#211 | |
VehicleDynamicsSpecialist
Drives: iG FR-S
-32mm front -33mm rear
"The best track modification you can ever make is between the steering wheel and seat." - CSH |
#212 |
Drives: White 86 Sport Plus
Anyone know H&R sport spring rate??
#213 |
Drives: 2013 Scion FR-S Asphalt 6-Spd
Swift Sport Mach FR-S springs. 1" drop.
(upper pic is after install and lower pic is before) Sent from my iPad using Tapatalk HD
Don't Text and Drive
KCCO:happy0180: |
| The Following User Says Thank You to SWAMechFRS For This Useful Post: | WingsofWar (06-26-2013) |
#214 |
Drives: iG FR-S
They don't seem to list spec.
For more information, visit www.hrsprings.com and www.trakplus.com or call (888) 827-8881.
#216 |
Drives: '13 dgm brz
Why do some springs (Tanabe, H&R) have a bigger drop in the rear while others (Tein, Prova) lower the front more? Is it a function vs. looks thing? The only reason I can imagine why you'd want a lower rear end is to move weight bias back (but I don't imagine a couple mm's would make much difference). Visually the front needs a bigger drop to keep the wheel gap consistent front to back.
And the spring rates are confusing too. Some of the lowering springs barely increase front rate at all, while many of the coilover come with the same rates front/back or stiffer fronts. Why the different approach? I don't even think I've ever seen an FR with stiffer springs in the back. Can't argue with the result handling-wise but it's too bad there's not more choices offered by the aftermarket (I see you RCE Thx Darren and WingsOfWar for the informative and easily digestible info. One of the better enthusiast forums I've visited.
| The Following User Says Thank You to Cesium Rainbow For This Useful Post: | Racecomp Engineering (07-04-2013) |
#218 |
Drives: 86
#219 |
I have my ride set on a 7 stiffness level all the way around and its more stiff that stock but not bad at all for daily driving. The height in this picture is adjusted. Out of the box the BCs I had would have dumped the car.
#220 |
Drives: 86
thanks
#221 | |
Drives: FR-S|(2)AE86|TA22|E30M3|E36M3|BPLeg
On the affordable side that still very comfortable, I recommend the Hotchkis springs with Koni shocks, or even the Sportlines. The new ST suspension coilovers look like they may be perfect for her needs. Pair either of these with camber/caster adding upper shock mounts and your will have a very comfortable car, great performance and no more cost than most entry level coils! If you want a bit more adjustability, then I have 3 very happy customers with Ground Control kits. They are very nice. I also like the FEAL kit (BIG review coming soon), but they are for someone who sounds more focused on track days than your GF. Best
| The Following User Says Thank You to Esoteric For This Useful Post: | clayrush (07-16-2013) |
#222 |
Drives: FR-S stock for now
Just let everybody know I have been testing the Bilstein Damptronic package on my FRS. I make a control box for the Porsches and GTRs that we adapted to the FRS, it uses the CAN for G, steering ,tps and braking to control the shocks. It rides soft but firms up based on mapping, pretty cool.
DougW |
| The Following User Says Thank You to DougW For This Useful Post: | DAEMANO (01-13-2014) |
#223 |
Wayward Member
Drives: Hot Lava 86
Why is it that all the springs with minor drops are TBA? I don't want to go very low and right now the lease I can find is the RCE Yellows with their .8" but I think I'd prefer a .5" instead.
#224 |
Drives: '13 dgm brz
| Adjustable shocks+ springs vs Coilovers | CyberFormula | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 44 | 06-08-2013 03:59 PM |
| Canadian FR-S options VS U.S.A's options? | Tino | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 11-06-2012 10:07 PM |
| coilovers or springs? | koyv90 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 45 | 04-01-2012 08:49 PM |
| Gearing Options and Diff options | airboy808 | Engine, Exhaust, Transmission | 26 | 12-25-2011 01:11 PM |
| Subaru BRZ different suspension / springs tuning | ahausheer | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 35 | 12-06-2011 12:52 PM |
