Old 08-22-2013, 11:14 AM   #1079
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
20 people in this group buy there has got to be someone else using the stock OP
ATL BRZ is offline
Old 08-22-2013, 11:22 AM   #1080
LavosTRD
Toyota Master Tech
Drives: Whiteout MT
If I had mine I would tell you 😉
LavosTRD is offline
Old 08-22-2013, 11:46 AM   #1081
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
Mine will be connected to the full stock exhaust for a little while at least
kask2_6.0 is offline
The Following 2 Users Say Thank You to kask2_6.0 For This Useful Post:
ATL BRZ (08-22-2013), HatchetBurial (08-22-2013)
Old 08-22-2013, 12:25 PM   #1082
xxscaxx
Drives: 2013 SWP BRZ
Mine is connected to the stock OP. Didn't notice any mating issues or leaks. I did notice how big the bolt holes are on the JDL header though, I want to throw a washer on there when I put the new revised header back on.
Wonder if I should just buy an OP...just can't justify the money they cost for the little gains they produce.
xxscaxx is offline
The Following User Says Thank You to xxscaxx For This Useful Post:
Old 08-22-2013, 12:39 PM   #1083
swift996
swift996's Avatar
Running a different header and added an over-pipe, maybe 3-4whp but a lot more rattling and noise coming from the exhaust work now. Not convinced it's worth it.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline
The Following User Says Thank You to swift996 For This Useful Post:
Old 08-22-2013, 12:41 PM   #1084
xxscaxx
Thats why I kept mine stock, lol.
Then again i'm getting noises anyway.
xxscaxx is offline
Old 08-22-2013, 12:42 PM   #1085
FR-S Matt
As long as my header is louder than the crickets.... Mission accomplished.
FR-S Matt is offline
The Following 2 Users Say Thank You to FR-S Matt For This Useful Post:
ngabdala (08-22-2013), Spartan65 (08-28-2013)
Old 08-22-2013, 01:41 PM   #1086
ATL BRZ
ATL BRZ's Avatar
I just don't find the $300+ for an extra 3-4hp worth it, especially knowing there's a strong possibility of clearance/rattling issues (under load with stock motor mounts) not only with my bigger RCE front sway bar, but also possibly contact with the frame. Swift seems to have mended the sway bar clearance issue with some washers under the sway bar mounting brackets but I'd just rather not deal with it. The stock OP has good heat shielding and clearance so I'd rather not mess with it as long as it seals perfectly against the header.
I will take @xxscaxx 's suggestion about using some washers on the OP-to-header bolts to have some cheap seal insurance.
ATL BRZ is offline
Old 08-22-2013, 02:01 PM   #1087
xxscaxx
If you look one page back at Lee's install photos, you can see the bolt i'm talking about. There is no washer for the side shown and the bolt is awfully close to the size of the actual hole to pass through.
I didn't have leaks coming from here though. Once I get time to put my car up on stands again I will check it out.
xxscaxx is offline
Old 08-22-2013, 03:09 PM   #1088
FR-S Matt
I'll be hooking mine up to a Nameless full 3" downpipe. Clearance looked pretty decent last time I checked, but I'll be sure to post pictures.
Old 08-22-2013, 07:49 PM   #1089
JDLAutoDesign
JDLAutoDesign's Avatar
Drives: 13 FRS
@ATL BRZ
Here is our collector flange bolted up to the OEM overpipe. I dont really think you will have issues with leaks but we dont recommend using OEM as the transition is less than ideal
JDLAutoDesign is offline
The Following 2 Users Say Thank You to JDLAutoDesign For This Useful Post:
ATL BRZ (08-22-2013), ngabdala (08-22-2013)
Old 08-22-2013, 08:03 PM   #1090
ATL BRZ
ATL BRZ's Avatar
Originally Posted by JDLAutoDesign View Post
@ATL BRZ
hmmm thanks for the pic but even if I bought a new overpipe I'd still have that transition to my stock front pipe. It's a slippery slope that I wanted to avoid. I just want a good seal....
ATL BRZ is offline
Old 08-22-2013, 10:43 PM   #1091
JDLAutoDesign
Drives: 13 FRS
Still going!
The Following 8 Users Say Thank You to JDLAutoDesign For This Useful Post:
ATL BRZ (08-22-2013), JETRED (08-26-2013), kask2_6.0 (08-23-2013), kiichiro (08-26-2013), mkivsoopra (08-22-2013), Ninjin (08-23-2013), scudzey (08-22-2013), ultra (08-26-2013)
Old 08-26-2013, 10:12 AM   #1092
ultra
Curious cat.
ultra's Avatar
Drives: 86 GT base M/T - Red
Still going!
Are those just sexy, or are you using a special camera?
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold)
1991 Mazda MX5 Miata (sold)
2007 Mitsubishi Evo 9 RS (sold)
2006 VW Golf R32 (sold)
ultra is offline
UEL Header Development 86drift Engine, Exhaust, Transmission 77 07-07-2016 01:45 AM
SRT Header Back Exhaust System Intro Piricing Swift Racing Technologies Engine, Exhaust, Bolt-Ons 51 09-25-2012 10:00 AM
Essex/AP Racing Competition Brake System in Development JRitt Brakes, Suspension, Chassis 1 06-14-2012 01:32 PM
