfrank1972 View Post
I believe you are right about the sequential vs parallel:
http://www.engineeringtoolbox.com/pu...ial-d_636.html
Wouldn't parallel make more sense as we're looking to keep boost low but maintain that boost at high rpm? i.e. double your CFM by using parallel units, and not worry about limiting boost by switching the motors?
Series as shown.
Parallel:
- Remove 'spider' intake manifold.
- Supercharge each 2 cyl (100hp) bank separately with its own ESC, 'Y' the inlets to a single MAF. I think this would look cool! and make room with the manifold removed.
- Run both units off a larger 24V, 35-40 AHR SLA, this will keep the PR's balanced.
Since the VW is 115hp stock, using two TQ18024V smaller units per side on the FA20 would yield ~ 3.5 psi to redline
Similarly, 370Z and early BMW 850i use two separate MAF/intake/manifold/cylinder runs, effectively 2 banks on a common crankshaft.
Robftss is offline   Reply With Quote
Old 08-22-2013, 02:47 PM   #1529
Toma
Hmm can you explain further? My intuition tells me we'd need a parallel system - tractor pull guys are not flow limited and they're looking for max boost pressure. This ESC system for the 86 needs more flow, not max boost right? A single unit produces enough boost pressure at low RPM, but boost drops as the motor requires more CFM. I would think the parallel rig, compared to the sequential rig, would produce less boost at low rpm, but more at higher rpm (where we need it)? I'm not a mechanical engineer so please feel free to correct me
The set up is not flow limited. Its easy to flow a ton of air with no restriction. Put a restrictor at the outlet... say an engine lol.... and then moving the same air starts to take exponentially more power as restriction... ie boost.... rises. So if you feed a compressor already compressed air... it has to do less work to move the higher volume of air.
In parallel... both turbos are fighting the same boost restriction but need to flow less cfm. But cfm is the easy part. Its the pressure that is hard.
I have a shop dyno fan that will flow 15, 000 cfm free flow with only a 1hp motor. Yet it takes 5 hp to move 300 cfm at only 2psi. 6 psi at say 800 cfm can take 35 hp
Old 08-22-2013, 02:48 PM   #1530
bfrank1972
Drives: 2013 FR-S Argento
Originally Posted by Robftss View Post
Series as shown.
Parallel:
Cool! What's the benefit of plumbing to individual banks? Could it be simplified with parallel chargers just feeding into the stock intake manifold?
Old 08-22-2013, 02:50 PM   #1531
meadowz06
THE CORVETTE KING!
meadowz06's Avatar
Drives: 2013 FR-S, and 2016 FR-S!
I have been thinking about selling my Lingenfelter built supercharged Corvette to buy a FR-S. And this electric unit has really got me excited. I can go back and try to find the information, but how much is the TOTAL cost for this kit? I am a manager at a Toyota\Scion dealership, so I could buy the FR-S for a good price.
meadowz06 is offline   Reply With Quote
Old 08-22-2013, 02:57 PM   #1532
bfrank1972
Ok, I think I get you - I was thinking the compressor was limiting flow, so it's the motor (or power to the motor) that is essential limiting factor? if that's the case and you assume equal amounts of power are going to two motors in either setup (series vs parallel), the 'in series' setup is actually more efficient? Bear with me, I'm trying to wrap my brain around this! Thanks
Old 08-22-2013, 02:58 PM   #1533
Robftss
Drives: VW
Balancing the pressure from the two outlets is difficult, path of least resistance, will cause pressure from one unit to flow into the other if there is even a small delta P. Once this happens the 'backfeed' centrifugal wheel may surge (low flow). I believe this is resolved on the turbine side on parallel turbo systems, balancing the wastegates via pressure.
Isolation works best.
Old 08-22-2013, 03:06 PM   #1534
fenton
Yes that is the idea, i think that intake is just one that Rob had sitting around.
The airbox would be ditched and the airfilter would sit in the area that the perrin intake or some turbo kits place their filter.
Removing the stock intake will require a significant amount of tuning to get it running right i think. This is really just for fun, it isnt all that practical.
fenton is offline   Reply With Quote
Old 08-22-2013, 03:46 PM   #1535
Toma
Tuning wouldn't be any harder. It's just the MAF flow curve. Easy breezy.
I think if the battery power is there, it would be very practical
Old 08-22-2013, 04:49 PM   #1536
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
While fun to discuss, the twin charger is a distraction. I'm more interested in development updates, and ultimately PRODUCTION RELEASE.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
Old 08-22-2013, 06:00 PM   #1537
NickFRS
Drives: 2013 Asphalt FRS
I knew that would piss all you guys off
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
NickFRS is offline   Reply With Quote
Old 08-22-2013, 06:11 PM   #1538
NickFRS
Originally Posted by Gary in NJ View Post
Nick, you are comparing apples to alligators.
The driver of a turbo or SC car with exhaust mads and the like is *generally* looking for big HP gains.
The ESC is for the driver that is looking to improve the torque curve (on demand) on a much smaller scale.
I was very interested in the Innovative SC until the Phantom came along. The ESC meets all of my performance and reliability needs. I had concerns with 100% boost over a long ownership period. Being able to choose when I apply boost means a lot to me.
Only time I hit boost is at WOT. I usually drive in -boost. Bypass valve ftw. Only lost 15 miles to a tank.
@fenton is this charger only when you flip it on? After your done with drift office you should bring it down to PIR and see what it traps in the 1/4 mile.
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
Old 08-22-2013, 06:33 PM   #1539
bfrank1972
Definitely kept the thread near the top of the FI section
Old 08-22-2013, 08:16 PM   #1540
Pug
Atoning Unifex
Pug's Avatar
Drives: '13 BRZ Premium, WR Blue
Originally Posted by Fast_Freddy View Post
Just to throw a few facts into the recent BS spew... The Innovate SC costs $3195 with free shipping vs the pre-production estimate of $1500 for the ESC. Shipping costs and inclusion of batteries is unknown. Tuning for either charger will cost the same depending on the tuning method and tuner you choose. The results are far from equal but for many the ESC will be good enough. I'm even considering it now.
I bought batteries here in the states from AtBatt. I got 2 of the correct batteries for the system (they are specific 12V/18AH, sold as a two pack PS-12180-NBx2) and one bigger battery for the starter. (12V/21AH) 1x PSH-12180FR.
I did free shipping and the batteries arrived in 3 days for a total of $139.03.
Power-Sonic 2 x 12V/18AH Sealed Lead Acid Battery w/ NB Terminal
SKU: PS-12180-NBx2 (8429) $99.49 $99.49
Power-Sonic PSH-12180NB FR Sealed Lead Acid Battery
SKU: PSH-12180FR (21861) $54.99 $54.99
SUBTOTAL $154.48
SHIPPING -
Thursday Special (M024PTL - 10% OFF) - $15.45
TOTAL $139.03
Pug is offline   Reply With Quote
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
